Question about Cooktops
Electric stove I was cooking on my electric stove top. When I finished I turned the dial to off. I started cleaning up the kitchen and notice the one of the burner was still on, I turned the knob again and the burner was still on. I unplugged the stove from the wall for about 10 minutes. When I plugged it back up to the wall, the burner came back on. The dial is on the off position.
    Scholar:
  • 58 Answers
If it is a DOUBLE element burner you might of turned on the second element. double elements the reverse direction turns on.
if single you have a short or a bad switch
Posted on May 01, 2008
I have a 4 burner Jenn-Air JED8430ADB electric radiant heat stove that has recently stopped working. It has been installed for many years (came with the house) and worked fine until now. When I turn one...
The cook top is connected to 220 volts. In the house wiring there are two legs each 115 volts. Usually they connect with a red wire, black wire and the third a neutral. It is likely that at the connection to the unit or at the electrical box a connection has failed or the 220 volt circuit breaker has failed on one leg. A qualified electrician needs to do the repair!
project1-nbbnxwvnfadegsi2zsme4jri-2-2.jpg Hope this helps?
May 04, 2017 | Jenn-Air JED8430 Electric Cooktop
Amana Glass cooktop 2 out of 4 burners not working
it is not a fuse. as if it shorted it may blow it and then nothing .. the sw to either one burner is at fault replace the sw 's ( both and the cook top should be ok . sw cost around 25 to 40 ea ..
Jul 13, 2010 | Amana AKT3040 Electric Cooktop
Burner shuts itself off after 10 0r s minutes of working normally
this unit has a gas coil controling the valve . and wen it gets hot it is failing and cannot keep the gas on . replace the valve coil // mm
Jul 12, 2010 | Thermador PC366BS Stainless Steel Gas...
Spot on Jenn Air smooth cook top stove with down draft.
Use Cooktop Cleaner with a soft micro cloth. Don't use water. Buff until the mark disappears. Hint: Never clean the cooktop until it is completely cool to touch as doing so makes cleaning much harder. Never use abrasives on the glass or abrasive cast iron skillets.
Mar 26, 2009 | Jenn-Air JED8430 Electric Cooktop
Why does my jenn gas cook top burners all flicker when turned off
hi im gerbee,i will sujest to clean the area were is the place of ur knob control try to remove the control knob then clean it by using a vaccium coz sometimes the problem is very dirt of the control knob.
Nov 30, 2008 | Cooktops
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Gaggenau Cook-top VG 352-812 problems
Hi, interesting. I have the same units on my GasHob and my problems are exactly reverse. To turn the burners on it takes about 15 clicks and with some luck you'll get gas! Sorry, wished I could help.
Claus.
Jun 08, 2008 | Cooktops
Ge profile electric counter top stove
I did not receive instructions with my G E Profile cook top Model No. 80030750434). There is a build up on the elements which I am having problems removing. Should the top be scraped while the stove is hot or cold? What is the best cleaning product to use?
May 01, 2008 | GE Profile JP930 Electric Cooktop
Cooktops Logo
148 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
