Question about Samsung AW0501M Air Conditioner
Airconditioner won't cool room off.
My husband took the aircond. apart and I cleaned it from top to bottom inside and out.He put it back together and it still doesn't cool room.
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Jun 04, 2010
    How large is the room,and how many btu`s is the unit,and is it a 220 volt,or 110 unit?
  • 6,826 Answers
The unit,has it cooled the room before?Check the evaporator coil,the one inside the house,where the filter goes,put your hand on the coils gently,and place it all around and feel if the coil is cold,and is it cold all over,if it is not getting cold,all over the front of the coil,then it most likely needs freon.
Posted on Jun 04, 2010
I dropped the feed dogs and they won't come back up.
Ignore all the other comments, they are wrong.
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
Aug 28, 2012 | Brother PC-420
I took my desktop apart and put it back together and now it won turn on
Open it back up and check to make sure you didn't accidentally pull one of the cables out.
Jun 30, 2012 | Dell Computers & Internet
I took the bladeoff to oil and now can't remember how to get it back together.
i needed to replace my blade - my husband replaced it but it would not cut so we took it apart and cant figure out how to put it back together. nothing helpful on line.
did anyone have a link how to put all the pieces back together to create the blade? thanks
Jan 16, 2011 | Oster 76076-010 Hair Trimmer
Filter
If this one is like mine (and it looks just like it except my Lasko doesn't have the wood grain on the front) there is no filter inside. It is just a fan inside a plastic case.
If you want to clean it, you can try blowing it out with compressed air if you have a powerful enough compressor. If you really want to clean it, you will have to take it apart and that isn't as simple as it sounds if your unit is just like mine.
There are a bunch of screws on the back, which isn't too bad except one of them is a triangle headed "security screw" that is probably there to keep you from taking it apart. I looked at several stores and couldn't find a screwdriver to fit the stupid thing. So what I did was that I took out the rest of the screws, pried the case open as far as I could with my hands and cut the support that the last screw was attached to from inside with a strong pair of wire cutters.
I figured that when I put it back together, I wouldn't miss that one screw and I wouldn't want to deal with a triangle head screw every time I took it apart in the future anyway.
Once the case is apart, I found the best way to clean the blades is to remove the whole blade assembly and just wash the thing out in the tub and let it dry thoroughly before putting it back in. There's a metal brace (Held on by two screws) at the top the top spindle goes into and there's a single screw on the shaft of the motor that hold the bottom spindle in. It probably sounds more complicated than it is. It's pretty simple when you see it.
If you put it back together right, you almost can't do anything wrong. You might want to take a damp cloth and wipe down the interior of the case and the shrouds that surround the blades as well. If you've had it a while, they'll be dirty. You'll see/feel the dirt wherever it is. This thing is a pretty simple machine and is easy to clean once you figure it out. I put a few drops of oil on the top spindle when I put mine back together.
May 21, 2010 | Lasko 2554 WIND CURVE Fan
Reset button or Fuse on my Infinity?
Ok, I took it apart, cleared the clog out, and put it back together. It wouldn't switch to "carpet". Got no answer on my question. Took it apart again, only I went further. Took apart the bottom - brush out, all inside bottom parts out, cleaned all that part of vac. No clogs down there. Ran the carpet/bare floor switch back and forth several times while I had it apart. Put it all back together and it worked fine. Still didn't find a fuse or reset button...
Jan 09, 2010 | Vacuums
Can't get my bassinet to stay up
1. hook/snap the loose arms into the bottom of the bassinet 2. slip hooked end through a small **** in the fabric on top side where the round metal tubing. 3. feel with fingers for the small hole in the tubing on the inside and fit the hook into there
... stupid design... took me hours to figure it out
Nov 02, 2009 | Dream On Me Dream Bassinet
I took the mouse apart and I can't put it back
Make sure the circuit board and wires are all in place correctly so they aren't preventing the case from snapping/connecting back together.
Most of the time, it's just a small piece of wire or something that is getting in the way and preventing you from closing it back up.
Devices are made so small these days that they don't leave much room in them for loose wires and all.
I hope this helps :)
Best Regards,
James Trageser
Jul 29, 2009 | Logitech Labtec Wireless Laser Mouse
Unit only works upside down!
there is a water level next to the ocilater make sure that the canal is clean. try some water and vinegar
Apr 07, 2009 | Venta VS 100 Humidifier
440 Aprilaire Humitifier small solinoid doesn't open
Make shure that the the filter in the bottom of the valve is clean. Turn water off use a 1/2 & 7/16 wrench to take apart the bottom connection on valve use a small screwdriver and push the small screen out and clean then put it back together.Use the same wrenches and take apart the top of valve clean inside valve and clean small orfice in plastic water line put back together. Make shure 24volts is gettin to valve you should her a click when furnace is running or fan. It may take a couple times to clean. Hope this helps
Jan 11, 2009 | Aprilaire 600 Humidifier
Ps2 not working
He forgot to plug up the power cord inside.
Nov 18, 2007 | Sony PlayStation 2 (PS2) Console
Samsung AW0501M Air Conditioner Logo
162 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
