Question about Texas Instruments TI-84 Plus Calculator
Wrong answer produced in sin / cos problems?
5sin(x)+1 = 0 should equal about 3.343 or 4.365, but my calculator gives me an answer of -11.537...
I know that I am doing all of the steps right...
5sin(x) = -1
5
sin^(-1) (-.2) should not equal -11.537. whats wrong with my calculator?
5sin(x)+1 = 0 is the equation you want to solve?
so
5sin(x) = -1
sin(x) = -(1/5)
arcsin( sin(x) ) = arcsin( -(1/5) )
x = -.201 (radians)
x = -11.5369 (degrees)
Posted on Jun 04, 2010
My calculator is not computing sin^-1 or cos^-1 correctly, I put sin^-1(0.184) in and it came out with 10.60283... when I should be getting 1.39. HALP?
When the angle unit is in radians
sin^-1(0.184)=0.1850543940 radians
When angle unit is in degrees
sin^-1(0.185)=10.60283581
Your calculator is calculating the functions correctly)
In the following screen captures the sine of the values is calculated with the unit specified inside the formula (degree symbol and radian symbol are inserted to show you the unit). In the last calculation the value of the sine is practically 0.184
Remember that when angle is in radians, for very small angles (less than 10 degrees), sin(x) and tan (x) are about equal to the value of the angle in radians
Mar 25, 2014 | Casio FX-115ES Scientific Calculator
My TI-30XB WONT CALCULATE INVERSE COS OR INVERSE SIN
Does it refuse to do so or does it give an error message?
Three common errors:
  1. Not having the correct angle unit. Wrong result, No error message
  2. Confusing reciprocal of sine (1/sin(x) with arc sine (x) ,sin^-1(x). Confusing the reciprocal of cosine, 1/cos(x) with arc cosine (cos^-1(x)). Wrong result, No error message
  3. Taking the argument of the inverse sine and/or inverse cosine functions outside the interval [-1,1]. This gives a domain error.
Oct 28, 2013 | Texas Instruments TI-81 Calculator
Cot(x) = -0.6
Let's start with a little background.
The cot(x) is also known as the cotangent(x) and it equals 1/tan(x) which equals cos(x)/sin(x). I'm showing these formulas because your calculator may not have a cot button but it will probably have buttons for tan, cos, and sin.
Your calculator may also have buttons for tan-1, cos-1 and sin-1. These are the inverse functions for tan, cos, and sin. If you enter a number and then push the tan-1 button, the result is the angle whose tangent is the entered number. For example, it you enter 1 and push the tan-1 button the answer will be 45 deg because tan (45 deg) = 1.
Now let's look at the problem, cot(x) = -0.6.
The first thing we need to know is do you want the answer in degrees or radians? Your calculator will have both modes. The default mode when you first turn it on is probably degrees. If this problem is in radians you will need to change the mode of your calculator over to radians before we start.
If cot(x) = -0.6, then tan(x) = 1/-0.6 from the formula I showed in the background section.
This means tan(x) = -1.6666666...
Now we just enter -1.66666667 and hit the tan-1 button to get the answer.
If we're operating in radians the answer is -1.0307 radians.
If we're operating in degrees the answer is -59.036 deg.
I hope this helps you out.
Dec 06, 2011 | SoftMath Algebrator - Algebra Homework...
How do i enter this question on a ti 89? 5 sin(2 pi 2000 t +60 degrees) does anybody know i would appreciate it.
Hi ssmith63,
Put the calculator in radian angle mode. The top answer is in AUTO mode and, The bottom is in Approx mode.
I converted 60 degrees into pi/3 radian which equals 1.0472 radians. I figured 5 significant digits was good enough since, you only went 4. If you have any question just post them and, I'll respond quickly.
Jan 15, 2011 | Texas Instruments TI-89 Calculator
TI89 is giving wrong answer for the integral of sec(x). Please help. It gives the answer as: ln[ |cos(x) / (sin(x)-1)| ] when it should be ln[ |(sin(x)-1) / cos(x)| ]. Why is it giving the wrong...
Hi danagasta,
If my last instructions did not work then you need to reset your RAM. You are missing the negative sign and, I have no idea where you got the absolute value inside the brackets.
Yes, the absolute value are used in books and, on integral tables but, I can asure you that the Ti 89 should not have produce them in this answer.
I'll stand behind that In( -cos(x) / (sin(x)-1)) is the correct answer. You can go ahead and simplify after the calculation to get the answer you want but, that is the good answer that Ti 89 is going to give you for the integral of sec(x).
Errors that do not match the suspected, I am pretty sure that Texas Instruments would have you clear the RAM. I do not like resetting the RAM but, I could not find the cause to why you got the answer you did. And so far no other expert has produced a solution to convince me otherwise.
I was not able to come up with any of the 3 answers MiB8888 did on my Ti 89. I am not saying that they are not good answers, they are book and integral tables answers. You are not going to get them on the Ti 89.
Jan 04, 2011 | Texas Instruments TI-89 Calculator
How to use trig function keys on my casio fx-300ES
You have 3 keys for the main trigonometric functions: [SIN], [COS] and [TAN]
To use them correctly you must set the angle unit to the one your problem calls for.
Press [SIFT][MODE] [3:Deg] for degree, [4:Rad] for radian, [5:Grad] for grad. Dependig on angle unit chosen a small D, R, or G appears on the top of the screen.
If you need the inverse trigonometric functions arcsine, arccosine, arctangent, you access them by first pressing the [SHIFT] key
Thus
arcsine [SHIFT][SIN] (sin^-1)
arcosine [SHIFT][COS] (cos^-1)
arctangent [SHIFT][TAN] (tan^-1)
The syntax for the function is
[SIN] # [ ) ] [=]; [SIN] 30 [ ) ] [=] gives 0.5
[COS] # [ ) ] [=] [COS] 19 [ ) ] [=] gives 0.945518576
Note: if the argument of the functions are numbers, the right parenthesis is not necessary. But if the argument is an expression (with various operations) better put the parenthesis to make sure the calculator is performing as one wants it to.
By the way, there are no keys, or key combinations to calculate cotangent, cosecant, and secant, but you can use the definitions:
cotangent (x) = 1/tan(x) Do not confuse it with tan^-1
cosecant(x) = 1/sin(x) Do not confuse it with sin^-1
secant(x) = 1/cos(x) Do not confuse it with cos^-1
Hope it helps.
Oct 30, 2009 | Casio fx-300ES Calculator
How do i find inv for sin,i have tried the mode Deg 1 but i keep getting the wrong answer. can you help? Eg 0.6339869 INV cos ans should be 50.655113.
You didn't specify what calculator you have.
On my TI30XA, 0.6339869 '2nd' 'COS-1' gives 50.655114
On my Windows XP calculator, 0.6339869 'Inv' 'cos' gives 50.655114
On a Casio FX-300ES, 0.6339869 'Shift' 'cos-1'
I hope one of these helps. If not, let me know what calculator you have and I'll figure it out.
Sep 08, 2009 | Office Equipment & Supplies
Tan Cos and Sin errors
go to:
mode
select DEGREE rather than RADIAN three lines down.
Aug 20, 2008 | Texas Instruments TI-84 Plus Silver...
SIN COS TAN
The answer that you have received in actuality is correct. However, it is in exact form when the answer that you were looking for was an approximation (decimal form) answer. To achieve this all you have to do is hit the alpha button (the yellow button with a diamond in the center) and then enter which will give you your desired answer :-)
Jan 14, 2008 | Texas Instruments TI-89 Calculator
Need help withe the sin, cos, tan problem with ti - 83 plus
here are the steps in changing it from radian to degrees
1. turn on your TI-83 plus
2. press the MODE button near the top of your calculator
3.go down to options and move the highlight from radian to degree, press enter and clear
you're good to go
Feb 17, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
283 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
