Question about Kenmore 62602 Electric Dryer
Dryer wont stay turned on. As soon a you let go of the start button it stops
  • Kenmore Master
  • 43,501 Answers
Hi, If you have a gas dryerdryer wont stay turned on. As soon a you let go of - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
dryer wont stay turned on. As soon a you let go of - 2_bing.gifour dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bingdryer wont stay turned on. As soon a you let go of - 2_bing.gifs= Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jun 05, 2010
  • dualelectric Apr 17, 2011
    Actually it seems the problem is in the start button itself, not anything described in that article. You'll have to take the top back panel off, and find where the power button is connected to the circuit. Make a note of what terminals the wires go to (if they're soldered in), or carefully pull the plug out of the back (if it's a jack-plug configuration). Then, pull the knob off the front side, and remove the rest of the switch from behind. Note: You may find that the housing of the switch is actually screwed in underneath the button. Installation is reverse of removal.
Old hotpoint gas dryer will not stay running starts when start button is pushed will stay running if button is held in but stops as soon as button is release
you have a bad push start button test it with a meter for continuity ohms should show ohms when pushed in and none when released
Oct 04, 2014 | Dryers
Kenmore elite dryer that wont stay on and wont heat...I push the button it runs let go it stops and it doesnt heat up even after holding the button down
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 19, 2011 | Kenmore Dryers
Kenmore Elite model #11060992990, has suddenly gone haywire. First, the on button won't stay on--the machine starts, but as soon as I let go the button, it stops. When I duct-taped it to stay on, it ran,...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 01, 2010 | Kenmore Dryers
Whirlpool ultimate care ii dryer will not stay on when start is pressed
if you push the start button an as soon as you let go of the start button your dry stop you need a new motor
Apr 24, 2010 | Whirlpool LER4634J Electric Dryer
Dryer will not stay on after pushing start button
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Dec 21, 2009 | Kenmore 63942 Dryer
Dryer won't stay on unless I hold the start button down. When I let go of the start button, it stops.
most likely the evenheat board is bad, but it could be the motor relay, get under the console and check the trouble shooting wiring diagram. there are several checks you can do to narrow it down.
May 24, 2009 | Dryers
Power working but won't stay on
sounds like u have a faulty start button. the switch isn't staying closed...
Feb 22, 2009 | Whirlpool LER4634J Electric Dryer
Ge dryer wont stay running
start switch is bad,it is stuck inside,get the model number inside dryer door or on top panel,call local appliance parts store to get new part,only a few bucs,replace and you should be allright,let me know-mike
Jun 15, 2008 | GE DBSR453EBWW Electric Dryer
My kenmore dryer turns on but wont stay on. I made sure the door was not loose and it was on the time dry. Can you tell me how to trouble shoot this?
If this is a problem that when you push the start button the unit runs, but as soon as you release the button the unit stops, then I have personally experienced this. It's a problem associated with the microcomputer board inside the control panel. You will need to unplug the dryer first. Then open the control panel and inspect the circuit board for burned components.
May 06, 2007 | Kenmore 64982 Electric Dryer
Kenmore 62602 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
