Question about Ryobi 30 Cubic Centimeter Gas Brush Cutter
I have to prime with fuel direct into the cylinder by removing the plug to get it started. It will then run at full throttle. If I let off the throttle it dies. If it is hot it will restart by just chocking. It has a new carb. & plug.
    Sniper:
  • 56 Answers
First I'd try opening the low speed mixture screw a smidge (1/8) turn increments and see if that might improve the idle to full throttle transition.....if that doesn't help try cleaning the carb....other things to check are the vent in the fuel cap....the filter in the tank inlet line and whether fuel is getting to the cylinder on starting ( pull start handle a few times, then remove the plug to see if your'e getting fuel to the cylinder) sounds like your'e not getting enough fuel to start....maybe a clogged mixture jet....hope this helps ;-D
Posted on Jul 15, 2010
  • 420 Answers
I suspect the rings are worn and not sealing as well. the small two stroke engines such as that one are designed for 25 - 50 hours depending on the brand and model.
Posted on Jun 04, 2010
Trimmer won't prime to start
Look inside the tank. Some units have a stone inside that blocks the fuel line when it is tipped a certain way. Might be what's happening here.
Aug 13, 2016 | Garden
My 2.4l dohc won't start after head gasket replacement. Where to check for problem?
You need three things things to get the engine to run.
1. Fuel. Ensure that the fuel pump is providing a proper prime and check fuel pressure at the rail if possible.
2. Air. Air comes in thru the intake and throttle body. But air alone wont work unless there is compression. Remove all the plugs, remove the fuel pump relay, and check the engine compression at all cylinders. The compression should be approximately equal in all cylinder and more than 120 psi. If all are low, then there is either a problem with the crank/cam timing or the head is damaged/cracked.
3. Spark. Ensure that the plugs are firing at the cylinders.
Oct 29, 2014 | Vehicle Parts & Accessories
How do i tell why me intex 24hp motor won't crank
what I do to test this is to remove the spark plug , inject some fuel through the plug hole directly into the cylinder. You can use a dropper, a straw , or pour...about one table spoon full. Thaen re-insert the plug and try to start several times. If it fires, even a little bit, then is is a fuel problem. Try this several times... If it only needs fuel... this will prove it... I have also sprayed starting fluid into the cylinder to try to get an ignition. This will work to prime an engine that has sat for some time as well.
Oct 10, 2014 | Craftsman Garden
Poulan leaf blower won't start
Check compression. 120-140 is good. over 100 it will run. Less than 90 is below service limit. Remove the muffler and look at the cylinder and piston. Do you see lines running up and down? a dull grey color? Those are signs that the motor is burnt up. The cylinder should be shiny, almost chrome, with no marks on the walls.
A severely flooded engine will give a false low compression reading. If no visible damage is found in the cylinder- its shiny with no marks- then reinstall the muffler, remove all fuel from the tank, open the choke, give full throttle and pull start cord several times. Maybe 10 or more times. If it starts keep the throttle open and let it run full speed until it runs clean. Then add good fuel and try to run. If it runs that's great. If it continues to flood itself the diaphragms are stiff and the carb needs rebuilt.
Aug 29, 2014 | Garden
83 yamaha enticer 300 wont start. if i use starting fluid directly into cylinders it runs and dies
Check for your accelerator pump is pumping fuel directly into the engine when you rotate the throttle, if not then you probably need a carburator fuel pump kit. (usually located on the outside of the carbs). However, through following the mechanical linkage, you can see that it leads directly to the little pump assembly as well.
Good luck my friend.
kd4rua
Dec 29, 2011 | Motorcycles
The motor turns over when I turn the key but it will not run. New battery, new plugs, new fuel line, and cleaned carbs. Fuel petcock was left open a couple times when I first got the bike. Has not been...
ARE YOU GETTING A SPARK AT ;PLUG REMOVE PLUG HOLD AGAINST ENGINE BLOCK TURN OVER ENGINE YOU WILL SEE SPARK OR FEEL IT IF YOUR UNLUCKY BE CARFUL IF NO SPARK TRY CHANGING SPARK PLUG LEADS COULD BE U/S GOOD LUCK [FROM THE AUTO ELECTRICIAN]
Aug 28, 2011 | 2005 Hyosung GV 250 Aquila
My 2005 450x is hard to start and when it does start it will not stay running
Install a new stock spark plug. Clean the air filter then remove and clean the carb. Drain the gas tank, clean out rust and any trash, and remove the fuel valve to clean the internal tank filters. Now install an in-line fuel filter in addition to the tank filter.
3a4f4c0.gif What follows is just in case it will help out. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There is a proper way to start the engine. Four controls are on your bike to assist in starting. Below are generic instructions.
  • The choke, used when the engine is cold. Pull the red knob for choke.
  • The " Hot Start " Lever, used when the engine is hot. Pull the lever to lean the fuel mix when the engine has been running.
  • The de-compression lever, always used.
  • The throttle, used to prime the cylinder, (power valve).
Don't kick, instead, push the kick lever downward. You will feel the back pressure as the piston is going upward on the compression stroke to the point the pressure is great enough that the kick lever "locks up". You are very close to TDC. NOW, pull in the de-compression lever. Push the kick lever a little bit more to get the piston past TDC. Now release the de-compression lever. Give the throttle a 1/4 turn then let it snap closed. A diaphragm, (Power valve), in the carb gives a shot of gas when this is done. DO NOT do this multiple times because you will flood the engine. Leave the throttle closed when kicking. A flooded engine will often backfire. Now give a strong kick through the full sweep of the kick start lever. Quickly get your foot off the kick lever at the end of the kick to avoid any chance of "kickback" from the kick lever. This happens in the case of a misfire, aka > backfire. It can be very painful, and can even break a leg. I am serious about that. Repeat the process (but without the throttle priming), for six kicks. After six kicks go ahead and twist the throttle again for a second priming. A good battery, a clean spark plug, a clean carb and clean air filter will also aid in starting. Note that not all carbs have a power valve. When a power valve is not present you should crack the throttle open only 1/8 inch from closed on each kick.
Jan 13, 2010 | 2005 Honda CRF 450 X
Will not start. I prime the unit by depressing the bulb 7 times, the choke is full and the throttle is full. It simple does not try to start.
take the spark plug out pull the rope and see if gass comes out of thr cylinder which tell you theres to much gas coming out if your getting to much gas pinch your fuel line pull till it starts thenunpinch it if its firing it will start
Nov 05, 2009 | Garden
I have a 94 Toyota 22RE that starts fine runs for 45 sec and cuts off. Just replaced the fuel pump and still does the same thing. When I try to give it gas it seems like going to cut-off until I let off...
replace the throttle postion sensor also pull catalitic converter and clean out if it's plugged. You can remove the idle adjust screw and reset it but i would have to give you full proceedure to do that so post here for more detailed information.
Jul 18, 2009 | 1994 Toyota Pickup
Difficulty starting Poulan 2250 . . .
hey pete
This is easy, prime bulb 5 to 7 times with choke lever full out. Pull string, once engine starts turn off choke and pull string again. ( throughout process do not pull trigger )Engine should start, let it idle 30 seconds, then finally pull trigger to rev up engine.
Jul 03, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Ryobi 30 Cubic Centimeter Gas Brush Cutter Logo
186 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
