Question about Panasonic Workio DP-150PA Copier
Panasonic DP-150PA Light Copies to no copies
Our workio machine has all of a sudden started to make a light copy or print at the top of the page to nothing toward the bottom, we replaced the toner and it does the exact same thing with the new toner, we get no error messages and prints and copies without noise or errors, just nothing is coming out really on the page.
DB - Pueblo, CO
    President:
  • 2,072 Answers
Have you reseated the drum and toner?
It can be a drum cartridge problem. have you tried that?
You say copy or print, so I am asuming this is multifunction and you do both printing and copying.
1, Have you shook up the toner cartridge well.
After the drum and shaking the toner, I would suspect the transfer assembly, Off hand I cant remember of that machine has a transfer roller, or if there is a channel where there is a hair fine wire running through it.
The wire may have broken, or if its a roller making poor contact.
The laser is also possible.The transfer will be on the right had door assembly.
Take the cartridges out and see if there is anything laying loose in the machine,
what you are describing sounds more like a drum or transfer problem.
sounds very much like a defective transfer. And again, could easily be the drum.
Did you have a jam just before this occured? If you had a jam in particular in the right hand door, you broke the transfer wire.
Yeah, i am rambling huh?
Posted on Apr 10, 2008
Hi can i reset my panasonic dp 8020p settings?
Sound like a software issue, recommended you get a pansonic tech out to reload the firmware
Feb 01, 2016 | Panasonic Workio DP-1820E Copier
Panasonic DP-190 copier problem
The printer is obviously good but the scanning software used for making copies must have an issue. Did you check the scanning bulb for proper operation? If bulb is good then the issue lies with the scanning section of the machine,.
Aug 30, 2017 | Panasonic Workio DP-190 Multifunction...
Workio 150 fax - won't go direct to fax always
You change to the defult setting of your copier sold be set on fax. Try this link and download the operating manual. hopefully this will help you.
http://panasonic.net/pcc/support/mfp/
Jul 07, 2011 | Panasonic Workio DP-150PA Copier
I have Panasonic Workio DP-2310 copier and there were multiple lines the length of the copy .I cleaned entire copy and drum area and installed new toner cartridge now the copies are coming out blank , no...
check you drum charge connection between drum unit and developer unit, two metal strips at back that contact when the two unit are closed. none or bad connection means no charge and then blank copies
Feb 01, 2010 | Panasonic Workio DP-2310 All-In-One Laser...
Dp-1820e rebooting not starting
you may try this:
unplug the network, usb, and fax connection
remove all papers
turn on the machine
press print key
press stop
press 1 for yes to cancel the job (if theres a job queue)
Mar 31, 2008 | Panasonic Workio DP-150PA Copier
Error message on copier
That is a laser unit error. If resetting the machine's power doesn't clear it up, then it means the laser unit is dead/dying. If that's the case, your only choice is to replace the laser unit.
Oct 04, 2007 | Panasonic Workio DP-150PA Copier
there is high voltage or corona probleb in your copier contact any technical person
Aug 27, 2007 | Panasonic Workio DP-150PA Copier
Copier is showing warming up but will not start
the fuser unit has ceased to heat...it has a bad heater. the fuser is a hollow metal roller that usually has a powerful light inside to heat the metal. a continuity test can detect
Mar 21, 2007 | Panasonic Workio DP-150PA Copier
Panasonic DP150 FX Workio information screen is saying "Warming Up"
remove the paper drawer and check at the back of the mc where the cassette was for paper
Panasonic Workio DP-150PA Copier Logo
177 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
