Question about Olevia 237T 37 in. LCD TV
I have a customer on the phone who has a olevia flat screen and can not locate an input for his cable wire. where are they located?
    Novelist:
  • 109 Answers
Here are the only signal inputs located at the back of the tv.
1 x HDMI input ( 19 pin HDMI Type A )
2 x component video input ( RCA phono x 3 )
1 x VGA input ( 15 pin HD D-Sub (HD-15) )
Audio line-in ( RCA phono x 2 )
2 x S-Video input ( 4 pin mini-DIN )
2 x composite video/audio input ( RCA phono x 3 )
1 x headphones ( mini-phone stereo 3.5 mm )
1 x SPDIF output ( TOS Link )
1 x audio line-out ( RCA phono x 2 )
1 x subwoofer output ( RCA phono )
1 x serial
If you are looking for a coaxial cable input.. it is actually not available so you have to connect a converter from coax cable to RCA cable for you to connect it on your tv.
Posted on Jun 04, 2010
My olevia tv volume only works with me dvd player but no sound when i connect my cable box
If cable from cable box is connected to TV, use TV remote to switch to Cable input if you have a Cable/DVR you will need to run speaker wires from Cable/DVR to a TV input
Nov 12, 2013 | Olevia LT32HVM 32 in. LCD Television
Olevia HD tv with no signal. Tried troubleshooting with cable provider, no results. Help!
If this is a problem you had while continuously using the same cable TV and provider, check whether the TV works well with any other input device. Look for any loose contacts in RC Jack, cable and connectors.
Aug 22, 2012 | Televison & Video
Can't locate fuse on my Olevia TV...what does it look like? 27 inch flat screen
The fuse is located on the power supply. You have to remove the back cover of the LCD in order to get to the power supply. The fuse should be near the AC power cord jack. If the fuse is blown, you may have bigger problems than you anticipated.
Nov 07, 2011 | Olevia 227-S11 27 in. LCD TV
Our new vizio tv is hooked up just like our old tv, (satellite provider being dish network) and it says no signal with a blue screen
Hello. This is usually an easy issue to fix. To get the DISH Network back on the screen, i have included a few steps:
If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4. Depending on the cable that is running between the receiver and the tv, the tv may need to be on an input, such as video 1 or 2. If you are at the TV2 location, where there is no receiver, then the tv needs to be on channel 60 or 73.
If you are using an HDMI cable, then the TV will need to be on an HDMI input
If you are using Component cables, your TV will need to be on a component input. (Usually Comp 1 or 2)
If you are using RCA cables, then the TV will need to be on a VIDEO input (Usually Video 1 or 2)
If you are using COAX cables, then the tv needs to be on channel 3 or 4 (If you are at TV2, then the TV needs to be on channel 60 or 73)
Becki Barned
DISH Network Customer Service
Feb 26, 2011 | Vizio VX32L Television
THERE ARE 3 WIRES YELLOW,WHITE, AND RED WHICH WIRE I CAN DO PROPER CONECTION for get DVD WHICH JUCKS I CAN PLUG?
OK, what you have is the Composite Video cable (Yellow RCA plug) and the Audio cable for Right (Red RCA plug)) and Left (White RCA plug) audio channels. You just have to look at the back of the DVD and locate the Composite VIDEO output jack and Audio output jacks, just match the colors. Sma thing on the TV, just look for either AV1 or 2 Composite Video input jack and audio input jacks.
Set the TV to select the video source you have the cable plugged into, and that is.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Nov 29, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Olevia tv, no power
This the common problem for Olevia TV, open up the back cover, locate the power supply board, look for the electolytic capacitors top that is slightly domed, replace them, they usually 1 or 4 that is bad, buy your replacement's at Radio Shack
Jun 06, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
Not sure if this is the right model #...need Model # to find out why volume quit working
Most commonly the model number is on the back of the TV. It should be located on the same sticker/placard with the big Olevia name on it. The model number maybe in small print below the Olevia name.
Did the volume quit working on every channel and every input selections?
May 17, 2009 | Olevia LT42HVi 42 in. LCD Television
I hooked my olevia tv up to cable tuner box but cannot get a pict
Try switching throught the various video inputs on your tv until you get a picture.
Jan 30, 2009 | Olevia LT32HVM 32 in. LCD Television
No Signal/VGA Input
use the " input " button on the remote control to select the input you are using to watch tv. she has accidently switched it to the computer input jack which is located on the side.
Jan 22, 2009 | Insignia IS-LCDTV32 32 in. Television
Need a Power supply for a LT26HVX Olevia LCD
That is because no one knows how to troubleshoot to the component level anymore in this "lowest repairable unit" world we live in! Throw it away and buy a well know TV set. Another item for the land fill....Shame! Sorry as it is, just a shame.
Former electronics technician - level troubleshooter - US NAVY
May 23, 2008 | Syntax LT26HVE 26 in. HD-Ready LCD...
Olevia 237T 37 in. LCD TV Logo
334 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
