Question about NEC Mitsubishi Diamond Plus 200 (White) 22 in.CRT Conventional Monitor
Unplugged the monitor to move it and it went into power save mode. Keeps going into power save mode
  • 11,361 Answers
All the pins are OK on the VGA cable?
Posted on Jun 04, 2010
Have a Dell E228WFP monitor keeps going into power save mode.
does it go into power save mode with your actually doing something. Like for instance if your typing does it go into power save mode? If its going into power save mode when your not doing anything on it then its as simple as a setting either on the monitor itself or in the power settings within your computer accessible by the control panel and screensaver
Jul 22, 2012 | Dell E228WFP LCD Monitor
Monitor went into power save mode and would not come back on
If your monitor is stuck in power save mode then first of all check all the power cables connected to monitor and your CPU.
After checking the connectors start the monitor if it does not come back from power save mode then lets move towards to second step.
2 . First unplug all the power cables to avoid power shock. After unplugging the power cables open the cabinet and look for the video card on *********** board.
Take the video card out and clean it with a normal eraser.Rub it on the golden pins and clean it.
Place it again at its place.
Close the cabinet and then start your monitor and your problem will be fixed.
Thanks for using Fixya.
Nov 13, 2010 | Computers & Internet
The monitor keeps going into auto power save and remains black. Have turned off and on, unplugged, waited and plugged back in. Have unplugged from computor and plugged back in. Will not get off of power...
It more likely went into shutdown, but try it on another PC first, if it still does not work, then read below:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 04, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Power saving mode
Prevent the laptop/desktop monitor from going to power saving mode:
  • Click on Start | Control Panel | Power Options.
  • In the Power Option properties window, click on the Power Schemes Tab
  • Set the Turn off Monitor/ Turn off Hard Disks option when on Power (and also Battery for laptop users) to Never.
  • Now click on the Save as... button and assign a name to this power scheme... Let us call it 'Presentation' and then click on OK.
  • That's it congrats!
  • Aug 04, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
    Unplugged monitor at one location and moved to a different location and the monitor will not work..... Tried a different monitor into the same PC and it worked fine. Viewsonic continues to go into power...
    Sounds to me that it's a resolution problem. I think that the previous monitor that was hooked up to it last had a different resolution.
    That or try restarting, it may need to install a driver.
    Jul 10, 2009 | ViewSonic G810 21" SuperClear CRT Monitor
    Unable to get monitor out of power save mode
    turn your moniter off waite 30sec back on this should get your screen on. Try this Rigth click on your desk'top >properties
    >screen saver, click Power then change the turn of monitor tab
    Jan 24, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
    Monitor
    I think your resolution is set too high reduce it in safe mode
    Sep 02, 2008 | Dell E153FP 15" LCD Monitor
    Monitor in Power Save Mode
    The inverter power logic is probably going bad. You can get it here as well as look at instructional videos on DELL monitors.
    http://www.lcdrepair.us/e176FPf-inverter-power-logic.html
    May 04, 2008 | Dell E176FP 17" LCD Monitor
    Monitor keeps going to power save mode
    the settings should be the same as your notebook power saver settings or you will have to check extended monitor in your graphics card properties in control panel.
    Sep 26, 2007 | Toshiba (K000006610) for Satellite P25...
    Monitor
    -Turn off both computer and monitor
    -unplug monitor from computer(still plugged into power supply)
    -turn on computer and monitor(monitor is still unplugged)
    -After computer is on for about 30 sec. plug monitor into computer
    -turn off both monitor and computer(now connected together)
    -turn on monitor then computer and should be good to go!!!
    Mar 25, 2007 | Sony CPD E230 17" CRT Monitor
    NEC Mitsubishi Diamond Plus 200 (White) 22 in.CRT Conventional Monitor Logo
    121 people viewed this question
    Top NEC Computers & Internet Experts
    Steven Wander
    Steven Wander
    Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
