Question about RTO 110cc Basic Manual ATV # ATD-125C
My 110 chinese atv starts and idles ok most times, but when throttling up it misses and wont pull itself. I've changed plug, checked plug wires, fuel is ok. Any ideas???
  • Andrew Mar 31, 2012
    Try checking clutch to see if its worn away
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 99 Answers
There might be a problem in a air combition chamber and air filter just check it and clean it with the proper tool like bush for air filter and petrol kerosene disel or oil for air fuel combition chamber. Now your bike will smooth up on throttling up.
Posted on Jun 04, 2010
Valve clearance diamo turista
Hi, Matthew and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Inlet system air leak.
4. Vacuum piston malfunction.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
12. The enricher valve not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.carlsalter.com/diamo-service-manuals.asp
Scooter Parts for Chinese Scooters Atvs
Chinese ATV Owners Repair Manuals
Diamo Turista 300 2008
Tips Tricks
Mar 28, 2014 | 2005 Diamo Fury
Acceleration problem
Could be a clogged fuel filter, could also be a slight crack in the throttle body gasket. get a spray bottle with water in it, set it to mist, while the vehicle idles, spray around the base of the throttle body, if it bogs down replace the throttle body gasket. Just curious, was it doing it before you changed the plugs and wires? If not make sure you have the firing order correct.
Dec 24, 2013 | 1997 Nissan Pickup
I have a 2005 Diamo 150 scooter. It always starts when the engine is cool but it sometimes stops or fails to start when it is warmed up. What is the problem with my scooter?
Hi, Jerry the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or a damaged battery, 9 volts or lower.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Water or dirt in the fuel system, carburetor or filter.
11. Restricted, blocked or kinked fuel line.
12. Fuel tank empty.
13. Gas cap is not venting properly or fuel tank venting system blocked.
14. A failed fuel pump, pressure regulator and or fuel injectors.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please visit the websites below. Good luck and have a nice day.
http://www.apriliaforum.com/forums/showthread.php?174841-My-scoot-won-t-start-sometimes-when-engine-is-warm
scooter wont start when hot
May 24, 2011 | 2007 Diamo Tracer 150
My 2002 4 cylinder highlander intermittent has starting problems. It will seem like it starts then will die.I have to hit the gas pedal couple times then it starts. Could it be time to change spark plugs?...
It could be all the above plus it could also be a bad fuel pump.My best suggestion would be have your plugs changed and take a look at them if there is a high carbon build up then check your air filter,ignition components and your engine control systems.If they have a gray or tan colored build up then there burning ok. I would try a tune up first to see what kind of response you get before going at the engine components.Also it wouldn't hurt to have the fuel pressure tested to make sure its at the proper pressure to eliminate the fuel pump.
Mar 07, 2011 | 2002 Toyota Highlander
09 700 ranger wont idol
Could just need maintenance service (spark plug, air filter, oil change).
Idle could set to low, but if it was idling OK, the idle doesn't normally change.
Could be throttle position sensor (TPS), or fuel pump. Polaris Dealer can hook it up to the diagnostic port and see what's happening.
Hope this helps.
Sep 12, 2010 | Polaris ATV
I have an 1989 4.3 it wont start unless i press the gas pedal down. then once it is started it idles fine but as soon as you put it into gear and try to give it throttle it dies, but if i am lucky enough...
Change the gas filter if you havn't already done so. It sounds like fuel restriction to me or perhaps a faulty fuel pump or cheap gas has blocked the gas filter. Hope this helps! Good luck!
Aug 03, 2010 | 1988 Chevrolet S-10
Burb is missing. put new fuel filter in plugs,wires.may be water
If one cylinder is missing at idle, it would be useful to know which one. Pulling the plug wires one at a time with insulated pliers would tell us if one does not cause a change.
It could be a fouled plug.
You could switch plugs with another, to verify.
If not spark, could be fuel.
If throttle body, then not likely.
If individual injectors, then pull whole rail off and see if all injectors fire, spray pattern like cone, and none dribbling.
If none of above, then consider intake leak, collapsed lifter, valve adj, etc.
Apr 22, 2010 | 1999 GMC Suburban
95 Summit 1.5L Mitsubishi engine miss /lack of power
Somewhere along the the line you may have a fuel blockage or a good dose of water in your fuel tank.Check the water in tank 1st.Add 1 litre of metholated spirits to every 20 litres of fuel.This will allow the water to break down and be burnt through the motor over time.Do this twice.If this does not work,there may be a glob of **** in the fuel tank that blocks the pickup.If this is the problem,the tank needs to be taken out and cleaned.I hope this is a start to get you back on the road.
Aug 18, 2009 | 1995 Eagle Summit
1995 mustang 3.8 V6 misses on throttle up
CHECK FOR OVER FILLED OIL LEVEL,DAMAGED BALANCER,LIKE DOES IT WOBBLE WHEN RUNNING OR PLUGGED CAT'S, THESE OLDER EEC IV IGNITION WONT NECESSARLY SET A CHECK ENGINE LIGHT WITH A IGNITION MISS. DID YOU WET THE CAR,IF DID MUST REMOVE ALL WATER,NO MOISTURE AT ALL. TRY PULLING OFF ONE WIRE AT A TIME AND SET IT IN A SAFE LOCATION AND RUN IT,SEE IF PROBLEM MOVES OR NOT. IF NOT ON A PARTICULAR WIRE THAT MAY BE YOUR SUSPECT.
Jul 12, 2009 | 1995 Ford Mustang
Honda Misses.
Pin point the dead hole and check that injector.
Dec 23, 2008 | 1995 Honda Accord
RTO 110cc Basic Manual ATV  # ATD-125C Logo
658 people viewed this question
Top RTO Cycling Experts
John Egan
John Egan
Are you a RTO Cycling Expert? Answer questions, earn points and help others
