Question about Dell Computers & Internet
I have a dell inspiron 2650 i was having hard drive issues so i changerd it now it beeps 8 times the ppower led and fan go on, the lcd scree n stays black and the hard drive diodent start up i tried to reinstall the old hdd with same results aby body out there help me
    Problem Solver:
  • 17 Answers
Hope this helps:
http://www.bioscentral.com/postcodes/dellbios.htm
Posted on Jun 04, 2010
Gray white screen.. Can't hear or feel hard drive or fan
It is unfortunate that the Dell Inspiron 1440 has a Gray white screen. Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the same issue then I would suggest you to try connecting a known good external LCD screen and check if that helps.
    Also check if there are any beep codes from the computer, how the power button light behaves and the system LEDs (located along the front edge of the system next to the media card reader).
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Jun 21, 2014 | Dell Inspiron Laptop 1440
Dell inspiron 15 beeps 7 times
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Oct 23, 2012 | Dell Inspiron 15 Laptop Computer- Intel...
Dell Inspiron 2650 will not boot to Windows install CD after UBUNTU Linux installed on machine.
have you went onto the BIOS to make sure that the boot options are correct e.g. CD DRIVE 1st priority?
Aug 06, 2012 | Dell Inspiron 2650 Notebook
My Dell Inspiron 2650 screen goes black after start up. It is still working, its just a black screen. I can close the lid, re-open it, and it will stay on for about 5 seconds. Whats the problem, and how...
This problem is caused by a bad inverter. You can find one on Ebay for a decent price. That's where I get most of mine from $8 to $20. Your inverter is located on the bottom front area of your LCD just under the plastic, and it is very easy to replace.
Here is a step by Step Video to help you with most common Dell screens (Copy and paste in your address bar)
http://www.youtube.com/watch?v=l_FtMr_40-w
Here is a list of the most recent prices and sellers:
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+2650+inverter&_sacat=See-All-Categories
Mar 10, 2010 | Dell Inspiron 2650 Notebook
Dell Inspiron 530 won't start up - is motherboard dead?
From your description, I agree with you assessment of a likely Motherboard failure.
Mar 09, 2010 | Computers & Internet
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
Does not reconize hard drive
turn off the laptop and then take out the hard drive from the laptop. Go ahead and reseat it back into its slot and then turn on the laptop and press F2 to go into the BIOS. It should see it in there. If it doesn't then you know the hard drive is bad and will need to be replaced.
May 18, 2009 | Dell Inspiron 2650 Notebook
Dell inspirion 2650 does not for mat hard drive it
you might have to Debug and then format the hard drive heres the link for debuging the harddrive and then try to format..hope this helps.
http://en.community.dell.com/forums/t/19020652.aspx?c=uk&l=en&cs=ukdhs1&s=dhs
Regards,
Khushroo
Mar 09, 2009 | Dell Inspiron 2650 Notebook
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell inspiron 2650 start-up problem
Mine did the same thing only I don't think it was even checking the hard drive and I found an entry in the DELL owners manual troubleshooting section that said if you powe rit up and the power light stays on but nothing appears on the screen, tyr removing and reinstalling BOTH memory modules and reinstalling them to insure that ey wer making contact.
Mine worked perfectly after I removed both memory modules and reinstalling them.
Be aware though that one of the modules require the removal of the keyboard to access it so it isn't really something that everyone should try on their own.
Don Jones
Dec 05, 2008 | Dell Inspiron 2650 Notebook
Computers & Internet Logo
52 people viewed this question
Alun Cox
