Question about Golden Technologies Golden CompanioN II - 3 Wheel
Scooter will not move
Everything seems to be on but it won't move and it is in drive lock
  • 1 more comment
  • Neil Wood Jun 04, 2010
    Hi. A bit hard to tell what is wrong. Any beeps or flashing lights in a repeating pattern? this will be a fault code. We need a bit better description of the fault, LED's on, and what happened in the days leading up to the fault occuring. Neil.
  • Neil Wood Jun 05, 2010
    Hi. Any flashing LED's or beeps? Does the battery gauge show full charge? How old are the batteries? It is possible that it is a faulty brake solenoid or a stuck brush in the motor. Is the machine stored inside or outside> Neil.
  • ran40gre Jun 05, 2010
    THANK YOU very much for your help, my mother was using an extension cord on the charger. we took it off and plugged the charger to the outlet and it started working everything is ok thank you again.
    Problem Solver:
  • 17 Answers
Start with the batteries. They need to be fully charged for operation. Make sure the brake lever is in the locked position for travel. If all OK check the limit switch on the brake assembly to see if it is functioning properly. If it is not closing, then the scooter thinks the brake lever is in the push mode.
Posted on Jun 06, 2010
Have a borrowed Rascal 250 motorized scooter that seems to be charged as indicator is green but cannot get it to run.
If you can push the scooter freely then have a look at the very back of your scooter near the rear tires. There is a leaver there that needs to be moved into a locked position to engage the system.
Also a scooter will not function if the charger is attached.
Oct 13, 2016 | Health & Beauty
I charged scooter and it still won't move back wheels seem to be locked up
that's normal the wheels r locked if u moved the free wheel lever check to c if its back in lock position if it is and the scooter wont move it might b an electrical problem check to c if its got a reset button ....good luck
Jul 02, 2015 | Health & Beauty
Won't move when drive leaver pushed
go to my group page on facebook wac mobility scooter and i will message you.many thanks billy
Mar 19, 2013 | Pride Victory 4 Wheel Mid-Size Electric...
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
My 150 cc motor scooter won't start
possible choke stuck or a sticking float
Jul 29, 2012 | Roketa 150cc cheap Scooters
Battery fully charged everything works but will not move completley dead
Hi za900
You have several options to consider.
1. Controller is bad. This can only be checked by putting another controller on it. There is no test for controllers.
2. If the charger is bad your scooter will not run.
3. make sure your brake is in the lock position.
4. make sure your scooter is not plugged into the wall.
5. If your brake is bad the scooter won't run.
6. If your Throttle engager is bad the scooter won't run.
Have a tech evaluate for you, too many things could be the problem.
Any durable medical equipment company in your area can help you.
Good Luck
Tim
May 03, 2011 | Electric Mobility Health & Beauty
In Drive position the wheels are locked and in neutral the wheels remain locked and will not spin or free wheel. In drive with the battery in the unit just clicks but does not move, everything works such...
I would suspect that the brake is not releasing causing your problem. When you place the handle in freewheel and you can't push the scooter easily then the brake pad is stuck on the motor housing. If you are able remove the seat and back cover remove the drive wheel on the side of the scooter nearest the freewheel lever usually the right side. you should be able to see the brake attached to the end of the motor with 3 or 4 hex head screws. take the brake off the end of the motor and carefully leave the wiring attached ( don't break or remove the wires going to the brake or the scooter will not run at all) remove the brake and place or tie it up where it won't fall or drag. Put the drive wheel back on and turn the scooter on and see if it will now move. If it moves like it should you will have to replace the brake. You can drive the scooter like this but remember you do not have brakes so the scooter can roll backwards or forward when not on and especially on ramps Hope this helps
Apr 23, 2011 | Drive Medical Drive Falcon 3 Wheel Compact...
The scooter rar wheels locked up nothing moves
hi, if the freewheel lever is jammed which is located on the drive motor, take the rear cover off and make sure the lever is not bent,
you will see how the freewheel lever is mounted under normally a rubber cover on the side of the electric motor ,
Let me know
May 16, 2009 | Pride Mobility Victory 3 Wheel Electric...
Golden Technologies Golden CompanioN II - 3 Wheel  Logo
437 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
