Question about Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas
Pilot light is on, but heater never engages - Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas
  • 33 Answers
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Posted on Jun 05, 2010
Wher is pilot light
Why will my pilot light on the gas water heater not stay lit for ...
diy.stackexchange.com/questions/.../why-will-my-pilot-light-on-the-gas-...
Jul 28, 2011 - The pilot light went out on my gas water heater. I followed the ... This could be from a valve not being all the way open. It could also be from a ...
How To Relight Your Pilot Light On Your Water Heater ...
? 7:54
https://www.youtube.com/watch?v=gqM7kMkkFAI
Apr 15, 2013 - Uploaded by TipsNNTricks
How To Relight Your Pilot Light On Your Water Heater. TipsNNTricks .... I answer the following questions in this video. How can I relight my pilot ...
How to Light a Water Heater (with Pictures) - wikiHow
www.wikihow.com/Light-a-Water-Heater
wikiHowJump to Questions and Answers - If the pilot light doesn't relight or goes out immediately after ... if you are unable to light the water heater after several attempts.
Jan 13, 2016 | Water Heaters
My wall mount propane heater sputters and won't fire up when I turn the knob to on
this quote is taken from site below under Problem Identification.
If the burner sputters on ignition or takes more time to ignite, there is definitely a blockage of the pilot orifice by dirt and dust. Set the pilot at a higher level and clean the orifice along with the burner ports.
Read more at Buzzle: http://www.buzzle.com/articles/how-to-repair-a-gas-furnace.html
Jan 09, 2015 | Heating & Cooling
Small Pilot flame on MrHeater MHBF20lpt & pilot won't stay on.
You will probably need to remove the pilot orifice and clean it out use a small needle or orifice cleaning rod. The pilot flame is not big enough to keep the thermocouple engaged.
Dec 22, 2013 | Mr. Heater Heating & Cooling
Flame went out. Attempts to relight allow the pilot to light but will not remain engaged to allow setting to on position.
Hello genepage,
I understand that you are having a problem keeping your hot water tank pilot lit. I have wrote a tip that explains what the problem is and how to correct it you just need to follow the link to this tip. Click here to go to the tip!
Thank you for choosing FixYa.com
Justin
May 03, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Flame flickers and jumps it will stay lit for a while then just puffs out
The pilot assembly probably has dust in it. With the unit off and cool, use a drinking straw and blow across the opening of where the pilot light flame lights. Do not blow directly into the pilot opening, as the dust will only become more lodged in the orfice. By blowing across the top of the opening, the moving air will 'vacuum' the dust up and out allowing a more staedy blue pilot light to engage the thermocouple. You may have to repeat this processa couple times depending on how much dust is in the opening. These OPD pilots are very sensitive.
Jan 18, 2011 | Dyna-Glo RMC-8001SS Heater
Why does a pilot light go out?
You either have a bad thermocouple, or the pilot flame is not engaging the top 1/3 of the thermocouple. If the problem is with a space heater with an ODP valve, there may be dust in the pilot causing a yellow lazy pilot flame. These are very sensitive and will go out moments after lighting if that is the case.
Jan 18, 2011 | Heating & Cooling
My hot water heater won't engage at all.
Sounds like the pilot light is not staying lit, provided you have one. The pilot light is used to keep the gas valve open by way of the thermocouple/switch. When the pilot light goes out the thermocouple cools down and shuts the supply of gas off to the water heater burner. It is not unusual for a thermocouple to go bad at which point it needs to be replaced. The thermocouple is the small rod that sits in or close to the pilot light flame. There is a small copper tube that runs from it up to the gas valve on the outside of the tank. This is where you control the temperature of the water as well as light the pilot light. If you are not experienced in dealing with hot water heater gas supplies, you should get professional help.
Oct 14, 2010 | Vacuums
My pilot light is on, but the heater does not
Miles
Jun 01, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pilot and Burner shut off at same time at various run times.
sounds like your pilot saftey is working.the pilot flame heats a device called a thermacoupler which gives a signal to the gas valve letting it know its ok to open main valve. you may need a new thermacouple , might have a dirty pilot orfice or a problem with gas pressure or worse case a cracked heat exchanger in any case in less you have some type of training you should call a pro
Feb 05, 2009 | Coleman Propane Forced Air Heater...
Comfort glo propane ventless heater won't light
I have several of these heaters in my rent houses and love them. The most problem I have is not being able to ignite the pilot with the user control igniter. Remove the screws that hold the front cover in place along with the front cover. Hold the pilot control down and ignite with a lighter. Keep the pilot engaged until thermocouple is warm enough to keep pilot gas flowing. If it will light this way then you need to blow out the pilot orifice. It seems that every year I have to go in after the summer season when the heater is off and clean the pilot/orifice lines with high pressure air. I believe spiders/bugs/dust block pilot orifice when it is not in use. You can also tell that orifice is blocked when you don't get a good blue pilot flame with pressure behind it allowing the flame to submerse the thermocouple. If the the thermocouple is not getting enought heat it will turn pilot gas off for safety reasons.
Nov 16, 2008 | Desa International GWP20T GLOWARM Wall...
Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas  Logo
158 people viewed this question
Top Teledyne Laars Pool & Spa Experts
paulcarew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
