Question about Dryers
Dryer runs for short time then stops... - Dryers
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryerdryer runs for short time then stops... - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Rdryer runs for short time then stops... - 2_bing.gife dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 04, 2010
Dryer drum moves about quarter turn/cycle then stops. please let me know the potential problem.
Your motor is probably going bad and it will run short time until overheated then after setting a little bit and cooling down it will run again for short time.
Aug 04, 2015 | Dryers
Why does my dryer stop heating
Clean your vent!
Try running dryer with vent unhooked if still shuts off could be bad thermostat. Try running on timed dry instead of sensor dry, could be sensor circuit.
Aug 30, 2014 | Whirlpool Dryers
When I push the star button on my dryer it will for a short time and stop, if I hold it in it will run
check the switch itself, try a jumper wire on it, if it runs while being jumpered its a bad switch
Jun 14, 2011 | Whirlpool GEW9200L Electric Dryer
Dryer stops before clothes are dry...have to wait a few minutes before it will start again but only stays running for a short time.
if the dryer is running and then the motor stops when it gets hot it sounds like you have a bad motor.when was the last time you cleaned out the dryer and vent line?also i need the model number,on some kenmore dryers they have even heat that can cause this to happen if it's in your machine the timer will count down faster than normal and shut down ,or you could have a bad thermister so send the model number and i can check it out for you.
Mar 26, 2011 | Kenmore Dryers
Our GE clothes dryer stopped running during the drying process and had to be restarted several times. Now it has stopped and it won't restart. Any suggestions?
First look for lint build up that could cause limits to kill power to the motor Clean the dryer and vent up. Check the element. It might be shorted to the pan. How to get into the dryer and repair photos HERE
Oct 07, 2010 | General Electric Dryers
Dryer does not stop
Hi. this will usually be a defective timer module issue. replacing the timer will fix this issue.
Jul 20, 2009 | Dryers
My dryer just stopped running?
It could be the door safety interlock switch. Remove the switch short the two wires and press start. If it works remove the short to stop the dryer and order a switch. If you have an Ohm Meter you can test the function of the switch without shorting the switch.
Jul 16, 2009 | Kenmore 63942 Dryer
Kenmore 94082 gas dryer: Runs a short time, then stops, E9E error
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 25, 2009 | Kenmore 67082 Electric Dryer
Electric Kenmore Dryer runs short time (seconds) and then stops.
your thermostat/s are not doing their jobs. They are allowing your dryer to overheat and also if your dryer has not been cleaned out on the interior you might want to do that. I've taken out globbs of lint build-up in them.
Mar 25, 2009 | Dryers
Dryers Logo
57 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
