Question about Hyundai L90D+ 19" LCD Monitor
My Hyundai monitor is making static like noises. I've tried muting the speakers and that doesn't help, what could it be.
  • 11,361 Answers
It can be bad filtering caps in the power supply are going out, you need to open it up and inspect the caps first. You may cause more damages if yoo do not unplug it from tthe wall outlet.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 04, 2010
My baby monitor wont stop making static noise
Did you try to turn the auto mute on? It is the first option under settings.
Mar 11, 2012 | Samsung Wireless Security Monitoring...
The monitor doesn't have sound and microphone It doesn't play any sound ,music or tones
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it:
if your computer came with a motherboard disc the sound drivers could be on it:
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps:
Jul 07, 2011 | Computers & Internet
Loud static noise coming front right speaker on home theater system. I've removed all cables and all speaker wires except that one and still get the noise. I've tried plugging the unit into another...
Make certain you have not started some kind of test signal going by looking in the the user manual, if not by all means send it back. Phone or E-Mail the makers helpline first they should sort any problems and confirm you have set it up right.
Jul 04, 2011 | Audio Players & Recorders
I have the Bose Companion 3 Series II speakers. I ordered them through the Bose website. However, I continuously hear static. Mute, low volume, with music, etc. I hear static noise. The only way to...
I have had totally the same problem before, and I have discovered that it is actually because of the electric current running through the speakers when the volume is low or muted.
I am afraid to tell you that the only solution to this problem is to raise the volume, as it is not a malfunction in the speakers but in the electric current running through them.
Good luck.
Dec 16, 2010 | Bose Companion 3 Series II Multimedia...
My dell inspiron mini 10 is making a random static noise
Muting does not mean turning off the speaker which means there can be occasionel static.
It occurs more if the is a magnet near!!
Dec 28, 2009 | Dell Inspiron Mini 10 Notebook
My monitor is making a electronic noise
u have a problem with electornic circules
Nov 04, 2009 | ViewSonic VX2235wm LCD Monitor
Speaker static noise
The first thing to try is plugging a set of headphones into the speaker plug and testing, see if the crackling continues, if it doesn't it sounds like a short in your speakers (or the sound card, but my guess would be the speakers).
Post your results here so we can further assist you.
Mar 24, 2009 | Gateway Media Center 610XL PC Desktop
Monitor Speaker
Make sure the speaker input from the computer is plugged into the back.
Make sure the volume control is turned up and not muted on the front.
Mar 14, 2008 | Hyundai ImageQuest L70S 17" LCD Monitor
Z-2300 noisy speaker
ur speaker is bad probebly torn membrane try replacing it (or disconnecting) this speaker there is a special kind of glue for membranes .... try it good luck windman
Oct 26, 2005 | Logitech Z-2300 Computer Speakers
Open Questions:
Hyundai L90D+ 19" LCD Monitor Logo
176 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
