Question about Veo Stingray
Cd I have works on xp, I have nothing for current o/s windows 7
  • 3,015 Answers
If no driver is available try using the older OS software in Compatibility Mode
Right click on the webcam icon on your desktop or from 'All Programs' - select 'Properties'
Select the Compatibility tab
Select Compatibility Mode
Use the dropbox to show the OS
Click OK
Restart your computer
Posted on Jun 04, 2010
Is the Pandigital SCN02 Photolink One-Touch Scanner compatible with Windows 8?
Are you using it currentrly? What is your current Operating System? I've been searching and can't see anywhate a windows 8 driver for this scanner.
Bu let me tell you, I'm using currently a Genius ColorPage, originally released for windows 98. Installed windows 2000 driver in compatibility mode for findows XP. There is no driver for Windows XP nor for Windows 7 and coldn't make it work in Windows 7. So I run it on a computer with dual bootWindows XP / Windows 7.
When I need to scan, I simply start up as windows XP. When finished scanning, reboot to windows 7
I Have Windows 7 on a 2 Tb HD SATA and Windows XP on 200 Mb IDE. Is more economical to have a dual boot then buy a new Scanner.
If your scanner won't run on windows 8, install on another HD or a partiton, Windows 7. doual boot Windows 7 / 8 work like a dream.
See comments for this scanner in Amazon;
Amazon com Customer Reviews Pandigital SCN02 Photolink One Touch Scanner...
Jun 11, 2015 | PANDIGITAL Office Equipment & Supplies
Hi, my CD/DVD ROM for compaq D510 SFF is only able to read "set-up" files(I mean the ones with an 'exe' extension), but it can not read or play music/video Disks..I previously loaded Win XP but now I...
Oh mind you that other computers or systems are only designed for Windows XP and the Drivers that are installed on that machine are XP compartible. Now that you are using windows 7, it could be an issue that Windows 7 operating system does not recognize the device being your CD drive.. You need to go on the HP official website and look for the drivers (the whole packge ) for your computer model and check if Windows 7 operating system is compartible with the machine. Otherwise the solution is to go back to Windows XP...
Jan 14, 2014 | Compaq Computers & Internet
I have an hp mini 210-1041nr running win xp and when I start it, the computer tells me Windows\System32\Config\System missing. I tried service pack 3 but it didn't work. Can u please help?
You need to get a Windows XP from someone and follow these instructions:
Windows could not start because the following files is missing or corrupt
\WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
1. Insert and boot from your Windows XP CD.
2. At the first R=Repair option, press the R key
3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
4. Enter in the administrator password when requested
5. cd \windows\system32\config
6. Depending on which section was corrupted:
ren software software.bad or ren system system.bad
7. Depending on which section was corrupted
copy \windows\repair\system
copy \windows\repair\software
8. Take out the CD ROM and type exit
If that doesn't work or you can't get into the repair console then With the XP disk you choose to install Windows XP and when you choose to install over the current XP installation you will be given the option to repair the current Windows installation and you won't lose all of your data.
Mar 01, 2011 | Computers & Internet
How do I format C drive with windows 7 on it I want to put windows XP on
hi
thank you for using Fixya
to formate C drive and re install windows XP
1 put widows XP CD in to your CD drive
2 restart your PC
3 it will boot your CD just put Enter
4 if not then selact boot option by presing F12 0r F2
5 it will start reding your CD
then just folow the instruction
it will ask you foue setps
May 16, 2010 | Compaq Presario CQ60-220US PC Laptop
My lap top will not turn on giving error message windowssystem32congfigsystem
Copy \windows\repair\system
Copy \windows\repair\software
And Thanks.
Mar 18, 2010 | Computers & Internet
Nightmare ned CD/ROM
This software was released long before Win7 was being worked on. Thus it isn't going to work directly in Win7; Microsoft has changed a lot in the OS. However, with a bit of work and either Win7 Pro or Ultimate, there is a workaround. Install the XP mode program from Microsoft (it's a two download process) and create a virtual computer inside your main computer. You should be able to install and run the game within the virtual computer.
I hope this helps.
Jan 24, 2010 | Microsoft Windows XP Home Edition
Toshiba a200/205 series Hard disk is toshiba mk1246gsx need compatible driver for windows xp I need to convert my OS from vista to XP
Well... this is common on newer laptops. It is due to the fact your HDD is SATA (Serial ATA) and Windows XP CD does not have the drivers needed to recognize it. The solution I use is a bit High Tech: to remaster your Windows XP CD including the drivers needed. Or, just settle to live with Vista until January, when Windows 7 will be available to the public. If you are not faint of heart, google this: nLite; with this program you can remaster your XP CD. (You need a working PC with CD-RW to actually do the job).
Apr 14, 2009 | Toshiba Satellite A135-S2386 Notebook...
Samsung Cd-R/RW drive
is this for music cd's or dvd's too?
Feb 25, 2008 | Computers & Internet
Veo Stingray Logo
71 people viewed this question
Top Veo Computers & Internet Experts
micky dee
Lyle Siemens
Lyle Siemens
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
