Question about Panasonic Televison & Video
Panasonic Plasma TH-42PX60U, got a power surge.
Panasonic Plasma TH-42PX60U, got a power surge.TV will power-up,dim lite screen,no viedo or audio.
  • earl mccain Jun 04, 2010
    Plasma TV got lighting from a storm,now ntv will power-up,haqs dim screen,no video no audio.Panasonic TH-42PX60U
  • Shahid Electronics
    Shahid Electronics Jun 30, 2010
    Rylee, if you have no idea about plasma tv then no need to answer that kind of question. Please stop answering tv and camera questions, chats etc. Stick with dish washers and cars etc.
  • Panasonic Master
  • 12,061 Answers
Www.warrantyweek.com/library/.../panasonic-th42px60u-manual.pdf Above is your user manual. http://www.eserviceinfo.com/downloadsm/39216/Panasonic_Th37-42px60u.html
Above is a multipart Service manual, please download. Below is a service manual, it's in Spansih, however there is an online Translation, to english This will help you zero in on the problem. http://www.scribd.com/doc/7581800/RCA-CTC-Chasis-175176177-TV-Training-Manual-Spanish
http://srvman.com/p8u8rouicth42p860urmrvicm28u58l-p-146.html
Above is a pay for service manual. These manuals will give you valuable understanding and information to assist you in deciding what to do.
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of only a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, Panasonic, in your case. Now,I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone
Posted on Jun 04, 2010
    Shahid Electronics Aug 27, 2010
    Silverdragon, what is the point in that long but useless techno bubble story? What you are trying to say for that particular tv problem?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa.These kind of issues in plasma usually happens due to bad cap on any of the boards inside. However, to check what has gone bad you’ll have to open the back of the unit
you’ll need to check bulged/swollen capacitors on power supply board. As the unit won’t show anything for a long time so it means that it is the power board which is causing this issue. These issues usually happens due to overheating in plasma TVs after sometime, as these sets are very hard working device and produces a lot of heat.Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
    The problem occured durring a lighting storm.A tree out side got hit and the TV will power-up ,have dim screen,no viedo or audio
  • Rylee Smith
    Rylee Smith Jun 04, 2010
    Lightning storm might have blow a part inside the unit.
I have a blicking red light and no picture ?
Possible power supply damage. Remove the power lead, wait 10minutes and try again.
Jun 26, 2014 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
Green tint in picture
Are the lines completely through the screen or just the upper or lower part of the screen? If through the whole picture, lines in the picture of a plasma can be caused by a defective Main Logic Control board or a bad plasma panel. The panel, if available would be very expensive (cheaper to buy a new TV). If the lines are just on the upper or lower part of the screen then it is the upper or lower scan drive board. Here is a list of the parts for your TV.
https://www.tristatemodule.com/t-Search.aspx?q=TH-42PX60U
Nov 04, 2013 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
Need service manual for Panasonic th-42px60u
Had this problem been solved?
Here is a link where you download the operating manual and other manuals that you need for this TV
http://www.generalmanual.com/Televisions/Panasonic-TH-42PX60U-Plasma-TV.htm
Jun 25, 2011 | Televison & Video
Panasonic plasma hdtv will not power on--no blinking LED, simply no LED. Other objects plugged into same surge protector are fine; no evidence or suggestion of a power surge.
The power supply board itself maybe the main problem inside the TV. Or, it maybe something simple like a blown fuse. Replacement fuses can be found at Radio Shack or some other electronic supply store.
If it turns out the TV keeps blowing fuses, the main power supply may need to be replaced. You can find replacements at a good price at Shopjimmy.com
Sep 12, 2009 | Panasonic TH-42PX60U Television
Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Mar 12, 2009 | Panasonic Televison & Video
No viedo from dvd on tv screen, only audio
What type of connection are you using when connecting the DVD to the TV? (Component, Svideo, etc) You might want to first try a different connection from the DVD to the TV. Let me know if that works. Could be a bad cable also or a bad connection.
Jul 14, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
462 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
