Question about Maytag 24 in. MDBH950AWS Built-in Dishwasher
Dishwasher makes noise as if something is is pump. Dishes come out not clean.
  • Maytag Master
  • 12,061 Answers
Http://www.servicematters.com/maytag_library/docs/16021814.pdf
Hi, please find above your service and repair manual. What you describe, could be one of a few things, please use the manual above and perform the troubleshooting steps, this will soon zero you in on your problem, and it also shows how to repair the problem too. This link below is a troubleshooting tool, between this and the manual, you should be OK. Often things get stuck in the pump, it is a pretty simple task, to open it all up and clean the pump out. Good Luck.
http://www.acmehowto.com/howto/appliance/dishwasher/diagnose-dishwasher.php
Of course if you feel you do not wish to service it yourself. Please contact a Maytag professional, always ask for a "Quote" before proceeding with any repair.
Posted on Jun 04, 2010
Dishwasher isn't draining completely and dishes aren't getting washed clean. There is also a grinding noise during parts of the cvcle.
Pump clogged with filth. Always rinse dishes or at least scrape them off befor putting them in a dishwasher. I hope the pump isnt shot.
Oct 11, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
2 year old stainless steel dishwasher making weird sounds
are u hearing any metal grinding sounds or is it making a noise like something is breaking theres a pump located down the bottom of the unit and depending on how you wash your dishes for example if you wash them before you insert them into the dishwasher or if you put them in with food on them would consitute your next course of action if you do insert them with food on them then you would need to check the pump and the chopper area you might want to call a technician if the problem persists. hope this helps try running it through the full cycle if tere is something wrong you will get an error code
Jul 13, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
I mistakenly used laundry detergent twice instead of dishwasher detergent. Now using the right detergent it makes a lot of noise. Have I ruined the dishwasher?
run a couple of loads of hot water with no dishes thru it and see if it cleans out the pump,it sound like the pump may be plugged and starving for water,also pull the sump screen and check for any residue
Mar 18, 2010 | Frigidaire PLD4050RHC Builtin Dishwasher
Motor making noise- Kenmore Elite dishwasher
OUCH. Sounds as if your dishwasher pump is bad. Most pumps need to have water in them to keep them cool and or lubricated. it could be an impeller problem and coul be a cheap easy fix. Or it could be a bearing which is a more expensive fix and a little harder to do. I hope this is an older machine and you may want to go ahead and get a new energy star heat saver. Or if it is a new one just repair it.
Aug 16, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Jul 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher not cleaning dishes on top rack
Check the riser tube coming from the pump assembly and be sure it isn't blocked or that something else isn't obstructing the pump intake area. Make sure the upper wah arm assembly isn't excessively loose on the spindle and losing pressure because it's leaking. You may have to remove the lower rack, lower wash arm and cover to see.
If everything is clear, it could be a worn or damaged pump impeller. If the machine drains normally, it's not the motor.
May 16, 2009 | Dishwashers
Dishes not clean enough. as if rinsing in dirty
If your dishwasher drains it's water to a garbage disposal, give the disposal a spin while the dishwasher is pumping out. Check around the bottom of the dishwasher to make sure something is not clogging the drain.
May 01, 2009 | Kenmore Dishwashers
Maytag 24 in. MDBH950AWS Built-in Dishwasher Logo
56 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
