Question about Uniden Radio Communications
I need the L401 coil labeled LF072 on the outside of the metal shield for a Uniden HR2510 that I am repairing for a friend. The entire daughter-board assembly (B401 PR-119) that the L401 coil is located on would do as well. Anyone got a junk HR2510 that would be willing to sell just these part(s)? I also may need the two large toroid coils located near the MRF 477 RF output transistor on the main motherboard. Please reply asap with any pertinent details concerning these parts. Rick
SOURCE: horizontal output transistor
You can Swap them if they are of the same rating, must check the wattage. cause the width problem & the power transistor become over heat. you can also use both of them in parallel, if they are ok. your tv live longer.....
HAVE A NICE DAY...
Posted on Feb 12, 2008
vrc_tech
  • 109 Answers
SOURCE: uniden hr2510 10 meter lights
Have you tried a different michrophone. If you have then the radio will have either a cold solder joint on the main board or a transister has gone bad. The unit will require service at a local radio shop or send to Uniden Service center.
Pat N5SLI
Posted on Aug 27, 2008
Sea Breeze
  • 4655 Answers
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Posted on Aug 05, 2009
SOURCE: kenmore 52552100 refrigerator not working
Hello.... do you still have the parts??
I can use Part 921526 PC Board kit, emitter & reciever icemaker - $30.
You can email me at durangoboy@xemaps.com
Thanks,
Paul
Posted on Jul 03, 2010
Grubhead
  • 5487 Answers
SOURCE: The mains input fuse (4amp) and a (1amp) fuse on
The cheapest option is to replace the transistors (a quick check on google will tell you how much they are). If they are common transistors you will be able to find them and get them quicker then searching for a board that could be no longer being made.
Posted on Sep 02, 2010
D104m6 wire it to 2510 cb
Pretty sure it can be done but you need a wiring diagram for the radio pinout and the mic. Best leave it to a CB service shop.
Oct 11, 2014 | Uniden 5 Pin Cb Microphone Fits Hr2510 Hr...
Presiden hr2510 vs. galaxy dx33hp2
Galaxy wins on power..... 25 vs 40 to 50 well tuned galaxy. If the question is which should you buy I would go Galaxy. The hr series is awesome however they are old and in need of a lot of restoration and tuning to make you a good radio. Be aware electronic components like capacitors done age well and there are a lot of them them in that hr2510, hr2600 and the Lincoln radios.
Jan 22, 2014 | Uniden Radio Communications
Looking tor owners manual uniden HR 2510 10 meter mobile transciever
Follow the yellow brick road...: http://www.uniden.com.au/resources_main/pdfs/HR2510.PDF
Jun 05, 2011 | Uniden Radio Communications
I have a Uniden/President hr2510 and would like to wire a DM452 echo mic to this radio. I need the proper code.
They are bother a simple 4 pin wire setup. Follow this and you will be good to go. 1 - GROUND SHIELD - BLACK
2 - AUDIO - WHITE / YELLOW
3 - TX - RED
4 - RX - BLUE
Jan 16, 2011 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Dell w3000 will not turn on at first try. Takes many attempts turning it off and on before video comes up. Audio always works and green light is on.
Faulty caps, if you take the back cover off of the monitor, there are 2 boards on the outside edges of the left and right of the monitor. these boards are covered by metal shields. remove the 3 screws on each board shield and slide them off.(careful this can be tricky) on the boards are 2 capacitors that need to be replaced. 4 total, 2 on each board. the capacitors are 150uf at 35 Volts. go to your local electronics repair shop to get the parts and tools needed to do this repair.
make sure to get the polarity of these caps right. stripe side on cap goes to the minus.
Dec 18, 2010 | Dell W3000 30 in. HD-Ready LCD Television
Someone gave me a dell w3000 tv and i hooked up the speakers and cable line and plugged in. the tv button turns on and green light comes on but no picture or sound
I have this tv, and have had the EXACT problem. my solution was simple. just need patience if you take the back cover off of the monitor, there are 2 boards on the outside edges of the left and right of the monitor. these boards are covered by metal shields. remove the 3 screws on each board shield and slide them off.(careful this can be tricky) on the boards are 2 capacitors that need to be replaced. 4 total, 2 on each board. the capacitors are 150uf at 35 Volts. go to your local electronics repair shop to get the parts and tools needed to do this repair.
Aug 04, 2010 | Dell W3000 30 in. HD-Ready LCD Television
I get a green power button, no picture. I have to turn the Dell TV on 6-10 times beofre picture comes up. What is wrong with it?
I have this tv, and have had the EXACT problem. my solution was simple. if you take the back cover off of the monitor, there are 2 boards on the outside edges of the left and right of the monitor. these boards are covered by metal shields. remove the 3 screws on each board shield and slide them off.(careful this can be tricky) on the boards are 2 capacitors that need to be replaced. 4 total, 2 on each board. the capacitors are 150uf at 35 Volts. go to your local electronics repair shop to get the parts and tools needed to do this repair.
make sure to get the polarity of these caps right. stripe side on cap goes to the minus. 1
Mar 28, 2010 | Dell W3000 30 in. HD-Ready LCD Television
Micwiring
Wiring the microphone is as follows:
Sadelta 1-White,2-NC,3-Green,4-Shield, 5-Brown
I hope this helps. If I can assist you any further please add a comment.
Oct 08, 2008 | Radio Communications
Uniden hr2510 10 meter lights up, won't transmit or receive
Pat N5SLI
Aug 26, 2008 | Midland Amateur&Consumer Radio Replacement...
Radio Communications Logo
55 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
