Question about West Bend 41077 Just For Dinner¿ Bread Maker
The bread machine will not knead m I have made sure it is connected right and even started over with a new batch, it makes the nosie like it is trying to work but will not knead.
  • 433 Answers
Hi, A few things may cause this problem. Make sure the bread pan is inserted correctly in the machine. If ok, then take the bread pan out of the machine and see if you can turn the paddle by hand. It should turn nice and smooth, If it sticks or does not move then the sealed bearing that the paddle spins on has failed. If that's okay then keep the pan out of the machine and start a kneading cycle. Look through the lid window and see if the motor shaft is turning smoothly. If no then the belt is loose, broken, or has fallen off the pulley.. Good luck Hank
Posted on Jun 04, 2010
How can I get the machine to start the bread making process from the beginning. It is currently stuck on knead.
Do you have your owners manual and have you baked bread in your machine before? Just want to be sure that you know the stages that the machine goes through. The first mixing and kneading stage in a tr444 will take up to 15 minutes before it stops on its own. It will then let the dough rest for about 1/2 hour before the 2nd knead begins. It takes almost 4 hours for your machine to go through all the stages before your baked bread is finished.
Jan 15, 2015 | Breadman TR444 Bread Maker
Welbilt bread machine kneading wont start.making ticking sound
some bread machines warm the ingredients before any mixing starts. If your breamachine doesn't start mixing within 1/2 hour then you DO have a problem. Give it a half hour before you assume it is broken.
Dec 10, 2013 | Welbilt ABM3500 Bread Maker
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
My Toastmaster TBR2 bread machine does not knead when started. It makes a tick-tock noise and the timer counts down but no mixing. The bread pan is positioned correctly. Why?
Make sure you are programming your machine correctly.
The Instruction Manual indicates three possible problems, none of which would seem to be your problem. Not plugged in, error message or kneading blade missing.
Suggest you review the Instruction Manual for programming your bread maker. Unplug your machine to reset and then plug in and program as directed.
TRB2 Instruction Manual:
http://dl.owneriq.net/4/4ae504be-4834-4845-a8f8-7a6df62c1033.pdf
Jan 22, 2011 | Toastmaster TBR2 Bread Maker
Why did the kneading paddle on my 1148X bread machine quit working. This happened the third time it was used. It did the initial mixing and resting. When it started the kneading process again, the blade...
Hi, If this is the third time using it, it could be defective. Return it for service. If not under warranty, try a few things. 1) Make sure the pan is inserted in the machine correctly. 2) Make sure that the paddle is not sticking, or the sealed bearing on the bottom of the bread pan is not broken or frozen. (Take pan out and see if you can turn the paddle freely by hand). Or finally, the belt may be loose and slipping, especially when it takes more power to knead the dough the second time. Good luck...Hank
Jun 12, 2010 | Toastmaster 1148X FastBake Bread Maker
Bread is dense and lopsided. The right end (from the right kneading blade) is "normal" but the left side is half the size. Both kneading blades do spin during the kneading process, but the same result with...
Hi Dan B,
Sorry about your bread problems. It is depressing to me to find an unsatisfactory result after going through the whole baking rigamarole. I had a similar problem early on, but I live in the Denver area, so I was also dealing with the high altitude problems, too. I started using Vital Wheat Gluten in all my bread recipes, and it helped a lot. I use a tablespoon per cup of flour, but you may want to start with a half tablespoon. I also put the salt in with the liquid ingredients, because you're not supposed to let salt touch the yeast. I also make sure to use non-iodized salt, because the iodizing stuff does bad things to the yeast. The final thing I always do is to set the timer for 10 minutes after it starts the knead cycle, and then I open the lid and touch the dough to see if it is too wet (add flour by tablespoons) or too dry (add water by tablespoons), until it feels and looks right to me. You are probably already doing most of these things already, but I thought I'd mention them just in case. Anyway, hope one of these things helps. Happy Baking!
Mar 25, 2009 | Zojirushi BBCC-X20 Home Bakery Supreme...
Bread pan pops out during kneading, hard to remove after baking
I have Breadman Ultimate for over 12 years now. I make bread 2-3 times a week for the past 10 years. I found that the bread pan popping out only happens when the motor shaft and the kneading paddle are not tightly engaged. I find this problem in the following two scenarios: 1. The bread pan was not pushed down all the way as described by cassie_hobbs and tlcquiltnut. 2. Debris filled up the motor-shaft bowl underneath the bread pan to prevent a tight engagement of the motor shaft and the kneading paddle. These debris are generated during the kneading process; part of the ingredients is pushed out of the shallow horizontal pan and accumulated underneath. To avoid the problem, I have to periodically remove debris from the shaft bowl and make sure the pan pushed all the way down. To reduce the debris, I made a simple cover for the bread pan by cutting an old aluminum baking dish. I always remove the cover after the kneading cycle to prevent the rising dough from reaching the bottom of the cover. Hope this helps. Wendy
Feb 22, 2009 | Breadman TR2200C Ultimate Bread Maker
The machine stops kneading in the middle of the program
Even Replacement May Not Help for Long.
After my six month old CBK200 had the same stop and start malfunction I was sent a brand new replacement by the company. Three months later the new unit started doing the same thing. I am putting up with it for now, but as soon as I have a little more time, I will go back to the authorized repair depot and request another replacement and hope for the best.
Feb 17, 2009 | Cuisinart CBK-200 Bread Maker
TR440 Breadman won't begin kneading once "start" button is pushed
Hi Mindy.......it takes 30 minutes to PREHEAT this silly machine for wheat bread. I thought I did something wrong, too........I stopped it twice after it preheated for about 15 minutes. I did not want to waste anything so I let it stay in the machine.....I just went to check the machine and it started after 30 minutes of preheating.
I wish they would mention this in the book!!!
Julie from TX
Jan 11, 2009 | Breadman TR875 Bread Maker
West Bend 41077 Just For Dinner¿ Bread Maker Logo
226 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Oloyede Monsuru
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
