Question about GE Heating & Cooling
My a/c unit is running but no air is coming out of the vents in the ceiling
  • 674 Answers
It sounds like your indoor fan is not running. First check to make sure you have power to the fan. Check your ciruit breakers and fuses. If that is good then turn off the power and make sure the fan rotates freely by hand. Next check the capacitor for the fan. You can use a multimeter for that or if the capacitor looks swollen it's a good bet that it is bad. Next check the fan motor windings with an ohmmeter. Let me know if you have any questions about what to do.
Posted on Jun 04, 2010
Good day! I am running my Carrier A/C Model 38EYG and it is running fine...the outside unit is running fine and the air coming out of the ceiling vents is cool. However, the inside unit (the one in the...
No its not normal. Check and make sure there is no flame inside the furnace. If not , turn the pilot light off it is a gas furnace and see if this makes a difference. good day to you too.
May 10, 2011 | Heating & Cooling
Stops blowing air
remove cover at ceiling so you can see in at fins and see if they are frosting up bad. If they are, I suspect during AC installation, they didn't open up ducts on discharge properly and air flow is restricted, which will cause freeze up, especially if low flow from discharge ducts. I'm assuming it is a ducted system. You may have to remove or drop down entire ceiling assy, to see if the ducts into ceiling have any blockage. Sometimes they don't cut rubber roof material back far enough, or misaligned ducts and cause restricted flow to ceiling vents, which will cause unit to frost up, which kicks out compressor until frost is melted, then compressor kicks back in and cooling happens again.
Apr 06, 2010 | Dometic Rooftop RV Air Conditioner
I'm getting condensation leakage from the vents in the roof. This is on a ducted system, and it's leaking from the two vents closest to the main blower unit up in the ceiling. It's very high humidity here...
Two things may need to be done here, one is to insulate the vents in the high humidity/temperature area to isolate them from these high conditions. The second would to install a drain pan under the system to catch any condensation and drain it away.
Mar 01, 2010 | Heating & Cooling
We have a one year old home and started to notice
do you have floor or ceiling vents, and does your house have concrete flooring or do you have a crawl space under depending on the answer because if you have a unit that is all outside then the duct may not be sealed
Jan 08, 2010 | Ruud UBHC Air Conditioner
Coleman 1300, condensation buildup inside unit, ceiling wet
Check for plugged drains under cover on roof, sticking out at base of unit usually. It should be running off roof.
Aug 04, 2009 | Heating & Cooling
Does anyone know if a Duo Therm model 620515.331c is ducted or not???
The upper unit itself is not ducted. They are all the same. The ducting is done with the lower unit or "Ceiling Pack" of the air conditioner. You need to see your RV is ducted, ie...vents in the ceiling that blow the are out. Usually they are round and mount into the ceiling. Another way to tell is if the unit has a wall mounted thermostat.
Hope this helps,
Jeff
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
I have a dometic duo-therm. No air coming through ducts.
Sounds like the ducting have come apart in some areas or blocked in some way. Take the supply grills off and with a shop vacuum try and reach as far as you can.
Mar 18, 2009 | Dometic Rooftop RV Air Conditioner
A/c works but fishy smell coming through vents
Is this an upflow or downflow unit? (vents in the floor or ceilings?) If an upflow, the coils needs cleannings and disefectant added. (mold-- bacteria--slime-- gooks---darkness plus moisture = bacteria growth.
Jun 05, 2008 | Goodman CLQ36AR49 Air Conditioner
No air flow upstairs
Cold air is denser than hot air, so is harder to move. All vents have some mechanism to regulate flow, so close all of the downstairs vents. Check to see if your furnace fan motor has more than one speed, & set it on maximum. Keeping the fan on all the time will help as well. If all else fails, you may need a more powerful fan motor.
Jun 16, 2007 | Weather King 12AJA4801AH Air Conditioner
Heating & Cooling Logo
47 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
