Question about Kodak ESP 5 Printer
Printer paper is jammed. Is there a release?
This is a Kodak ESP5 printer.
  • 29 Answers
Is there a... what? you didnt provide additional information, and you left the question unfinished. is there a way to remove the paper? is there a solution? yes. the paper can be removed. but i dont have enough information.
Product summary The good: Improved photo quality over previous model; attractive design; large 3-inch LCD screen; easy-to-use Home Center software.
The bad: Poor quality build with several mechanical errors; average print speed; graphics quality still lacks definition.
The bottom line: The Kodak ESP5 is an attractive full color all-in-one printer, scanner, and copier, and casual photo enthusiasts will be happy with the watered-down editing software, but hard-core users should look elsewhere for a multifunction printer. The ESP5 is too expensive and suffers from too many mechanical deficiencies for us to give it our CNET stamp of approval.
you will continue to have these paper jams.
Posted on Jun 04, 2010
How to fix paper jam in kokdak esp5 printer
www.kodak.com/go/itg
Select all-in-one printer
Select paper jam and follow the steps
Jan 15, 2010 | Kodak ESP 5 Printer
I have a ESP5 printer. There is an error message that says I have a paper jam, but I cannot find any paper.
A Piece of Paper may be in there. Find out it by replacing Catridge. Off the printer switch, See inside, out the paper from tray. Then keep it one by one.On Printer
Dec 10, 2009 | Kodak ESP 5 Printer
How do I clear a piece of paper jammed in my Kodak ESP5 All in one printer
1 Lift the output tray.
2 Open the paper trays and remove any paper.
3 Turn OFF your printer.
4 Wait 30 seconds, and then disconnect the following from the back of your printer: USB cable, Ethernet cable, Fax cable, AC power cord.
CAUTION: Do not use force when removing the paper from the printer.
5 Check inside the cleanout area for a paper jam. If necessary, remove any paper or debris.
6 If paper is not visible, check the printer for foreign objects, such as paper clips or staples. If necessary, carefully remove the foreign objects from your printer.
7 Open the printer access door.
8 Remove any foreign objects from the printhead access area, and then close the printer access door.
9 Connect the following to the back of your printer: USB cable, Ethernet cable, Fax cable, AC power cord.
10 Wait 30 seconds, and then turn ON the printer.
11 Squeeze and move the paper-width guide on the paper tray to the left.
12 Load the paper into the upper paper tray.
13 Squeeze and move the paper-width guide to the right until it touches the paper.
14 Close the paper tray.
Best of Luck
saj
Nov 02, 2009 | Kodak ESP 5 Printer
My Kodak ESP5 AiO printer has its print head stuck at its right.
Dear Sir/Ma'am,
• To resolve this issue remove the cartridges and then the printhead (Upon removing the cartridges look into the slot where the black cartridge fitted into. On the vertical wall at the back you will see two small contact points. Place your finger above those points on the black plastic and run your finger towards the top of the printhead. You will feel a little button and by pressing it , it will release the printhead.)
• Remove power
• Please now check for any objects or paper that might be obstructing the movement of the printer carriage - if any are found please remove them
• Wait 5-7 minutes
• Reinsert power
• Reinsert printhead (When inserting the Printhead please ensure that you hear it click into place)
• Then re-insert cartridges, black first then colour.Please also ensure that you hear them clip into place
Regards,
CViveiros
Oct 24, 2009 | Kodak ESP 5 Printer
Kodak ESP5, duplex, only prints first side
You can try ressting the settingson the printer By going to Menu -> Printer settings -> Reset All settings and hit Ok.
If the issue persists, try upgrading the printer software and the firmware. The link for the upgrade is kodak.com/go/esp5downloads
Oct 07, 2009 | Office Equipment & Supplies
Kodak printer esp.3 ...paper jammed
u should only use kodak inkjet papers with size plain paper, coated paper, photo paper, iron-on, transparency film, label media, greeting cards, 20 to 24 lb. plain paper. open back access door of printer by pulling out the latch on back of printer. remove paper-jam from the rollers. u can find manual for ur printer onwww.kodak.com/go/manuals.
Jul 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP5 Printer - actual paper jam
you can pull it out from front and if you don't want pul it out from front just open up the cover of roller then take off the paper.
you are done
Good luck
Feb 09, 2009 | Office Equipment & Supplies
Paper Jam
on the back release the cover and pull it out. you cant release the tension.
Jan 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My Kodak ESP5 keeps saying "Paper Jam please remove paper jam" But there is no paper in it?
My esp 5 gave me this same message. I'm not an expert but here is what worked for me.
I turned off and disconnected both cables (usb and power) then reconnected and turned on.
At this point it still read paper jam, so I took ink cartridges out and paper out.
I then reinstalled ink cartridges and PULLED OUT THE PAPER TRAY to it's FULL capacity, added about 5 sheets of paper, and on the main menu I chose the allignment function and printed a test page and suddenly....no jam!
Hope this works for someone. For some reason pulling the tray all the way out cleared the "jam" message for me. Now if I could just get the new ink cart to work I'd be all set! Good Luck!
Dec 20, 2008 | Kodak ESP 5 Printer
Kodak ESP 5 Printer Logo
179 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
