Question about Magellan Maestro 4000 GPS
How do you reboot the Magellan 4000 GPS - Magellan Maestro 4000 GPS
    President:
  • 1,111 Answers
To reboot the 4000, get a paper clip then turn it on and when it gets the the warning screen look on the left side near the bottom for a little tiny hole (thats the reset) and insert the paper clip and press gently to reset the gps...it should turn off and reboot.
if that does not cure your problem, please let me know whats wrong with it and we will go from there.
bill
Posted on Jun 04, 2010
5 Suggested Answers
SOURCE: magellan maestro 4000, 4040, 4050 vs mio c220,c230,
Don't buy a Magellan. There is little to no support, and their web based support redirects to no where useful for upgrades. I'd sell you my 4040, but can't in good conscience sell it to anyone.
Posted on Nov 20, 2007
  • 5 Answers
SOURCE: How to reboot magellan meridian gps
If by 'reboot' you mean to wipe it completely clean then do the following. But if you want to save your waypoints and tracks you should do that first. You can do that to the SD card in the unit or serially to your computer using any number of free or costly software. It'a also a good idea to remove the SD card while wiping the unit, it can do a format of that card.
To wipe it clean, press [menu], then arrow down and press [setup], then arrow down and press [clear memory], then select [all] and press enter. It will ask you if you really want to do that, if you do then slelect [yes] and press that.
Now your GPS is fresh, to whatever satellite configuration its firmware knew about, probably 2004, so you have to set the date, set your approximate location and have the GPS ON for a minimum of 12.5 minutes with as good a clear view of the sky as possible, and do not move the GPS around while it's trying to re-acquire the satellite almanac.
Others will say that this will make your unit no longer be able to receive WAAS augmentation, they are right, but I spent all last year figuring out how to fix that, check http://ray.jerome.jobs.googlepages.com/MagellanWAASfix which at least 100 people I know of have used so far.
Posted on Feb 26, 2009
  • 1111 Answers
SOURCE: I NEED A SOFTWARE FOR MY GPS MAGELLAN 4000
what version software is currently installed. i dont think a map updates going to help you, which is what the link is from the previous poster.
Posted on Jun 03, 2009
  • 1111 Answers
SOURCE: I can't tell if my magellan maestro 4000 gps is charging.
this could be happening for a few reasons but the most common is that its probably not charging.
before checking anything else, plug your 4000 in to a known good charger, then press and hold the power button for up to ten seconds till it starts.
if that fails, its likely not charging
this is very common problem with this and many model magellans.
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get help to repaired it, here
or buy the port here
if you need further help, just let me know.
Posted on Nov 09, 2009
My maestro 4000 wont boot up
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Jan 02, 2011 | Magellan Maestro 4000 GPS
Magellan maestro 4000 no sound
I did an update on a Maestro 4000 and it seems that I lost my sound.
Mar 09, 2010 | Magellan Maestro 4000 GPS
Nov 09, 2009 | Magellan Maestro 4000 GPS
Power cord is not charging unit. There seems to be a loose fit in the socket of the Magellan Maestro 4000. Is the problem with the charger cord or the Maestro 4000 socket?
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
Oct 09, 2009 | Magellan Maestro 4000 GPS
Tried to update firmware and now all I get is a blue screen with the word Magellan across it and a black line across the bottom of the screen. how do I fix it?
run the firmware again and make sure you wait until it tells you to disconnect the usb and wait for the unit to finish the reboot.
Jul 08, 2009 | Magellan Maestro 4000 GPS
I have charged my Magellan Maestro 4000 for 8hrs and still cannot get the power to come on
hi monicarmccar
this is a very common problem with your model gps
Bill
Apr 29, 2009 | Magellan Maestro 4000 Handheld GPS...
Lost instruction manual
www.magellangps.com/assets/manuals/maestro_4000_manual_en.pdf
Jan 06, 2009 | Magellan Maestro 4000 GPS
Magellan Maestro 4000 Audio Problems
the one i have is 3 month old and im having the same problem, the audio is not working (magellan model 3225)
Mar 17, 2008 | Magellan GPS
Magellan maestro 4000, 4040, 4050 vs mio c220,c230,
Nov 13, 2007 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4000 GPS Logo
284 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
