Question about GE WPGT9360E Profile Harmony 4.0 cu. ft. Washer with Stainless Steel Basket
Will not drain
The washer will not drain motor is running but does not open to drain
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasherwill not drain - 2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jun 04, 2010
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
SUDsamsung washer error codes
• dc--Unbalanced load preventing washer from spinning
• dL--Door is in locked when washer is running
• dS(d5)--Door is open when washer is open
• FL--Washer failed to lock the door
• Hr--Water temperature control problem(Heat control problem)
• LE--Washer tried to fill but has not reached proper water level(Slow fill)
• LO--Door will not unlock
• E3--Motor not running properly
• nd--Washer is not draining/Washer senses a brief restriction while draining
• nF--Washer tried to fill but was unsuccessful
• Sr(5r)--Problem with control
• PF--Power failure, electric service was lost while washer running
• OE--Fault detected in water level sensor
• E2--Jammed key
• bE--Motor speed sensor problem
• tE--Temperature sensor problem
• 3E--High current detected
• 2E--High/low voltage detected
• 8E--Vibration sensor problem
• 7E--Silver Care control problem
• SUdS--Too much suds detected during wash cycle, unit on hold until suds reduced
Nov 12, 2013 | Washing Machines
My washing machine will not drain...
Good Morning, Cindeyellis88:
3 weeks is a long time without a washer. Is the washer not draining for all cycles? Will it spin and not drain, or not spin AND not drain? Can you hear the motor running?
If the motor is running, and the machine will spin but not drain, you will need to open the machine and clear the hoses to and from the pump. There are YouTube videos showing how to open the machine safely.
If the pump is clogged, the problem may extend up to the tub. This happens when socks and small items go overboard.
Good Luck.
ChrMacKenzie
May 20, 2011 | Kenmore 22422 Top Load Washer
I have a bosch washer machine which has got a bras wire stuck in the drum i think.When i run the washer now water is coming out from under the machine.
possibility of such a bra wire stuck in the drain valve or drain hose, you can check, ranging from filter sewage water to the drain valve (with drain motor). you should open the drain valve / motor assembly. wire bra might clog there. so that the rubber water valve does not close properly
Aug 05, 2010 | Bosch Washing Machines
Calypso Washer stopped working
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*@#$&
Jul 18, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My Kenmore calypso washer (older model is giving me the Ob and SL flashing signal. The washer stops right before the last drain and spin. Any ideas?
Jan 16, 2010 | Kenmore Elite 45986 Front Load Washer
Code Ld and sometimes Ob water doesn't seem to drain properly
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*@&^$
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer motor runs. washer drains. washer still
The spin-tube assembly needs to be replaced.
This is one of those jobs to call-in the repair professional for.
Sep 07, 2009 | Kenmore Washing Machines
The washer stopped running and draining "OB"
Jul 09, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer will not drain or spin motor making clicking noise
Likely has debris in the filter.
Open the bottom access panel (3 screw on bottom front lip)
open the filter access and be ready for some water spill ,have towels.
clean and check the pump impellers for freedom of movement.
if you still have noise after this you may have to go deeper past the pump and remove the hoses as the debris can be past the pump now.
Or take the machine outside and run water up the pump using a water hose to clear it. be inventive
Oct 26, 2007 | Whirlpool GHW9100L Front Load Washer
GE WPGT9360E Profile Harmony 4.0 cu. ft. Washer with Stainless Steel Basket Logo
261 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
