Question about Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher
I have a bad smell must be milk. Can I use bleach
I have a bad smell must be milk. Can I use bleach to clean out without dishes in there. Also I need to know how much too. I misplaced my manual. Thanks Barbara Hamilton
  • 523 Answers
No use tang! a tabel sppon of tang in the dispenser close it then start the dw
Posted on Jun 04, 2010
Sour smell coming from back of fridge on outside
Check the drain pan under unit. Maybe something has got in there. May need to remove the back our go through the front. Can pour a very small amount of bleach our Lysol to kill in the drain pan to kill mold. Hope that helps.
Aug 18, 2012 | Hoover Refrigerators
Why do dishes stink when they come out of dishwasher?
try running the dish washer on the heated cycle and use a quality wash detergent not ordinary washing up liquid
Apr 14, 2017 | Maytag Dishwasher
Odd odor coming out of dishwasher upon opening it. Smells like rotten milk. What is the best cleaning solution?
After a dishwasher is installed the hose rarely comes to mind - unless a problem occurs and a repair person comes out to inspect the job. If the hose was installed improperly, or if it is lying in a position that does not let it drain, stagnant water will create a bad smell. Examine the hose that is probably inside the kitchen cabinet beneath the sink. If the hose is lying in the bottom of the cabinet, it is probably full of water. A film begins to form inside the hose and the odor begins to grow. The next time the dishwasher is used, the stagnant water ends up on dishes, and in the meantime it can cause a bad smell inside of the dishwasher. Hang the hose at an angle on supports in the back of the cabinet. This alone might get rid of the bad smell inside the dishwasher.
Check the Seal
A dirty dishwasher seal can be a source of a bad smell. Before deciding the dishwasher needs to be replaced, check the seal - especially at the bottom. Old food and grime builds up in these areas and can cause a particularly bad smell. Clean it with a solution of diluted bleach and hot soapy water. One teaspoon of bleach for each quart of water is sufficient to kill germs and the odors they create.
NB I decided to add a little bit of vinegar to the machine after I unloaded it. Sure it would smell pretty strong for a while but then the smell would dissipate. Voila! For two weeks now my dishes have not smelled whatsoever.
Jun 23, 2011 | Maytag MDB6709AW Builtin Dishwasher
I had some meat go bad in my freezer. I've cleaned and cleaned with hot water, dish soap, bleach, vanilla extract, oxyclean, and just now tried vinegar, next I will try squeezing lemon and/or placing...
just spray it with 75/25 bleach/water it will kill any germs/smells....
also syringe the drain hole with bleach.(you only needed to wash out with clorine bleach and let it dry to totally clean the unit....)
Jul 30, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Wet clothes after spin cycle and bad mildew smell. I have seen many complaints about mildew smell with He3 & He4 well really frnt loaders in general. The bad mold is so gross and the smell is horrible.
Clean tub boot the best you can with bleach. Then run an empty load with sunlight automatic dish soap (verry little). Then this should clean and freshin the washer up. The best thing to do is not to shut the door on washer when not in use.
Oct 27, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Smell under the unit, kenmore elite model number 44703
Hi: Not knowing your model number I would look where the milk was spilled and see if there is a hole. Possibly behind a panel for the defrost water. If so pour a little clorox bleach ane water in it. If not look for any cracks in the liner of your fridge. Those will expose the foam insulation to absorb the milk and cause odors. Clean them and seal them with teflon tape or a repair kit from the manufacture. On the off chanch the mild spilled to the front of the fridge and leaked behing the front grill the coils there are quite warm and will spoil milk fast. Pull the grill off and clean. I hope this helps, Jeff
Jul 07, 2009 | Refrigerators
Bad smell on dried dishes after being washed.Stale water smell.
Try Running Goo Gone Through It Although It Smells Like Oranges It Removes Stains As Strong As Sap. Also Try Running The Dry Cycle While Its Empty Two Or Three Times.
Jan 06, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Diswasher asko d1716
clean out the food traps in the bottom, assuming the unit has some sort of filter.
then run a cup of bleach in the unit with no dishes. you might need to do this once or twice.
make sure you use fresh bleach.
most bleach dies in strength after only 2 weeks. it will still smell like bleach to some degree, but it will have little effect. most bleach manufacturers add 'scents' to the bleach to hide the degradation characteristics of bleach.
also, you may have a partially blocked air gap.
to determine this, check for water remaining in the bottom of the tub after it drains. left over water will contribute to odor, and negate any sterilization you dishwasher might otherwise try to do.
good luck
mark
Dec 28, 2007 | Asko D1716 Built-in Dishwasher
Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher Logo
183 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
