Question about Whirlpool GH7155XHS Microwave Oven
Whirlpool Gold 609TAKK14309 69-69E04320-014309 Timer and light work - nothing else
  • jackierfb Jun 04, 2010
    yes, very much - thanks
    Guru:
  • 194 Answers
Hello Jackierfb
Depending on your technical skills , there are basically 4 components which you can check than normally cause this type of error in a microwave.
PLEASE READ HERE HOW TO DISCHARGE YOUR CAPACITOR AND SAFETY PRECAUTIONS BEFORE DOING ANYTHING!!!
Firstly , check to see if your microwave is fitted with a fuse. This will normally be located inside the casing and it is not very common for a microwave to have a fuse , so don't worry if you can't find one. If you are in doubt , let me know and I will look up to see if there is a fuse for you to check. The fact that the timer and the light is still working means that it's probably not the fuse anyway , so let's continue.
Open the casing of you microwave and look at the back right of the unit for the following.
HV Diode is located near the power supply and is identified with a symbol like in the picture below.
CLICK FOR IMAGE
Check the diode for physical damage like a crack , bulge , burst or burned smell as they normally fail physically. To test , set a multimeter to test resistance at 10k ohms and test. A normal diode should read 50-200 k ohms. If not , replace the diode as it has gone. Remember that the polarity is important , so test it both ways (or put positive to anode of diode)
Next component to check is the HV Filter Capacitor. This component is a big circular steel tube on the board/mounted near the HV diode.
Locate and remove any leads going to the capacitor AFTER DISCHARGING THE CAPACITOR.
Now , set you multimeter to resistance again to the highest available setting. Now put it onto the terminals for a few moments (Should read infinite) and then switch the leads around. The reading should go to almost zero and then go back to infinite. Also test between each terminal and the casing (if not covered in plastic) and this reading should be also be infinity. This test might not work if your multimeter is digital and has a very high latency. If it's a good quality multimeter , it should work fine.
Also inspect the capacitor for bulges , leaking , a strong burnt smell or a crack and replace if any of the test fail. These capacitors are designed to fail at the top of the capacitor where steel is visible , so check here especially.
If neither the Diode or the Capacitor is defective , by process of illimination , the only thing left is the Magnetron. Depending on how expensive your oven was it may not be worth replacing as it's a expensive component. In your case , it would cost about $75-$150 for the magnetron , so you might just want to buy a new oven.
Most of these components can be found at radio shack (diode and capacitor) or www.repairclinic.com. If not , contact Whirlpool directly.
Feel free to ask if you need more info or have any questions.
Kind Regards
StephanSA
Posted on Jun 04, 2010
  • Stephan Reichert
    Stephan Reichert Jun 04, 2010
    It's a pleasure. Please do not hesitate to ask my if you get stuck or need some advice doing any of the steps.
    Kind Regards
    StephanSA
My whirlpool gold GT4185SKQ-2 microwave won't heat
It's not door switch. It's the microwaves are not being produced. Do to safety issues DO NOT take apart. Replace
Jul 24, 2014 | Whirlpool Microwave Ovens
I have a Whirlpool Gold top-mount fridge (GR2SH/GR2SHM). It's about 6 years old. About a year ago the freezer started to have ice build up and water would over flow into the fridge. I defrost the...
The defrost cycle is not working. After a predetermined number of hours of compressor running time, a timer actuates the defrost cycle, which stops the compressor and turns on a heating element to melt the ice. Either the timer or heating element is not working. Also, make sure the melted ice water is actually draining and not re-freezing.
Aug 31, 2017 | Whirlpool Microwave Ovens
My whirlpool gold gt4175sps lights up and the control panel works but the turntable does not spin and it does not cook. No fan or cooking noise
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 16, 2011 | Whirlpool GT4175SPS Stainless Steel 1200...
Whirlpool gold accuwave microwave oven lost power afer running em
Hello Davisaroundt, we are sorry to hear about your Microwave not powering on. If you would like for us to schedule service for you, then can you please email your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 13, 2017 | Whirlpool Accuwave Microwave Oven
Whirlpool gold series model gh7155xhs-1 buttons not functioning
Remove power to unit, wait 3 min. Plug unit back again try using touch control, If it still not working replace controller assembly, touch pad and board.
Sep 17, 2009 | Whirlpool GH7155XHS Microwave Oven
Microwave wont start
go to repair clinic .com or similar site.Will need make model # serial#
Jan 07, 2009 | Microwave Ovens
Whirlpool GH7155XHS Microwave Oven Logo
56 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
