Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a craftsman lt 2000 I was mowing and put the brake on to pick up a stick, i never left the seat just bent over, then when I put it in forward (hydro stat) the tractor would not go anywhere, I check the belt appears fine the brake does not appear to be sticking I pulled of the back cover and the pulley on the top of the transmission is turning. Any thoughts
    Scholar:
  • 38 Answers
The brake mechanism is likely stuck, if you pull the hydro release rod and attempt to push the mower it should free wheel reasonably well, if it continues dragging then the brake shoes are likely seized, even though the arm may be free
Posted on Jun 04, 2010
Craftsman Garden Tractor 26 HP 6 speed transaxle First mow of the season. mowed 15 ft. pressed in clutch to look behind at how it was mowing let clutch out to go no forward movement. belt seams good.
Make sure the transaxle disengagement lever is not in the neutral position. On most lawn tractors, this lever is a stiff wire -- sometimes with a loop on the end -- that sticks out of a slot above and to the right of the trailer hitch bracket on the rear panel, below the seat. Most tractors move under their own power when the wire is all the way in, and can be rolled around without the engine running when the wire is pulled out.
Apr 10, 2018 | Craftsman Garden
Need free owners manual for a 6 speed craftsman Lt 20000 17.5 HP riding mower
You normally download the Craftsman manuals @
http://www.searspartsdirect.com/
You will the model number from the serial number decal under the seat area. This number usually starts with 917.
Aug 05, 2014 | Craftsman Garden
Craftsman LT 1000 Model: 917.272650 I put a new battery in over the weekend and was running perfect for most of the day Saturday. I got off it to empty the bagger, and as normal, the engine stopped. I...
check to make sure that mower deck drive is not engaged. there is a switch that the lever presses on it must be free. also check for seat switch cables loose or disconnected. Also make sure it is in neutral and not reverse as it may also kill the circuit for safety. Depends on you system for mow backwards. with key on you can short the two large terminals on solenoid to see if starter works. if so you must check all safety switches . try setting park brake before trying to start too.
May 17, 2013 | Garden
Engage blades engine shuts down
if you removed the seat and then placed a fuse in the plug for the saftey switch and then started having this issue . with my experience with the safty switches on the seats most are open as not connected to make a circut when your sitting on the seat or pressure is applied to the seat . try removing the fuse and attempting to start mowing or least ingauge the blades and that should fix your issue ... when removing the origonal seat you just left that curcut open so it can not close and make connection when you get off the seat . so you should be fine after removing the fuse from the socket .. happy mowing
Nov 07, 2011 | Craftsman Garden
WILL NOT START craftman LT1000 YR.2000
most likely the blades are still in the on position,but you have a seat switch, parking brake switch, and the blade switch, also the mow in reverse key switch. if mower dies once you let out the clutch in reverse with blades on and key wrong.
Apr 22, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
My craftsman lawn tractor 42" cut (2007 model) cuts off when i try to engage the cutting blades
You have a safety switch somewhere that is open, like the seat, you have to be in the seat or it will kill the engine, sometimes the clutch has to be in, not moving, sometimes the gear selector in neutral, You have a bunch of safety switches that prevent the mower from spinning if you are not in your seat, not ready, etc. Check them out. Hope this helps.
Apr 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My Craftsman riding lawn mower LT 2000 will mow the grass but will not pick up leaves
worn blades or damage under the deck. look under the deck check for damage on fairings that surround blades
Mar 26, 2010 | Garden
My mower dies when I put it into gear when I am trying to mow. It works fine for my husband. How can I change the level of sensitivity on the seat safety switch? We have a Craftsman DLS 3500 lawn tractor.
The seat is adjustable. Move the seat forward to fit you better. There is no adjustment on the switch itself. You just need to put more weight in the seat.
Nov 23, 2009 | Craftsman Garden
Craftsman LT 2000, model # 917.272234. When I am
what is happening tom is the blades are cutting more than the deck can discharge (spit out) try changing the mowing deck to a higher setting & try that if that works then that is the problem also try cleaning out the top & botton of deck there could be alot of old grass caught under there causing some of it aslo if i can further help e-mail me wade at wadembly@aol.com
Jun 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
288 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
