Question about Dell 926 All-In-One InkJet Printer
Ink cartridge problem?
I own a Dell 926 all-in-one printer and lately it has refused to print. The printer connects and turns on successfully however, it continually says the right cartridge (colour) is not connected, the cartridge is not supported or there is tape over the cartridge (none of which is true). The cartridge has recently been refilled and the black and white one works perfectly (as tested through printing alignments). It will allow me to print without colour but i just spent $25 on a refill for nothing!!
Thanks for your help!
JT
  • 742 Answers
Try to re-seat the ink cartridge.
  1. Press your printer's button to position the ink heads for replacement
  2. Then gently pull out the problematic ink cartridge.
  3. Turn the printer OFF to reset the printer's memory.
  4. After about 3 minutes, turn ON your printer and it should now ask for the missing ink cartridge.
  5. Now gently put on the problematic ink cartridge in place.
  6. Let the printer re-charge the inks and clean the ink heads afterward through the printer's maintenance program installed in your computer. (Go to "Printer's and Faxes, right click on your installed printer, then click "Printer's Preferences. Go to the "maintenance tab" and click on something like Print Head Cleaning.)
Just give it a try.
Posted on Jun 04, 2010
My Dell 926 AIO Printer will not print after installing new ink cartridge. Ink level on computer still says empty.
you must cleaned cartridge before you plug on printer, for level ink detection you must waiting for moment for ink spread on cartridge.
Mar 09, 2011 | Dell 926 All-In-One InkJet Printer
My Dad bought new ink cartridges ( black and color) and installed them in the printer and it is not registering that they are installed. What are some things I should check for and how can I fix this????
After installing new ink cartridges in your Dell all-in-one 926 printer, you may receive an error message telling you the print does not recognize the new cartridges. Refilled or third-party cartridges, which Dell does not recommend using with the 926, often trigger the error message. You may also receive this error after you have been using the same ink cartridges for some time. Whether the cartridges are new or not, the error can be caused by a number of sources. Following the steps below should clear up print cartridge problem.
  • 1
    Open the Dell 926's front cover with the power on and wait for the cartridge carriage to come to a stop. Remove the ink cartridges by pressing on the tabs at the top of each cartridge. Check the cartridges to make sure you have removed all of the blue protective plastic film. Look for the "Dell" logo stamped into the cartridges' lids to ensure they are genuine cartridges.
  • 2
    Clean the shiny metal portions of the ink cartridges with a damp microfiber cloth. Allow each cartridge to dry completely.
  • 3
    Clean out any paper, staples or other debris that you may be able to see, then reinsert the cartridges into their appropriate slots. Put the black ink cartridge into the left slot and the color cartridge into the right slot. Make sure both click back into place.
  • 4
    Close the Dell 926's front cover and turn off the printer. Unplug the power cord and USB cable from the printer for five seconds, then reconnect them.
  • If your Dell 926 fails to recognize the print cartridges after following the above instructions,
    take it to a repair shop for servicing.
    Good Luck and Happy Printing
    Jan 26, 2011 | Dell 926 All-In-One InkJet Printer
    I have a Dell 926 All-In-One InkJet Printer, I put a new black ink cartridge in the printer; still have plenty of color ink. When I have a document that I want to print from Word, it will sound like its...
    Make sure you've removed the shipping tape from the cartridge's print head. More than likely the black cartridge is not disbursing ink - clean the print head carefully with "Q" tip and alcohol and see if black ink comes out slightly. Re-insert cartridge and try again. Perform "clean cartridge" in printer properties window.
    Nov 03, 2010 | Dell 926 All-In-One InkJet Printer
    My printer Photo 926 says that the ink cartridges have no ink when it does and it won't let me print anything.
    Please remove the cartridge and check the ink is there or not if the ink is not there please change the cartridge. If the ink is there in the cartridge shake the cartridge and fix it back.
    Aug 05, 2010 | Dell 926 All-In-One InkJet Printer
    Dell Photo 926 printer will not print with the black ink and tells me that the cartridge is incompatible even though there is ink in the cartridge and i got it from dell
    Do you have a '926' or a '962' printer? You've cited each number in your problem description.
    Remove the ink cartridge.
    Turn the printer off.
    Turn the printer on.
    Reinsert the ink cartridge.
    If the problem persists, contact Dell, and get them to replace it.
    Nov 20, 2009 | Dell 962 Photo All-In-One InkJet Printer
    Dell series 9 refill and low ink warnings
    The series 9 cartridges can be refilled. As long as the electronics are still functioning on your cartridge you should be able to print no problem. There is no way to reset the ink levels on these cartridges so you will just need to ignore the ink level warnings. I would recommend Cartridge World for ink refills. Many other stores and on-line sellers don't do the cleaning, vacuum filling, electrical testing, and print testing that Cartridge World stores do to make sure your cartridge works.
    Apr 02, 2009 | Dell 926 All-In-One InkJet Printer
    Hi there
    Replacing Ink Cartridges 1. Turn on your printer. 2. Lift the printer unit. 3. The ink cartridge carrier moves and stops at the loading position unless the printer is busy. 4. Press down on the ink cartridge lever to raise each ink cartridge lid. 5. Remove the old ink cartridges. 6. Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them. 7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge. 8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier. 9. Snap each lid closed. 10. Close the printer unit. 11. An alignment page automatically prints.
    Mar 01, 2009 | Dell 926 All-In-One InkJet Printer
    Dell 926 injection refill kit didnt work
    The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
    Feb 05, 2009 | Dell 926 All-In-One InkJet Printer
    Ink cartridge replacements.
    Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
    Hope this helps. Bud
    Jan 08, 2009 | Dell 926 All-In-One InkJet Printer
    Dell 926 All-In-One InkJet Printer Logo
    180 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
