Question about Garden
While mowing it started 'jerking' going forward (John Deere RX75)
While mowing it started 'jerking' and continues to do so. Does not **** while moving in reverse. Shortly before I had tightened the brake a little, but made sure I could still push it fairly easily. It acts as if the belt slips repeatedly OR maybe a gear tooth broke in the transaxle? Previous history: last summer the local authorized dealer replaced the gears assy in the transaxle because the shifter pin broke twice. Been working well since. I'm hoping I just need to adjust a belt or a guide or something like that. Looked in the operator and service manuals, but no t/s for this prob desc.
    Scholar:
  • 38 Answers
If this is a MTD rider, (troybilt, yard man, yardmachine,. bolens, cub, etc) the transmission is likely a single gear forward and reverse with a variable speed pulley mechanism with two transmission belts, these trans are prone to failures of the gear clutch which is a dog style clutch with some small teeth that engage the gear plates, these teeth can wear off on one side resulting in the popping or chattering while retaining full functionality for the other direction, this is the gear set inside the transaxle and is usually an indicator of significant wear inside the axle housing itself, usually entire transaxle replacement is the most common and effective repair solution.
Posted on Jun 04, 2010
John Deere 360 will not go in forward or reverse Why not?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Apr 17, 2016 | John Deere Garden
My john deere gx75 don't go into reverse and when i put forward gear i hear a noise like a tic tic tic...
It sounds like the spider gears inside transaxle is worn or broken causing noise and causing reverse not to work.
Oct 16, 2013 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Transmission problem
Hi Dan, if the pulley on the transmission is turning the transmission will need to be pulled down and checked. Regards Phil.
Aug 21, 2012 | John Deere Original 130 160 165 175 180...
John deere riding mower will not go forwards or backwards and was just mowing yard with it. it will start it will cut grass but will not move now help
If it is the belt driven version you should have a deck belt and a drive belt. The drive belt is under the engine. If you have the hydraulic version check for a broken linkage at the pump.
Apr 22, 2012 | John Deere Garden
JD SRX75 - when push lever forward or back, tractor does not move..
check the lever on the rear of the tractor used to puch the unit when not running then check the belt
Mar 31, 2012 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
I have a L118 John Deere mower. When cold, the mower moves forward and reverse without problems. I mow my 1/2 acre yard and at the last couple passes, the mower barely moves forward and has no reverse. ...
Hi, remove the battery and battery support tray and clean all debris from around the hydrostatic drive, fan and cooling fins. Your problem is caused by the hydrostatic drive overheating. Hope this helps, regards Phil
May 23, 2011 | John Deere Garden
Lost the bolt/nut to my riding lawn mower!
That is a cap screw you are talking about. The size of it is 7/16" X 1-3/4". The John Deere part # is 19H2563, but I am sure you can just get one at the local hardware store. I could not find out for sure, but on most blades they use a fine-thread bolt/screw. If you can tell the difference, check before you buy, or just buy both and see which one threads in easily. Hope all this helps.
Mar 31, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
893 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
