Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
The washing machine stopped in mid-cycle and won't drain.
Won't drain
  • Bosch Master
  • 2,605 Answers
Hello langdon, welcome to fixya.
What you may have based on your brief description is either a clogged pump, improper detergent being used, ( must use "HE"/lo-sudsing detergent ) hence suds not allowing a proper drain cycle, or wires loose at the pump...the later being the least likely.
Taking all this into account It is strange you aren`t receiving an E13 code, but anyway.
You haven`t mentioned if you`ve checked the pump...so here`s what I suggest.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
  1. Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, be careful you could get wet. ( unless you`re lucky enough to be close to a floor drain )
  2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)
  3. Find a drill bit or small screwdriver that fits in the hole in the round door.
  4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful or wear chain-mail gloves).
  5. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a red ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan ) There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out.
  6. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.
  7. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
  8. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "fixya" and good luck.
macmarkus :)
Posted on Jun 04, 2010
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Washer stops between wash and rinse, and stays full of water. ld code
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 21, 2013 | Kenmore Washing Machines
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Maytag heavy duty super capacity washer - stopped mid cycle. Won't drain water. Won't agitate. Water fill function works. Any ideas what to check? Do you know where the fuse is located?
It is a computer problem. My daughters machine did the same thing and the company came out and replaced the computer board and it fixed the problem.
Jul 16, 2011 | Maytag Washing Machines
Our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
Washing machine keeps stopping mid cycle
If you found coins and such in the drain filter then there is a possiblility that the impeller in the drain pump motor was damaged and you are not getting good water flow thru it. The machine will error out and stop mid cycle if it detects it has not drained in a set amount of time. OE indicated a drain error. I suspect you need to have the drain pump motor assembly replaced.
Nov 20, 2008 | LG WD-1280FHD Front Load Washer
Stops mid cycle
CHECK DRAIN PUMP AND DRAIN HOSE FOR RESTRICTION
Jun 01, 2008 | Fisher and Paykel GWL11 Top Load Washer
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
106 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
