Question about Sony Cyber-Shot DSC-P93 Digital Camera
I dropped my sony cyber shot dscp93a the lens
I dropped my sony cyber shot dscp93a the lens will close but now i cant zoom in or zoom out it will stay in one positon i can still take pics
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jun 04, 2010
Lens size of a Sony Cybershot DSC-HX100V
he Cyber-shot HX100V's Carl Zeiss Vario-Sonnar 30x zoom lens has a range of 27-810mm (equivalent) with a maximum aperture of f2.8-5.6.
Aug 04, 2012 | Sony Cyber-Shot DSC-HX100V Digital Camera
Sony cyber-shot dsc-w570 lens cover won't close
Lens block is faulty you must replace it with a new one
Nov 04, 2011 | Sony Cyber-Shot DSC-W570 Digital Camera
When i turn off my camera sony cyber shot DSC-S90 the zoom wont retract and a word appear in the screen turn off and on again..any idea what's going on with it?
Sounds like you have some grit or gum on the lens barrel. This will cause the lens to stick in the partly closed position. Clean the lens barrel and try again. A rag moistened with methylated spirits may be needed. The rag must not be wet as we must not harm the special grease used in the lens.
If this fails it probably means an very expensive repair, or replacement.
Feb 19, 2011 | Sony Cyber-Shot DSC-S90 Digital Camera
The camera was dropped with the lens open. Now it
Bad news - there is no DIY fix for lens damage. The drop likely damaged the lens tube (housing) or jarred the zoom mechanism off of its track. If you attempt to fix it yourself you are likely to worsen the damage, so the camera will need professional repair.
Oct 19, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Zoomlens stuck
Examine the lens carefully. you will see that the outer lens is out of line with the inner lens. . hold the camera firmly with one hand using the fingers of the second hand firmly nudge the outer lens back in line. reinsert battery and test.
Good luck,
Luwangula
Sep 15, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Cant zoom
lens stuck error, probably a broken gear teeth.
Jul 15, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Zoom lense 'Slanted'
The parts (gears) are manufactured in plastics so once damaged it is very difficult to rebuild. Sony does not sell gears but complete lens assy. so best way is to find out what Sony charges for the repair. At www.camerarepairjapan.com the rebuilt of zoom repair was around $120 with 3 months warranty. Good luck. James
Mar 26, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Cant zoom on my DSC-W80 sony cybershot after droping it in the sand at the beach
If you found good information in my solution, please be sure to rate it! Thanks!
Oct 25, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Lens/zoom wont come out
The lens mechanism inside of the lens unit is damaged. The fix is to change the lens. You can send the camera to authorized service rep for an estimate. I believe that the cost of service many be close to or even more expensive than replacing the camera.
Jerry G.
Jul 03, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-Shot DSC-P93 Digital Camera Logo
96 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
