Question about Bosch MON171CL 17 inch Monitor
Monitor Red Color
If i use the Video inputs 1, 2 and S-Video,
The screen is full of red in color, after i connect to the video, the video looks red in color also. seems to be red and blue missing only in the Video inputs, But for VGA input The color is good, RGB is perfect,
Only the Video inputs got problem, How can i rectify the fault? to get the Green and blue color for the video inputs? Is there got and settings?
3 Suggested Answers
  • 3 Answers
SOURCE: bosch LTC1461/12
Hi:
Try TimeLapse Supply.
Search on the web you'll find them in no time. I use them a loton Autodome parts mainly, great service... See if you can finda something there that intrests you..
Posted on Mar 23, 2008
  • 145 Answers
SOURCE: I am using this monitor
Hello there,
ok so if i understand this problem correctly you have a Monitor connected to a DVR for a CCTV System, when cycling through the inputs on the Monitor you find the correct input for the CCTV system but the monitor only stays on this input for a few seconds .
sounds like the input is going out or the Monitor is programed to stay on a single Input, I would try both move the CCTV System to another Input on the Monitor and if that fails see if the Monitor has any Pr-Set settings then you can Default .
if you need any Help with the Default let me know and i hope this information was helpful don't forget to Rate.
Posted on Jan 27, 2011
Testimonial: "Some good idea's thanks, will give it a try."
How to tune up dvd player
  • Plug the power cable of the Samsung VHS/DVD player into an available power outlet near the television.
Connect a set of RCA audio and video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. The colors of these cables are yellow (video), white (left audio) and red (right audio).
Take the other end of the RCA audio and video cables and connect them to the color-corresponding inputs on your television. When plugging in these cables, look for a label for the input, such as "Video 1" and "Audio 1." This will be important in Step 5.
Turn on the television and the Samsung VHS/DVD player.
Tune your television to the video input channel that you noted in Step 3. If you did not take note, you can also tune through your television's input channels until you find the one displaying the signal from the DVD/VCR player.
Insert a VHS tape or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Component Video
Connect a set of component video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. These cables will look similar to composite audio and video cables, but they are instead color-coded as red, blue and green.
Plug the other end of the component video cables into the color-corresponding inputs on your television. Take note of what input number you are plugging the cords into, as it will be useful later.
Connect a set of RCA audio cables to "Audio Out" jacks on your VHS/DVD player, then connect the other ends to your television. These cables are color-coded as red and white and must be plugged into the same input number as the component video cables.
Tune your television to the component video input channel where you connected the Samsung VHS/DVD player.
Insert a VHS or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Jul 10, 2012 | 2005 Toyota Caldina
The DP26649 model TV has three inputs; video one (which is fine and has all color and everything), video 2 (if you plug them in certain ones the best i can get is full sound and all but its black and...
OK, here is the breakdown on whet you are doing wrong.
Video 1 - Composite -
Video - Yellow
White - Audio In - Right
Red - Audio in - Left
Video 2 - Components - HD - RGB = Red, Green, Blue
Video -
Red - Red Colors
Green - Green Colors
Blue - Blue Colors
Your GameCube will only work on Video 1, unless you buy an HD (Component cable). You will need to buy HD cables for your device connected to Video 1 to work on video 2. I will assume it is a DVD player. This is a high definition cable to produce a better picture. Let me know if you do not completely understand
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 06, 2011 | Televison & Video
I just purchased a Sanyo Hdtv Lcd and the picture quality if off the picture seems to come out greyish or pale....i'm not getting a true color. Is there some adjustments that I should know about? I tried...
Check hookup connections. If you are using the component input (3 wire video green ,blue and red). Be sure both ends are in the correct colors. if switched or not all 3 connected color will be off. Composite video uses only 1 wire ,yellow. See owners manual for hookup explanations.
Mar 07, 2011 | Televison & Video
I don't know where to put the yellow, red and white connectors on the TV or the dvw
look on the back of your flat screen , there is a panel with inputs , example: VIDEO 1 , VIDEO 2 , etc. , connect your yellow , red & white from the DVD COMBO to video 1 (input) there colored to match with your cable , yellow w/ yellow , red w/ red , white w/ white , hope this helps AJ
May 08, 2009 | Sanyo DVW-6100 DVD Player/VCR
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Wii has no color
Are you connecting you Wii to a progressive scan TV input (2 for audio (red)(white), 3 for video (yellow)(blue)(red)?
It's possible you have the red audio and red video inputs switched.
If you have the regular AV-Cable (2 for audio (red)(white), 1 for video (yellow)), and your TV has 5 inputs (progressive), look for the 3 inputs (2 for audio (red)(white), 1 for video (yellow). If it doesn't, connect it to a VCR and run the Wii through the VCR input.
Dec 25, 2008 | Nintendo Wii Console
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Dec 13, 2008 | Philips Magnavox DVD/VCR Dual Player
HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Nov 18, 2008 | Philips Magnavox DVD/VCR Dual Player
We are having trouble connecting our dvd player to our samsung tv.
couple of ways but the easiest way would be connecting the video and audio out from DVD need rca connections yellow red and white)
Yellow --- Video
white and red is audio out left and right.
find in your tv set inputs with similar colors its going to be input 1
or input 2 (as an example)
once you conect the cable matching colors yellow to yellow red to red and white to white make sure you select the same input on your set (video 1 or 2) that its throu input selection in remote control from tv or set itself.
Jul 04, 2008 | Samsung Televison & Video
TV ranking
Hi. You could look up reviews. I personally usually never offer advice on choices, because what I like, may not be what you like..its a matter of personal preference. But in this particular case, I'd go for Panasonic. Why? Better features, better service, easier availability of parts, and better resolution.Plus some nice features. If this answers your question, PLEASE don't forget to rate as fixed. I'd really appreciate it. Enjoy your new tube!!!
Jeff
May 12, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Bosch MON171CL 17 inch Monitor Logo
43 people viewed this question
Top Bosch Computers & Internet Experts
RudeRude
ray gallant
Brett Duxbury
Brett Duxbury
Are you a Bosch Computer and Internet Expert? Answer questions, earn points and help others
