Question about Ruud Central System Air Conditioner
Central air :no cold air
Central air was fine for the past month now it is not blowing cold air unit goes on but just blows air i put in a new air filter but still the same problem
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jun 04, 2010
Central air conditioning system is blowing warm air.
many, many. Is the outside unit running? If it is, is the compressor running? Feel the refrigerant lines leaving the unit. Little one should be warm. Big one should be cold, probably sweating.
Jul 08, 2010 | Ruud UAPA042 Air Conditioner
The last time i used my ac here in las vegas nv. was july 2009 and it was freezing. i terned it on to check to see if it still blew cold and it dosnt. blows air fine but dosnt get cold, is there a re-set...
central air or window unit? central systems use a low/high pressure limit switches which self reset when pressures are nominal. suction about 50-60, high pressures around 300.
Oct 20, 2009 | Heating & Cooling
Tempstar High efficiency 5000 It is not blowing enough cold air
if the unit has cooled fine in the past then it is most likely dirty you need to look at the return side of coil,you may be able to look thur your return grill.if it is dirty it is best to call a a/c service company to clean it for you,what ever you do,Do Not clean with a brush it can damage the coil and cost a lot to replace.also check your suction line at outside unit,it the big line it should be sweating if not it can be low of freon. Average cost to pull and clean a coil is about 375.00 no more then that.
Aug 12, 2009 | Ruud Central System Air Conditioner
Central air system blows cool air not cold and
your indoor unit is only circulating the air in the house. for your condensing unit. check your breaker in the electric panel. your contactor or your capacitor.
Aug 09, 2009 | Carrier Heating & Cooling
Central air/heat pump not putting out cold air
I have some things for you to check. If you look at the outside unit the lines going into the house. Are they frozen? Have you had any yard work done, the reason I ask is they could have accidentally cut or pulled out the thermostat wires to the ac unit. Also, inside check for the same thing, frozen lines. Also, you may want to check the drain coming from the inside unit, it may be clogged.
Jun 22, 2009 | Heating & Cooling
2003 Air Conditioner not blowing cold air
If it goes down again,take it back to the mechanic.He will shine the system with a uv light to enhance the dye and find the leak..Good Luck!!!
Aug 06, 2008 | 2003 Hyundai Santa Fe
Ruud Central System Air Conditioner Logo
570 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
