Question about Panasonic WORKiO DP-C262 Printer
Fuser belt unit dp-c262
Where do i get one of these units and how do i replace it
When making copies, there is line on the copies. How do I resolve this issue?
Katie
Posted on May 13, 2008
How do I reset ms610 imaging unit?
When you get the error message "Replace imaging unit, 0 estimated pgs remain [84.3x]" This means the imaging unit has reached end of life and needs to be replaced. The device will not print, and this message will not be cleared, unless you replace it with part number 50F0Z00
(or 500z)
Vertical streaking. If the imaging unit is near end of life, or the device has had problems with non standard toner, vertical streaks may occur on the page. Replacing the imaging unit will resolve the problem.
Vertical streaks on page
Vertical band at top of page. This typically appears on printed images, but can also appear on text. The most likely cause is toner contamination on the charge roll, however if the band is still visible after printing 30-40 continuous pages this means the imaging unit needs to be replaced.
Vertical Banding on images
Seal failure on the imaging unit. Occasionally seal leaks have been seen from the Imaging Unit.
Toner will be seen on the main frame near the Imaging Unit sides.
If toner build up is excessive, it may even fall into the Tray below. Cleanup with a toner vacuum may be needed.
Replace the Imaging Unit to fix the problem.
Spots, scratches, marks on the page. If they are random, this indicates a problem with toner scatter.If they are repeating patterns, measure the distance between matching marks or spots. If the distance is one of 97mm, 47mm or 38mm, this indicates marks or dents on the imaging unit and it will need to be replaced.
You receive the message Replace defective imaging unit The imaging unit is defective and needs to be replaced. If you just installed it, it will be covered under warranty - contact Lexmark Australia on 1300 362 192
You receive the message Reinstall missing or unresponsive imaging unit and the below instructions don't resolve the problem. Try one or more of the following:
  • Check if the imaging unit is missing. If missing, install the imaging unit.For information on installing the imaging unit, see the "Replacing supplies" section of your device's User's Guide
  • If the imaging unit is installed, then remove the unresponsive imaging unit, and then reinstall it.
  • Note: If the message appears after reinstalling the supply, then the imaging unit is defective. Replace the imaging unit.
You receive the message Replace unsupported imaging unit The imaging unit you attempted to install was either non-genuine, or was from a different region. Buy a genuine Lexmark imaging unit from an authorised Lexmark supplier in your country/region.
You receive a 31.6x error One of the following errors is shown on the display:
31.60 Imaging unit smart chip error
31.61 Imaging unit I2C packet timeout
31.62 Imaging unit I2C packet has been sent but code timed-out on receiving the data (callback)
31.63 Imaging unit security error in the send challenge sequence
31.64 Imaging unit ROM signature error
31.65 Imaging unit stuck busy (status register and/or CRI Arbiter register report busy)
31.66 Toner failed to replenish into the imaging unit
In this case you need to ensure that the imaging unit is properly installed. If yes, check if the imaging unit is supported. Replace with a supported imaging unit if necessary.
If the problem remains, you will need to organise a Lexmark service call (Australia 1300 362 192)
You receive error message 32.11 Imaging unit smart chip compatibility error This could be caused by an unsupported imaging unit (non-genuine or incorrect region). Replace with correct imaging unit to clear this error. If your imaging unit is supported, you will need to organise a Lexmark service call (Australia 1300 362 192).
You receive error message 84 Imaging unit low If expected, replace the imaging unit. If unexpected, call Lexmark Support (Australia 1300 362 192)
Jan 23, 2017 | Office Equipment & Supplies
Color Print Quality
In my experience, the fuser has always been the cause of the lines.
Jul 09, 2008 | Ricoh CL3000E Laser Printer
Fuel sending unit test and replace
Checking and replacing a fuel sender unit ' How a Car Works
www.howacarworks.com/fuel.../checking-and-replacing-a-fuel-sender-u...
Learn how to check and replace a fuel gauge sender unit, and how to check a fueltank. ... Fuel pipe Sender lead Breather pipe Sender unit Petrol tank Filter Float arm Float Mounting flange Filler .... Test by quickly removing the filler cap.
How to test a Fuel Sender - YouTube
? 2:01
https://www.youtube.com/watch?v=hHzeOOzQKR8
Dec 1, 2012 - Uploaded by TheyMightBeRacing
This video shows the basics of how to test a fuel sender to ensure that it is ... Trailblazer fuel gauge not working/sending unit test and replace ...
Trailblazer fuel gauge not working/sending unit test and ...
? 17:29
https://www.youtube.com/watch?v=aIMDauRGwFg
Sep 23, 2012 - Uploaded by MAY03LT
How to replace the fuel sending unit in the 02-03 Trailblazers. I also show how the fuel gauge works and how ...
Toyota Corolla Fuel Pump Removal Sending Unit Testing ...
? 6:17
https://www.youtube.com/watch?v=JtYMRrUpZr0
Oct 29, 2014 - Uploaded by richpin06a
Toyota Corolla Fuel Pump Removal Sending Unit Testing. ...Camry 1997 1998 1999 2000 2001 fuel pump replacement - Duration: 9:32.
Jan 13, 2016 | Cars & Trucks
The Samsung Printer M-2876ND is showing an error replace imaging unit. It has already printed 9000 units, so i guess the life of the unit is over. Now, i want to know if the same will work in case i j
Dear Ankit
you can replace the complete drum cart. or replace the CRUM (drum chip) of the drum cart. no need to replace the drum it can goes up to another 9000 a4 pgs.
Thanks.
Jan 12, 2015 | Samsung Office Equipment & Supplies
Need to replace imaging unit . konica c252
http://www.precisionroller.com/imaging-units-for-konica-minolta-bizhub-c252/products.html
push down, slide out, pull tapes and fixtures off new unit(s) and replace. These IU's have chips in them to keep track of life. Another option instead of replacing the unit is to buy just the chip and replace it on the old image unit. This depends on the condition of the existing unit(s).
Jan 07, 2015 | Konica Minolta BizHub C252
How can you be sure about replacement parts on older RUUD units? I've got a RUUD UHQA 1015T that my home warranty company wants to just replace the coil on...rather than replace the whole unit....
I would ask what the price difference is between replacing the coils and replacing the unit. Then make my decision. If the the unit is 12 years or older, then i would take what they are offering to replace the coils and replace the unit.
Sep 22, 2011 | Heating & Cooling
Cracked overdrive unit housing where it connects to transfer case
Replace the overdrive unit case. It isn't hard to remove the parts and switch them. OR replace the overdrive unit with another one. I can tell you how to disassemble the unit. You will be suprised how easy it is.
Jul 04, 2009 | Dodge Ram Pickup 1500 Cars & Trucks
We need to replace the drum unit on a Minolta Di3510 and were told that when you replace the drum unit you also need to replace the developer. Where and how is the developer replaced on this unit.
Not familiar with your model.... but...
When you install the toner cartridge, the toner is routed into a developer unit. this unit has "developer" in it that mixes with the toner. Generally you purchase the developer, remove the developer unit, remove the top cover of the unit, empty the contents of the unit. add the new deveoper to the unit, replace the cover, install the toner cartridge. a lot of times this requires going into service mode to reset the developer count and run a conditioning mode. Not sure if this is any help but here you go.
May 18, 2009 | Office Equipment & Supplies
Technical Black Imaging Unit Replaced,Error message still shows
These units are automatically reset with a fuse. When you put the imaging unit in it will completes a connection which resets the count then simultaniously blows the fuse. Sometimes the fuse blows before the reset, which is what it sounds like happened here. The machine should print normally but the error will persist until the unit is replaced with a new one. Is the the imaging unit an OEM unit or remanufactured? Whoever you got the unit from should replace it as defective free of charge. If it is OEM you might have to go through Xerox to get it replaced. I don't know if the Big Box stores will.
Dec 04, 2008 | Xerox Phaser 7300DN Laser Printer
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
Panasonic WORKiO DP-C262 Printer Logo
789 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
