I have a Samsung J845 front loader washing machine, A few weeks ago, no water would go into the machine, so replaced the broken solenoid. Now the water never stops going into the machine ??? The solenoid is working but not getting electrically turned off. When I pull the terminal from the solenoid the water stops. What has gone wrong now???
For most front loaders: Plug
off the mains. You have to look for screws below the front kick-panel, the
panel comes down & out. The pump is on the right side. Be prepared for
dirty water so keep a large plastic bag ready. There is a drain hose here, disconnect & drain out. There could be a lot of water. Inside the big
flexible tube (coming from the tub bottom) is the filter, be prepared to find
all sorts of junk here, clean out. Examine your pump also, clean out the
impeller. Carefully refit all. Your machine would be fine. Don’t wait for the
machine to jam to look into your filter.
For
some front loader models after removing the panel, bottom front, the filter is in the
compartment having the white screw able lid.
The big hose from the bottom of your tub leads to this compartment.
