Question about Rosewill R900J 19" Flat Panel LCD Monitor
My Computer screen goes black at start up. I have a windows xp. I have switched Screens with a working moniter and found out somthing is wrong with the screen. I really need help From, Anynamos
  • 11,361 Answers
Caps in the power supply will be the first suspect.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 04, 2010
On Tumble Bees I can't get zoom to make game board bigger so I can rea d the words.I have poor vision
most browsers have a zoom function which can be found in the view menu at the top of your browser if it is a online game. If it is a game you install the you can use the magnifier program the is installed in microsoft windows if your using microsoft windows you can find it under Start > Accessories > System Tools or Ease of Access
Feb 09, 2012 | Electronic Arts Tumble Bees To Go for...
Have just hooked up my Viewsonic VA720 moniter as the main moniter to a new laptop that I have. The laptop is an ACER Travelmate 6293 running windows XP. When I come to start up my computer each morning...
You most likely have a capacitor that has changed value. When a capacitor goes bad it will work after it heats up. Sometimes a bad cap will have a bulging top or show signs of leakage. Sometimes can only be checked with a meter.
Oct 04, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Amillo pro 2010 screens gone black
Check by rebooting it to BIOS--Press Del or F1 during boot....
Choose F8 option during startup intial stage-Windows
Choose Safe Mode----If it works---then No Problem with Hardware,,but with Operating System--Repair or Reinstall Operating System using Valid XP Serial Key
Oct 01, 2009 | Computers & Internet
When I hook up my moniter it does not work like other moniters.
ok sounds like you have a broken pin on your cable if you look in the end of the cable plug the part thet goes into the box but also check both ends if they are there
failing that take monitor to roof and heave ho away it goes
Jul 25, 2009 | Compaq P 1220 22" CRT Monitor
Delll flat screen moniter goes black.
Assuming you are running XP.  Right click on the desktop, select Properties, select the Screen saver tap.
Click on "Power"
See adjust the time out so that it is  "Never"
May 18, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
The screen turns black and stays like that
Normally it's because the resolution is set too high for the monitor. This has happened to me when I switch a computer from a flat screen to a old "biggy-size" monitor.
try rebooting the computer and BEFORE you see the windows splash screen, start pushing the F8 key...this should bring up a menu...select VGA Mode...it won't be pretty, but once you're in..right click on the desktop and change the solution (try 800x600). restart the machine...that should work.
-SuperDale
May 05, 2009 | Apple Computers & Internet
Moniter Screen Blank when my PC start....Giga byte 8S661FXME-RZ Mother board
try to remove the motherboard from the casing and see it if the have some capacitors or any circuit distroy. use other mother board for testing chek your hardware one by one maybe some of your hardware devices damages.
Jan 01, 2009 | Computers & Internet
Compaq FP 5315 Moniter
Have you checked the computer bios?
In case an item was changed in the BIOS, such as the primary display device setting, use the following steps to reset the BIOS back to its default configuration:
  1. Turn on the computer and press the keyboard key that enters the BIOS Setup screen key when the keyboard light comes on. The key to enter the BIOS should be one of the following:
    • HP and Compaq desktop computers that came with Windows Vista, press F10 .
    • For HP Pavilions desktop computers that came with Windows XP or previous versions of Windows, press F1 .
    • Compaq Presario desktop computers built after 2002, press F1 .
    • Compaq Presario desktop computers built prior to 2002, press F10 .
  2. Wait 5 seconds.
  3. Press the F5 key to restore the default settings of the BIOS.
  4. Press Enter to accept the change and wait five seconds.
  5. Press the F10 and then the Enter key to save the changes and exit from the BIOS.
  6. The monitor should now display the first screens received from the computer (the logo screens). If not, find and download the latest BIOS update if one is available for your computer.
  7. If a BIOS update was not available or the monitor is still blank, continue to the next step
Reseating loose internal components
If the PC case was recently serviced or moved, a card, cable, memory module, or processor may have become loose. When this happens, the PC might make a beeping sound when turned on. Use the following steps to check for loose components: WARNING: The edges of metal panels can cut skin. Be careful not to slide skin along any interior metal edge of the computer. CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Unplug all cables except for the power. Write down each cable location if you do not already know where it connects.
  2. With the power cable removed press the Power button on the front of the PC for 5 seconds.
  3. Remove the screw(s) that retain the panel or cover from the rear of the PC. c00371492.jpg
  5. Gently press down on the outside edges of cards and memory modules that are inserted into the motherboard to better seat them. Do not press too hard.
  6. Gently press down on the connectors of the flat ribbon cables to seat them.
  7. Replace the side panel and screw(s), reconnect the PC cables, and turn on the PC on.
  8. If the monitor still displays a black screen, the video hardware may be faulty and needs to be replaced or serviced. If the monitor displays the first startup screen but does not display Windows, continue to the next step.
Try this and if it doesnt work. please post again.
Oct 21, 2007 | HP Compaq FP5315 15" LCD Monitor
Rosewill R900J 19" Flat Panel LCD Monitor Logo
185 people viewed this question
Top Rosewill Computers & Internet Experts
Ian Ballard
Level 1 Expert
Jim Thurston
Alun Cox
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
