Question about Troy Bilt 5.5hp Self Propelled Mower
Where is the oil change plug
Need to change oil & filter on 6.75 self propelled frontwheel dr.briggs & stratton, troy bilt
    Problem Solver:
  • 15 Answers
The new B&S.engines dont have one you turn the mower upside down with the dip stick removed and drain it out the oil tube.
Posted on Jul 17, 2012
  • 391 Answers
The plug is under the mower on the bottom of the engine. Make sure you take the spark plug wire off before you work, remove the blade (it needs sharpening anyway right?) and then tilt the mower on its side WITH THE CARBURETOR UP. position an aluminum cake tin under the mower so that once you remove the oil plug using a 3/8" ratchet you can set the mower back down over the cake tin and it will catch the oil. Don't forget to put the plug back in =-)
Posted on Jun 04, 2010
My Briggs and Stratton lawnmower engine won't start. Checked for air, spark, and fuel problems.
Before doing too much more i would pull the flywheel off and check the key has not part sheared.
Jan 28, 2013 | Troy Bilt 5.5hp Self Propelled Mower
My briggs & Stratton won't start. Changed spark plug.
check for spark is there a low oil shut off and the oil level is a little low ?
Jul 01, 2012 | Troy-Bilt Chipper Shredder
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Troy-bilt self-propelled w/briggs and stratton 6.75hp after starting runs for 3 or 4 mins. dies out and in 3 mins later will start and do the same thing any suggestions?....thanka abb
Hello. Your carburator is partially clogged up. That said, if you havn't installed a new fuel filter and new air filter this year do so. Also put in a new plug if u havn't lately. Finally get a bottle of a fuel additive called seafoam and pour it into the fuel following the directions on the bottle. J.
Aug 16, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Won't start after 3 seconds it stops
try changing or cleaning the spark plug and scoket
Aug 18, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have a troy bilt mower with a briggs & stratton engine. How do I change the oil?
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Jul 18, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
6.75 B and S push mower wont start.
Check the kill switch. It may be stuck in the off position.
Apr 26, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
679 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
