Question about Sony TA-FE370 2-Channel Amplifier
Wire for st-jx285 tuner and a integrated amp. ta ax285
On back of tuner igot conn. 2 i ned conn1 wires
  • gjdemp Apr 09, 2008
    wiring for these coponets
I too have the same system. STJX285 however I only have the #1 cable and need the #2 cable. the system I have is complete including the cd player and dual cassette deck. You would not happen to be willing to part with your #2 cable would you? you can contact me at frankgamboa@msn.com
Posted on Apr 30, 2010
  • 54 Answers
Need MORE details possibly in english and better typing
BIGRED
Posted on Apr 11, 2008
I need to know how to hook up Sony amplifier ta-ax 295,Sony tuner st-jx 295, sony cassette tc-w295 with a RCA 5 disc CD player and a Samsung DVD/ video CD/CD player in stereo. It always worked when my...
There are a number of amplifiers in the TA series, but the connections are basically the same.
In your system, the amplifier serves as master control. How do you know? Look for the component that offers input selection -tuner, cassette, CD, video, phono and probably auxiliary. Every other component plugs into and is controlled by the integrated amplifier. For example, plug the tuner wires from the tuner output to the amplifier input marked "Tuner." To use the tuner, just select that input from the front panel. Same with all the other components.
On the back of that unit will a bunch of RCA jacks for left and right channels. Take the hook-up wires, usually RCA cables with colored plugs on each end, and connect the OUTPUT jacks on each separate component to the INPUT jacks on the amp. Power may also be controlled from the amp. On audio plugs, red is right and white is left. Keep the polarity constant as you connect each component. Connect the speaker wires to the speaker outputs, usually spring clips or screw terminals on the amplifier end and the same on each speaker. The DVD video cable will have three wires: Yellow, red and white. Yellow is always video. It may also have a little round video connector for S-VHS which provides a much better picture when using DVD.
Select your desired input and enjoy the show. Service Manual free download schematics datasheets eeprom bins pcb...
Jul 13, 2014 | Audio Players & Recorders
No sound from sony ta-ax285 amp
Try plunging it in and turn it on. Check your input.
What is the question? More information is needed before somebody can help you.
Jun 03, 2014 | Sony Audio Players & Recorders
Need connecting wiring for sony am/fm jx 285 connecting to the sony stereo amp ta-ax 285
If you are trying to connect a ribbon cable tuner to a conventional RCA input terminal amplifier, it won't work because the ribbon cable carries the signal output as well as the data for frequency synthesis which is determined by the processor located in the amplifier ( that is supposed to work with that type of tuner), and the data buss for the buttons on the front of the tuner.
For the time and effort to put into a workaround, it is cheaper by far to get a tuner that will work with your amp. If cosmetics are not an issue, brand of tuner will not matter as their outputs are "Line Level" or nominally 1 volt peak to peak..
Oct 27, 2012 | Sony TA-FE370 2-Channel Amplifier
I have a Sony Amplifier [model TA-AX380] and other components of CD player [model DCP-C40], AM/FM Tuner [model ST-JX380], FM Stereo/FM-AM Receiver [model STR-AV570X], and Stereo Cassette Deck [model...
http://www.servicemanuals.net/ServiceManual/SONY/TAAX380/148547/detail.aspx
http://www.hifiengine.com/manuals/sony/str-av570x.shtml
Hi above are links for manuals, these may help..
When one wires up anything it is all usually color to color output to input... usually RED & WHITE stereo audio.
Now we would start with our Tuner this the CD player, & Cassette deck, will wire into the Amp's INPUTs , red - red & white - white, these go into the Stereo INPUTs on the AMP... 1, 2 & 3 and be selected via the input selector on the AMP.
Now after all these in's and out's are wired we need to wire our speakers, this too is simple, locate the outputs on the Amp, and wire accordingly, Plus to Plus and Negative to Negative... each speaker has two wires a Plus, + & a Negative -
All will/should be clearly marked and it will be easy to do. You will need patch leads, one set each for each unit, these will be a pair of cables, usually Red & White with RCA jacks on each end, as related these go color to color from the RCA OUTPUTs Sockets, of the signal suppliers, ie: Tuner, FM stereo & Cassette deck... these ALL will wire into the Main Amplifiers INPUTS, usually at rear of unit, and clearly marked, after this is all done, then as related again now connect the Speakers, again the OUTPUT on the Amp will be clearly marked, as output and + & -, + & - (two sets), one for each channel.
Now each INPUT is selected ON the AMP, and it's output will then be directed to the speakers attached to the Amp..... Just wire and test one at a time, and i am sure you will prevail.
Hope this helps.
Jun 20, 2011 | Sony Audio Players & Recorders
Cant get remote wire to turn on amp. it is running from back of kenwood deck to kenwood amp.
OK ! FIRST THINGS FIRST. DID U TEST THE AMP FIST. BEFORE U STARTED INSTALLING RCA CABLES,AND REMOTE WIRES. LETS DO THAT FIRST.GRAB YOUR AMP.SET IT ON YOU WORK BENCH ,TABLE,OR CHAIR.THEN GET (2)PIEACES OF #10 OR #12 WIRE W/1 OF THE WIRES HAVING A 20AMP FUSEABLE LINK ON IT.NOW THE WIRE W/THE FUSEABLE LINK ON IT.CONN THE REMOTE(REM) AND THE 12v + ON THE AMP AND HOOK THEM BOTH TOGETHER ON 1 SIDE OF THAT FUSEABLE LINK WIRE. AND THE OTHER WIRE HOOK IT UP THE - GROUND SIDE OF THE AMP .NOW PICK UP YOUR AMP OPEN UP YOUR HOOD.MAKING SURE THAT NO WIRES OR THE AMP IS TOUCHING THE + 12V OF THE BATTERY. NOW CONN YOUR GROUND TO GROUND AND THE FUSEABLE LINK ON THE +12v SIDE OF THE BATTERY.NOW THE AMP SHOULD HAVE CAME ON. LOOK 4 A SOLID RED LIGHT OR ANY SIGNS OF A SOLID LIGHT THAT HAD CAME ON.
Feb 21, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
Need connecting wiring for Sony ampilfier and tuner
FM-TUNER out connect into tuner in your amplifier
Jul 06, 2009 | Audio Players & Recorders
HOW TO WIRE AN EQUALIZER TO A SONY TA-FE370 AMP
You can't wire an equalizer to this amp unless you only want to equalize one source, because it doesn't have a tape monitor function.
Jan 22, 2009 | Sony TA-FE370 2-Channel Amplifier
Display / Clock display not working
SONY MHC-EX50
Het is al een paar weken verder, maar ik ben eruit: C161 en C162 (100uF/35V) in de voeding zijn slecht.
wel 105 graden elco's gebruiken en hoger dan 35 volt, liefst 100v
et gaat dus om een VFD (Vacuum Fluorescent Display) die geen gloeispanning krijgt. Het vervangen van C161 en C162 lost het probleem helemaal op.
Radio: ST-EX100
Amp: TA-EX50
Symptome=Tuner-Display zeigt nichts an, sonst Tuner OK.
Defekt=C161 und C162 (100µF,35 V) auf der Tunerplatine ersetzen.
Wenn bei dem Sony-Tuner RDS EON ST-EX100 (z.B. zu der Anlage Sony MHC-EX5, aber auch MHC-EX 70) pünktlich eine Woche nach Ende der Garantiezeit die Beleuchtung im Display wegfällt und man deshalb leider keine Sender mehr programmieren kann, dann handelt es sich vermutlich um eine fiese Soll-Bruchstelle.
Auf der Platine des Tuners sind zwei Kondensatoren zu schwach ausgelegt und gehen zwangsweise früher oder später kaputt. Die Reparatur ist ganz einfach. Man kauft zwei neue Kondensatoren (100µF,35 V) - kosten nur ein paar Cent! - und besorgt sich einen Lötkolben. Dann schraubt man den Tuner auf, entfernt auf der Platine die Kondensatoren C161 und C162 (die sind namentlich gekennzeichnet) und ersetzt sie durch die neuen.
Nov 12, 2008 | Sony ICF-2010 AM/FM/SW Radio
Sony Stereo System
Your in luck there is a user guide online that has all you need to know.Here is the link
Jul 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
REAR CONNECTION
You can make your own or find someone who can. I hope this helps.085fcaf.jpg
Apr 09, 2008 | Audio Players & Recorders
Sony TA-FE370 2-Channel Amplifier Logo
924 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
