Jun 03, 2010 - I would like too know if the fly back transformer, is suppose to have metal sticking out of the side. Mine has two spots.close too one another.Looks like it tried to seep out. Or is this, the way it's made? one is the size of a pencil lead and the other a small eraser.Its a f36665 36" RCA TV 1999 year.I just wanted to make sure I bought the right part to fix it.The Horizontal IC card didn't seem to look burned anywhere.Is this also called the regulator Ic or is this two different peaces? I had, a power surge, of course the fuse blew. I have too pick one up. All I had was the 1 amp, I need a 5 amp when I plugged it in, the TV sizzled and blew the 1 amp just didn't want to spend A lot of money on TV and still not fix the problem. thanks Rob
You may be on the wrong track here.......fly backs are a common failure,but not because of power surge. Most commonly the problem would be on the primary side of the power supply ,such as the rectifiers and sw mode regulator. If you want to prove it,just un solder the horiz out transistor(q401) and the pin of the flybackit connects to...... and if it still blows fuse ,you need to work on the power supply.......not the horiz/hv area
Testimonial: "thanks for the feed back,very helpful.I saw it spark by some resistors.Just not for sure whats all bad and needs replaced.Does the fly back need to disconnected to work on the board? If so I didn't see a good way to do so thanks rob"
