Question about Seagate (ST3320820U2-RK) 320 GB USB 2.0 Hard Drive
I can not add any folders or delete anything off of my free agent
No matter what I do or try I can't delete, add, or organize any files on y free agent. I'm at a died end and I really need to save a lot of information and files to it. I'm a college student. I need a new start.
  • 33 Answers
If this is a emoty drive formatit by rigth clicking on it in mycomputer
Posted on Jun 04, 2010
It gives error that your hard drive have 1mb free space
1. Go in control panel Add or remove programs or programs and features then uninstall the programs that you don't use or havn't used in a long time.
2. Go in control panel Folder options view tab at the top. Look for Hidden files and folders put a tic in show hidden files and folders.
Go in My Computer/Computer Click on the c drive then windows folder delete the update folders that have a $ infront of the name of the folders. Go back to Folder Options/View tab at the top. Hidden files and folders put a tic in Do not show hidden files and folders.
3. Right click on Rec bin choose empty rec bin.
4. Go in control panel / Internet Options clcik on settings next to the first delete button from the top then click on view files. On the upper roght clcik on edit/Organize choose select all. Then hit your delete key on your folder yes to conferm. Click on ok then in the next window click on delete button next the settings button you clicked on before.
5. Open notepad type del %temp% /q then save the file to your desktop name it Del.bat cloce everything out and double click the del file on your desktop.
6. Open the run command Hold the windows key down (left of the space bar on your keyboard) Press the r key. Type in %temp% Delete all the files and folders you can in that folder.
7. Right click on Rec bin choose empty rec bin.
If it still says low disk space I suggest saving your personal files and reinstall your oem system disk or add a second disk drive.
Terry
Apr 03, 2014 | Computers & Internet
Tip
Organizing Files and Folders for Easier Scanning
You should organize the files and folders, as this makes scanning easier. To do this,
  • Slide the USB switch and connect it to the computer via the USB port (Make sure "USB Connected" appears on your computer monitor and if not, double click the "Media Studio" icon on the desktop.).
  • Click the music note icon and a music display list will pop up.
  • Click "Add Folder" under "Media Studio" and the "Open Folder" window will pop up.
  • Select the folder you want ot add and click "OK" (the files of the folder selected are added to a list on the left side of the "Media Studio" screen.
  • If you want to add a file, click Add File" under "Media Studio" and the "Open" window will appear.
  • Select the files you want to add and click "Open" and the files are added to a list located at the left side of the "Media Studio" screen.
on Oct 01, 2010 | Samsung YP-U3 MP3 Player
Tip
Error "the application is being terminated because of memory corruption"
When you exit Acrobat 7, Acrobat returns the error message,"the application is being terminated because of memory corruption."
Solutions
Do one of the following solutions:
Solution 1: Install the Acrobat 7.0.8 update.
If you have Acrobat 7.0, choose Help > Check For Updates Now to install the update. Alternately, you can download the update from the Adobe website at www.adobe.com/downloads/ .
Solution 2: Remove the files from theAcrobat Organizer folder.
When you remove files from the Acrobat Organizer folder, you force Acrobat to rebuild the Organizer database. This process replaces any damaged files in the Organizer that may be causing the error message.
To remove the files from the Acrobat Organizer folder:
1.Choose Start > Run.
2.In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Organizer70.
3.Delete or move all filesfrom this directory.
Solution3: Remove the files from the Updaterfolder.
You may receive this error message after a failed update, indicating that the files in the Updater folder are corrupted.
To remove the files from the Updater folder:
1. Choose Start > Run.
2. In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Updater.
3. Delete or move all the files fromthis directory.
on Mar 20, 2010 | Adobe Acrobat 7.0 Professional
"Not enough free space"
If you delete files on a MAC they are still there. Go to Options or Utilities folder (depending on which OS is running). Use the clean utility to clear the dead files.
Mar 04, 2014 | Philips GoGear Ariaz MP3 Player
Currently my 500 GB WD External Drive has 353GB as free space. But when I try and add a 6GB file I get the following message "Error Copying File or Folder Cannot copy filename: There is not enough free...
How many directory deep is the file going that you are trying to save? I believe the maximum NTFS file (location + name) of file length can not exceed 256 characters total.
Example: C:\user\documents\file.exe is OK
But: C:\user\documents\folder\folder\folder\folder\folder\this folder name 230 charicters long\file.exe BAD
Feb 05, 2010 | Western Digital My Book Essential Edition...
Itunes messed up my external hardrive
I doubt that iTunes really moved/reorganized files on your computer.
iTunest may have created its own "Table Of Contents", presenting a "view" of all your files.
Open "My Computer" and open your external hard-drive.
The files should be in "your" order.
Open "My Documents". Open "My Music".
If iTunes really did "reorganize" your files, there's no way to "go back", because "Windows System Restore" does not automatically created time-stamped backups of your 'My Documents' folder (nor of any external disk-drive -- where would it put that much data???).
Jan 02, 2010 | Seagate Free Agent Go Small 12 GB USB...
It says that free memory is about 1.5 mb and the
To organize your messages, you can move some of them to the Saved items folder, or add new folders for your
messages. While reading a message, select Options.
To add or delete a folder, select Menu > Messages > Saved items > Text messages, and My folders. To delete a
folder, scroll to the folder, select Options > Delete folder.
Let me know if this helps
Nov 26, 2009 | Nokia 6030 Cellular Phone
Good day. When i save files or create new folder or add some softwares to my computer and i restart my computer i want to delete all that files, created new folder, or softwares that i added so that it...
1. try scan all you HDD by anti virus with many type free edition anti virus may be you pc effect by virus.
2. can you remember last time you do what like install any special program try uninstall this program the restart pc see will be ok???
3.if solution 1.virus is too effected you os better format,if after scan no anything virus found i think is you OS got problem better you do format & reinstall you OS AGAIN
Jan 18, 2009 | Computers & Internet
Unable to delete files through PC
try to open new session with an administrator count
Jun 03, 2017 | Toshiba Gigabeat MEG-F20K (20 GB) MP3...
Removing Sygate Security Agent 3.0 for laptop program
You can remove it manually by deleting it from the registry.
click start
run
type: regedit
enter
under edit
click "find"
type: " sygate security agent"
delete all about the agent.
Jan 02, 2008 | Computers & Internet
Seagate (ST3320820U2-RK) 320 GB USB 2.0 Hard Drive Logo
75 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
