Question about Kenmore Dishwashers
Kenmore Ultra Wash leaking from door
Water runs out of the door of our older Kenmore Ultra Wash dishwasher. We have reduced the leakage by cleaning around the door and the seals, and by tightening the Torx fasteners on the side (the bottom ones were quite loose, maybe 1/8" backed out of fully tight).
We're assuming a water seal somewhere (inside the door?) needs to be replaced. Does anyone have a schematic or diagram of what to expect if we take the inner panel off the door?
catriver
  • 878 Answers
SOURCE: Door leak
Br, couple of things you can look for here. Check the vent, you can just pop this out. Sometimes there is a buildup of gunk which will hold water during wash and leak down between the door. There is a seal there, part number 974782. Another thing is to check the upper spray arm for cracks or splitting. This can send a direct flow of water into the vent. There is also a seal at the bottom of the upper spray arm, part number 3376846. I was fooled by a leak like this once, it turned out to be a clogged vent...Catriver..post back.
Posted on Oct 01, 2006
catriver
  • 878 Answers
SOURCE: Water Leak at vent area in door...
On this model the vent is open and shut by a wax motor. The vent should be closed tight during the entire wash cycle and the first 6 minutes of the drying cycle. Check the operation, make sure there is not a bunch of gunk restricting it. If you are handy with a meter check the resistance of the motor. It should read approx. 2100ohms. Another reason for leaking at the base is oversudzing. Also check the upper spray arm for cracks or splits shooting water into the vent area. Catriver...post back.
Posted on Oct 23, 2006
Maanita
  • 1142 Answers
SOURCE: We are having water leak
Try to fix the rubber seal which has come out by fixing it through super glue or apoxy seal which will stop the water spill and leakage.
Please give more details of you dwasher ..... the Make and model so that i can send you the manual for future use
Posted on Apr 06, 2008
  • 56 Answers
SOURCE: Kenmore dish washer leaks thru the door, need replacement seal.
I dont know what models but several models leaked thru the soap dispensor in the door.They were recalled. Check the manufacture for your model.
Posted on Jan 26, 2009
SOURCE: Door leak
Check the screws on the pump cover under the lower spray arm (the spray arm is easy to remove, the screws are torx - maybe a torx 10 or 15, so a regular screwdriver wont work). They come loose on ours every 6-12 months and spray water at the door, causing it to leak all over our wood floor. I routinely tighten those screws now before they come loose enough to cause the problem.
Replacing the door seal doesn't help - if you look at it closely the bottom of the door doesn't seal against anything, it just overlaps the front of the tub so water sprayed hard against the front (from a leaking gasket) can go under the door and up and over the tub front, making it look like a door seal problem.
Posted on Jul 12, 2009
I have a kenmore elite ultra clean dishwasher. Have only used it two times. Does not dry well. Lots of water left Read Manuel. Extra dry should not always have to be used. Water still on door after a...
RINSE AID! Buy a bottle of Jet Dry or similar rinse aid liquid. Fill the rinse aid dispenser completely. Run dishwasher as usual. Water will no longer cling to the tub or the dishes. Newer dishwashers require rinse aid to dry properly due to reduced energy consumption.
Aug 07, 2014 | Dishwashers
Kenmore ultra wash diswasher top rack not cleaning
see please the next video for your fix it: God bless you
Jul 21, 2012 | Kenmore 24" Built-In Dishwasher with Ultra...
It sometimes run water on to floor . the drain is not kinked.
first of all, you must check to make sure that the door is closing properly before you run it, and that nothing is sticking out, or trailing out of the door.
secondly you must never open the door during the running of the dishwasher.
check to make sure the drainage is clear of protrusions. use special dishwasher cleaning salt if you need to. to do that, you need to obtain the special salt and run the dishwasher empty, it cleans away all the junk blocking the drain.
additionally, the connections to and from your dishwasher could be faulty and or leaking. check the input and output water line connections on the dishwasher and their other ends as well.
Mar 26, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Water is not competed drained out after all wash rinse and dry cycles are complete. No signs of any leakage on floor or under machine.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Mar 20, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
The top rack on my kenmore ultra wash 3 dishwasher does not come clean and now even the bottom is starting to not clean
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Dec 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Water leaks from the bottom door
The gasket that surrounds the door will fix it. If that's what you ordered, it'll be taken care of upon installation.
Jul 11, 2009 | Kenmore Dishwashers
My Kenmore under counter ultra wash dishwasher model 665.15825691 has started leaking at the lower corners of the door. The leaks seem to occur during the final rinse while the water is being heated. I...
Happened on my dish washer too. Remove lower rack, remove lower spray arm by removing the center plastic nut, check screws (torx) on outside edge of pump. Tighten these as necessary, mine were loose causing water to spray forward against the tub causing leakage.
Jun 27, 2009 | Kenmore Dishwashers
Kenmore ultra wash dishwasher control lock light flashing
Just press the 'Air Dry' button for 5-6 seconds....I have an ancient Kenmore Dishwasher (ULTRA)
Oct 02, 2008 | Kenmore 15899 Built-in Dishwasher
Kenmore Ultra Wash 3 Leaking
Got a possible solution from a brilliant guy named Jake on another website and thought I would post it back here.
"Check the door vent on the inner side of the door, that should just snap out, I have seen those clog and start making more pressure inside to make it leak from the bottom. Jake"
I checked mine and got a nasty surprise. Who knew it could get so dirty.
Nov 01, 2007 | Kenmore 15129 Built-in Dishwasher
Dishwashers Logo
110 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
