Question about Dell Vostro 1000 Notebook
Cooling fan trouble ....hot hot hot - Dell Vostro 1000 Notebook
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
If your cooling fan gets hot while functioning, basically it is defective. If it is within warranty from the time you bought your product, you can still replace it for new. If it is not within warranty, try to hire for repair at a service center nearest you.
Posted on Jun 04, 2010
When is the electric cooling fan suppose to come on.
The info I looked at was for v6 engine. The fan turns on at 105c or 221 f. If engine is overheating, I'd want to know, how hot in degrees f?
If you turn on ac, the fan may run? The ccrm controls the fan. Check for applicable cooling fan trouble codes? Don't replace anything unless your testing points in that direction.
It may be possible to use jumper wires from battery to connector that goes to fan, for voltage and ground, just to see if fan will run. If it won't run, suspect fan itself. Just to be safe, you might use inline fuse on jumper.
Apr 08, 2016 | 1998 Ford Mustang
Fan comes on and stays on
fan always on even when not hot is a symptom of a cooling system malfunction.
First thing you need to do is to have the car scanned with a engine malfunction light scanner . then you'll get a engine trouble code.
depending on what is the code then search on google for bmw engine trouble code list and repair procedures.
to find out what codes meens go to that link http://www.obd-codes.com/trouble_codes/bmw/.
Jan 12, 2014 | 2009 BMW 320i
Radiator overflow, overheating, fan not working
you should have a heat sender switch on your cooling system that activate your fan it can also be a fuse or the fan it self
Nov 12, 2013 | 2010 Triumph Thunderbird
2004 mazda mpv engine racing and cooling fan not working
coolant temp sensor tells the computer how hot or cold the engine is so it can regulate the idle and fuel mixture, when it fails there usually is no cooling fan and you will have trouble starting the engine and keeping it running.
Oct 08, 2012 | 2004 Mazda MPV
I have a 1996 fordwindstar and i took out the thermostat and its still running hot.can you please help me to trouble shoot the problem?
make sure your cooling fan is coming on , no fan no cool no matter what you do. hope this helps.also make sure the radiator is full of fluid.
Sep 13, 2011 | Ford Windstar Cars & Trucks
How do i check the cooling fan my car is over heating
HOT WIRE COOLING FAN USING JUMPER WIRES TO BATTERY.IF FAN DONT RUN WHEN HOT WIRED FAN MOTOR BAD NEED REPLACING. IF FAN RUN WHEN HOT WIRED. CHECK COOLING FAN FUSE AND RELAY.IF ALL IS GOOD.YOUR ENGINE COOLANT TEMPERATURE SENSOR NOT WORKING.IT CONTROL COOLING FAN AT SET TEMPERATURE IF SENSOR OPEN OR FAULTY THE COOLING FAN WONT TURN ON.CHECK COOLING FAN WIRES FOR DAMAGE.IF ALL STILL CHECK OUT GOOD HAVE VECHICLE SCANNED FOR PCM FAULT.IF IT FAILS NO COOLING FAN WONT TURN ON.
Dec 13, 2010 | Hyundai Elantra Cars & Trucks
Compressor wont start..blows hot air
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | LG LP1200DXR Portable Air Conditioner
1999 Hyndai Accent 1500 cc high cooling water temp.
over heating while stopped usually indicates that the radiator fan is not coming on ...when the engine is running hot you should be able to hear the fan running .. if it doesnt then suspect the thermal switch mounted on the radiator .. make sure the fan turns freely .. the fan is not needed when the car is moving so it wont heat up as long as you are driving .. but will do so when stopped if thats the trouble .. sometimes the thermal switch operates a relay that in turn operates the fan ..that could also cause the trouble ..
Jun 10, 2010 | 1999 Hyundai Accent
M2000 heat causing trouble?
Are the fans clear from dust and debris? this is a major factor, if it keeps freezing you may have partially burnt out the processor or other component.
Mar 26, 2008 | Compaq Presario M2000 Notebook
Dell Vostro 1000 Notebook Logo
128 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
