Question about Maytag Neptune MDE5500AY Electric Dryer
Change 3 prong to 4 prong plug
Which colors go on which connections?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check this picture which will sort out everything for you:
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 04, 2010
How to wire a plug
In USA, Either the male or female plug connector would be wired the same. Black is hot wire and would connect to the BRASS colored round head screw ( Smallest flat prong or slot ). White is the neutral wire and would connect to the SILVER colored round head screw ( Largest flat prong or slot ). Green is the ground wire and would connect to the GREEN screw ( ONLY HEX shaped screw ). 1) FOR YOUR LIFE SAFETY, ALWAYS USE 3-WIIRE PLUGS WHEN REPAIRING 3-WIRE EXTENSION CORDS! 2) Check the male plug connector. It should have two flat and one rounded prong. The rounded prong is the ground wire connection. If the ground prong is missing, replace the plug. 3) Inspect the outer cover for damage. 4) Do not use cords with damaged outer covers. Taping over the damage is not an adequate repair, for safety, replace the cord.
Apr 04, 2014 | Woods Industries 12/3X100FT Yellow Jacket...
I have a FEQ1442es dryer. I need to change it from a 4 pronged plug to a three prong, as that is what outlet my condo has... Is there any special order etc. in which to attatch the connections on the...
The 4-prong plug has red, black, white, and green/yellow wires while the 3-prong plug has red, black, and white wires. The only difference is the green/yellow (ground) wire of the 4-prong plug which is attached to the dryer cabinet. All you have to do is connect the wires of the 3-prong plug in the same way the same wire colors are connected with the 4-prong plug then connect the terminal on the cabinet, where the green/yellow (ground) wire of the 4-prong plug is formerly connected, to the white wire of the 3-prong plug.
Feb 12, 2011 | Frigidaire FEQ1442ES Electric Dryer
Can you take a dryer that has a 4 prog plug and put a 3 prong plug on it?
Yes, you can put a 3-prong plug in place of the 4-prong plug.
Feb 04, 2011 | Maytag Dryers
Need to change from 3 prong cord to
disconnect the green or brass ground strap from the terminal block to the body then wire the new plugs three colors the same as the old then connect the green from the plug strait to the body. on a 3 wire the dryer is grounded through the neutral, on a 4 wire the ground goes to the body.
Dec 02, 2009 | Dryers
I am trying to change a 3 prong dryer plug to a 4 prong
You are correct, the green wire is ground. You may be able to connect to the same location as the green wire from the unit.
The white is neutral and the red and black are both 110V (your unit uses 220V).
Here is a link to a picture. I hope it helps:
http://repair2000.com/cord.html
Sep 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
Change fr 3 prongs to 4
They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
Dec 27, 2008 | Frigidaire GLEQ642A Electric Dryer
I've since moved and in the new house the dryer cord had a 3 pronge plug. The one that I need in the new house is a a 4 pronge plug. I purchased one, took off the 3 pronge plug without looking at the...
Yes, it does matter which color wires are connected. If connected wrong, you may injure yourself and/or destroy the dryer. The following link explains how to convert your dryer plug:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Let me know if you have any further questions. I hope this helps you.
Aug 07, 2008 | Dryers
MAYTAG DRYER ELECTRICAL CONNECTION
how do you change a 3 prong plug to a 4 prong plug when the colors dont match on the wires to the dryer?colors on the wires are red white black and green. colors on the terminal of the dryer are a black and yellow tied together a white in the middle and 2 blues tied together. this is a maytag atlantis dryer. thankyou chad....
Jul 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
148 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
