Question about Kenmore Dryers
Kenmore Elite electric dryer (king sized 9 cycles)
I have an electric Kenmore Elite king size 9 cycle dryer with Total care system with the even heat system. The dryer was making a high pitched sound. Then it stopped working. I unplugged it and waited and then plugged it in again. When it came back up the PF light was on and I pushed a few buttons and it started working again. Then a few weeks later it happened again. However, this time, there was no loud pitched noise. Now it is not working. Is there something that I can do to fix it myself?
watugot
  • 290 Answers
SOURCE: kenmore agitates doenst spin
There are 3 things that may be wrong.
The timer is keeping the transmission in neutral drain.
The clutch is slipping.
The basket drive block that supports the basket has failed.
Aimiel is correct that you will need to see what is happening during the spin to diagnose the problem. Please post the complete model number from the top under the lid and I will try to walk you through checking it.
Thanks/Mike
Posted on Dec 23, 2007
  • 2122 Answers
SOURCE: Dryer doesn't work when I want it to
do you mean you changed out the dryer and the same thing is happening?if so it's not the dryer,either your vent line is clogged with lint and the dryer is cutting out from over heating and coming back on when it cools down or you have an electrical problem because there is no way your gonna have that same problem on two dryers,try running it with the vent line removed from the back of the dryer let me know about this
Posted on Nov 04, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Kenmore Elite
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 29, 2010
richroth
  • 9472 Answers
SOURCE: Kenmore Elite Heavy Duty King size capacity Quiet Pak 1 dryer doesn't turn on
Check to see if the door switch is working. When you push and release it, it should click. If not, it will need to be replaced.
If the switch is good, then the only other component that would cause that problem is the thermal fuse. If you could post your model number I could direct you to the part you need.
Posted on Oct 16, 2012
Door wont lock, cycle doesn't start
interlock could be knackerd...................cheers
Jan 22, 2014 | Kenmore HE3t Steam 4.0 cu. ft. Front-Load...
Kenmore agitates doenst spin
You will have to look at the inside of the washer when in spin cycle to see what is going on. Is the spinner motor not engaging the drum? Is the spinner working at all? It sounds like the spinner isn't being moved against the drum before the spin cycle starts. Most washers use a seperate spinner motor, which is lifted off the drum by a relay and / or solenoid and if one or more of those is malfunctioning, it will cause your described problem.
Dec 22, 2007 | Kenmore Elite HE4 Electric Dryer
I have a kenmore elite total care flex king size capacity plus quiet pak2 oasis that makes loud noises like a airplane when its in the spin cycle Model #110.28032701 which parts should be change?
If the washer is roaring during spin, the bearings are bad and you will need to replace the outer tub assembly.
Here is the part to order.
The part comes with a 365 day, any part, any reason return.
Nov 03, 2012 | Kenmore Washing Machines
I have a Kenmore Elite Heavy Duty King Size Capacity quiet pak 1 that is not heating up what could the problem be?
Jan 13, 2011 | Kenmore Dryers
Kenmore elite he4 quiet pak 9 dryer display code
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Nov 04, 2009 | Kenmore Dryers
Kenmore elite dryer shuts off mid cycle.
My Kenmore Total Care dryer (with even heat) shuts off during drying cycle with the dryer displaying a "E 1" error message. What is this?
Aug 09, 2009 | Kenmore 63942 Dryer
Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer shuts off
If the venting is clogged this will happen. And that is a good thing because it is a safety measure built in to prevent fires. There is a thermostat that can tell when your dryer is over-heating,(usually caused by clogged venting by lint) and this devise tells the heating element to turn off so as not to create a fire. Clean out venting, inspect thermostats and element, replace if neccesary. You may only have to clean out the venting.
Nov 27, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
100 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
