Question about Frigidaire FRS23KF5C Side by Side Refrigerator
Frig or freezer is not cooling
The freezer froze, due to ice maker leak, so i thawed it out. i turned everything back on and now it wont cool/ freeze??? HELP!!
  • Frigidaire Master
  • 1,606 Answers
Tap on the freezer knob and see if refrig comes on . If so , replace the freezer thermostat ( piece with the knob ) .
Posted on Jun 04, 2010
I have water leaking under freezer side of door. I turned the ice maker off, turned off the water to the fridge, cleaned out the ice behind the panels, and put it all back together. Every couple of days I...
Hi, The drain hole is plugged with debris or ice...
Just had to thaw my own out tonight, it was doing the same thing... Take the bottom draw out and maybe the bottom shelf and then you will see the ice buidup in the back and on the floor... Thaw it out and make sure the drain hole is open... then you will be okay again...
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 25, 2011 | Maytag MSD2651 HE Side by Side...
The freezer is working fine but the refrigerator part is warm on the coldest setting and the door has been shut for more than 8 hours.
Hi, I have seen this a lot in my 13 years in maintenance work, the most likely problem is ice build up in back of freezer behind the plastic liner.The drian tub freezes over and when the frig goes into defrost cycle the melted ice has know place to go and covers the air holes that blows into frig to keep it cool. You my have noticed water in the bottom of frig. You will have to either take freezer apart inside and remove ice and thaw out drain tube or unplug frig to thaw it out.
Mar 05, 2011 | Refrigerators
Refrigerator not cooling below 55 degrees. Freezer works fine. Coils under refrigerator are clean and compressor is running.
Check the defrost timer, it may be out, if the coils in you freezer are all froze over with ice it may stop your fan from circulating the cool air to the frig side, this is cause by the defrost time not working. It will need to be replaced. You will need the model number and to thaw the coils with a heater or to unplug the frig while it thaws. If this is your problem call First
Source and provide with model number and ask for a defrost heater. Replace per instructions.
Jul 05, 2009 | Refrigerators
Top half of frig will not cool
the ports are still froze up. you need to allow EVERYTHING to completely melt, and then fire it back up. you have ice lodged in system
Jun 15, 2009 | Refrigerators
Frig and freezer not cooling. Everything is thawing
1/ refrigerant leak or
2/ Defective thermostat / sensor or
3/ Burnt out compressor
Apr 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Any thoughts?
Any noises from frig at all??? cicking humming???pull the unit out and remove back cover. Is the compressor(football)size motor in back hot to touch??Lights are on in frig right?
Feb 26, 2008 | Refrigerators
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS23KF5C Side by Side Refrigerator Logo
75 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
