Question about Panasonic Viera TH-42PZ85U 42 in. Plasma TV
Red Blinks - No Power
TV does not come on. Red light blinks. Blinks in series of 2.
  • 88 Answers
2 blinks is one of the power sources not coming up. most likely thje power board,but a short on a periphael board can mimmick. Only a Panasonic auth service should be used and expect a repair of $200 to $400. Since the set is not very old,call the panasonic number in your book......they will give you a case number and in some instances may cover it!!
Posted on Jun 04, 2010
4 Suggested Answers
SOURCE: TV will not come on andthe red power light starts blinking in a short series of 6 blinks and a pause of approximately 2 or 3 seconds.
its haveing a power problom. it had a power serge thats why it dose that. i work on them everyday it has a bad power chip. if u want to get rid of it email me at moonlight1874@aol.com
Posted on Sep 27, 2008
djchillsnyc
  • 151 Answers
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Posted on Dec 14, 2008
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-50PZ80U tv, error- 2 blinks
1. Reseating the connector P25 may solve the problem. If it does not.
2. Unplug the unit andd disconnect the connectors A5, A6, and A7. Apply power to the TV. If a White screen comes up and all voltages check normal, replace the P board.
3. If the TV stays on after isolating the SC board, then replace the SC board and the D board; it is likely that the fuse on the D board is blown.
Posted on Dec 06, 2009
Beeps red light hp pc
The blinking should be in a pattern.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
Aug 17, 2013 | HP Computers & Internet
I have a Panasonic HDTV 1080p and it won't turn
You have a 5 year old projection TV with power supply trouble
Jul 13, 2013 | Televison & Video
Error code 13 on mitsubishi wd52628
wait for the light to go out then press power. Then if it doesnt power up hold the menu and the Device/input buttons on the set both in together for 5 seconds the light will blink a series of blinks pause briefly then blink another number of blinks then pause then it will repeat the same two digit blink sequence a few times . Let me know the two digit blink sequence.
Aug 29, 2012 | Mitsubishi WD-52628 52" Projection HDTV
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
Th42px80u- tv wont come on and red light flashes 10 times
Here are all the Panasonic blink codes.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Oct 21, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Sony KDF-50E2000 shuts down and blinks repeatedly twice.
The 2 blink error is a temperature error and the 6 blink error is a thermal fuse error. You may need to unplug the set and get you a can of canned air, take off the back lower cover and blow out all of the fans inside the set.
Oct 20, 2009 | Sony KDF-50E2000 50" HDTV
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
The tv wont turn on
PT-44LCX65
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
Sep 27, 2008 | Panasonic TC-32LX60 32 in. LCD Television
Red light blinks
Check the lamp door (with green on) ,.. both green and red blink - bad lamp. Green off, red blinks..Try unpluging for 2 minutes and retry - if no different (sorry, call a service person).
Apr 21, 2008 | Toshiba 43H70 43" Rear Projection...
Panasonic Viera TH-42PZ85U 42 in. Plasma TV Logo
1,142 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
