Question about Maytag MSD2756G Side by Side Refrigerator
The door gaskets on both freezer and fridge get VERY hot. What is the cause of that?
    President:
  • 949 Answers
This is caused by an overheating condenser. The coils below the refrigerator are either dusty and dirty or the fan down there has stopped running. See the link below for more details on this and how to check the fan. Let me know if it was helpful.
Dirty Condenser
Posted on Jun 04, 2010
Why the freezer door opens when the refrigerator is closed?
I have a refrigerator with a top freezer that was constantly popping open, just enough to let the heat in and melt anything inside. This can also cause heavy frost build up from condensing humidity in the air. The frost can build up on the front face of the fridge where it meets the magnetic gasket on the door making it even harder to keep the freezer closed.
The cause in my case was that slamming the refrigerator door sent a puff of air through the ductwork to the freezer above. The sudden pressure increase popped the freezer door open and the door wasn't heavy enough to close on its own. Since this is a beer fridge in my garage I fixed it by putting a stick on childproof latch from H-D on the freezer door. :-)
If this was our main fridge indoors, I would first check to see how much force it takes to open the freezer vs. the refrigerator section. It should be about the same. If not, check the freezer door gasket to be sure no food or ice is built up on it and that the mating surface is clean. Check that the door is closing parallel to the mating surface. A misalignment would make it hard for the gasket to seal or stay sealed. Adjust hinges if necessary. If all seems ok, check to see if the fridge is level or possibly needs to be adjusted so it tilts back just a bit to make the doors self closing and not fighting gravity to stay closed. If all else fails, inspect the door gasket to be sure it isn't broken or stiffened with age. Inspect the bottom of the door gasket with a mirror. I once had a side by side with what looked like a good gasket until I felt around the bottom of the door. Replace if necessary.
Dec 15, 2016 | Refrigerators
Jenn-air gasket is hot
The refrigerator portion is fed cold air from freezer section to cool it. Check for the freezer fan and/or the damper mechanism that directs air into fridge compartment for proper operation.
Sep 03, 2017 | Jenn-Air Refrigerators
Candy fridge freezer the fridge part keeps icing up on the back of thr compartment why is this
Sounds to me like the door gasket is faulty and letting moisture into the fridge section,the ice is the moisture freezing once it gets inside and it will accumulate in the coldest part of the fridge(probably the back of the fridge)cause thats where the freezer air inters the fridge section, change the door gasket and it should be fine.
Aug 25, 2009 | Refrigerators
Top freezer door pops slightly open when frig door is closed
try to adjust hinges and check the door gaskets for pinching. Also I have seen that if the fridge is slightly pitched forward and not slightly towards the back gravity sometimes this causes the problem you describe.
Apr 26, 2009 | GE Refrigerators
Fridge not cold
I think that I have a solution. Refridgerator side not cooling.
I read in the blogs that holding down the top two bottons(power cool & fridge) at the same time resets the refridgerator control panel.
I may have caused the problem by leaving the door open. If my above solution does not work, then I will defrost the frefrigerator just in case the coils are froze up. It works with my air conditioner.
Ed
Aug 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Frost inside freezer door
there is a small electric heater along the door gasket where you see the frost building up, this heater has apparently stopped working. this will also cause the door to pop open due to a poor seal. feel around where the door gasket contacts the refrigerator and it should feel a little warm. if not then a service company can replace those heaters. should not be too expensive.
Jun 28, 2008 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Indest Fridge Freezer
Possibly something was spilled and it got to the door gasket. Clean the door gasket area with warm soapy water. In the door there is nothing critical to the system operation that should cause the condition you have.
May 17, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge freezer temprature/hot doors
if your talking about the post between the doors its supposed to be hot its to keep the gaskets dry but you can clean the coils on the fridge if you haven't for awhile that will help keep them the right temp as far as setting the temps i always using your milk and ice cream every one knows how they like their milk and you don't want to have to dig your ice cream out with a chisel
Feb 16, 2008 | Refrigerators
Concaved out freezer door
If concave is severe you will have to replace door. You can try to alleviate a slight gap by using a hairdryer and blowing hot air on the gasket in the area of the gap....move the dryer in up and down motions and the gasket will expand! Just make sure that there is no ice pressing against the door inner first! Oshie
Jun 18, 2007 | Maytag MTF2195AE Top Freezer Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
136 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
