Question about Nissan Vehicle Parts & Accessories
My 2000 maxima keyless entry is not working. changed batteries on transmitter and it seem car only locks from transmitter, trunk release and unlock do not work. When looking at the reciever behind rearview mirror the antenna was disconnected and can not be repaired. Where can i get a replacment part and what is it called
  • 27 Answers
SOURCE: 2005 Scion Tc keyless entry not working
You can take the car to the dealer and he can reprogram the remote for you. Or you can buy the programming instructions for $9.95 from here: http://www.keylessride.com/order/programming_post.asp?lbfix=yes&make=Scion&remoteyear=2005&model=tC&frid=76C74C4F
You will need a working key to reprogram your remote.
Posted on Dec 19, 2008
jpk528
  • 95 Answers
SOURCE: keyless entry
trunk release wire goes to the trunk wire of the vehicle and the flash output goes to your parking lights. Now if the trunk release is a positive wire than you will have to put a relay in to make it positive and if your parking lights are negative than you will have to put a relay in to make it negative.
Posted on Mar 01, 2009
  • 22 Answers
SOURCE: Valet 712T keyless entry works inside vehicle only!
Two suggestions one even if its a new battery change it ,secondly if your new car has metalised window tinting on it and your old car did;nt this can be the reason also ,if so move the antenna to the front screen which won;t have tinting.
Posted on Apr 21, 2009
SOURCE: Keyless Entry doesn't unlock my doors anymore
Did you get help? My problem is similar but not as bad. My viper550ESP no longer remotely unlocks the doors (well very, very occasionally it does). That is the only problem.
Posted on Nov 25, 2009
herbalgarden
  • 344 Answers
SOURCE: keyless entry for civic 1997 not working
clean the terminals on the remote chip with a pencil eraser, I had the same problem with my keyless entry for my astro this fixed the problem
Posted on Dec 15, 2009
2003 crown vic keyfob only works with ignition in run position .keyless entry and door locks work fine.even tried new keyfob.no change
The keyless entry system consists of the following components:
  • driver door module (DDM)
  • keyless entry transmitter
  • keyless entry keypad
The driver door module (DDM) receives inputs from the digital transmission range (TR) sensor, ignition switch, brake switch, window/door lock switches, lighting control module (LCM), keyless entry keypad switch and remote transmitter. The DDM outputs consists of keyless entry keypad switch illumination, power door lock actuators, luggage compartment release solenoid, horn relay, and lighting control module (LCM).
  • Battery junction box (BJB) fuses:
    • circuit breaker 7 (20A)
  • Central junction box (CJB)
    • 4 (10A)
    • 6 (15A)
    • 8 (25A)
    • 13 (5A)
  • Keyless entry keypad switch
  • Power door lock actuator
  • Luggage compartment release switch
  • Luggage compartment release solenoid
  • Connectors or connections
  • Wiring harness
  • If fuse's good have checked for DTC'S - diagnostic trouble codes .
  • B1526 Keyless Entry Circuit Short to Ground DDM Go To Pinpoint Test E . B1553 Decklid Release Circuit Short to Battery DDM Go To Pinpoint Test B . B1751 Park/Neutral Switch Circuit Short to Battery DDM Go To Pinpoint Test K . B2425 Remote Keyless Entry Out of Synchronization DDM Go To Pinpoint Test L Need a professional grade scan tool to check fro these codes . Not a code reader for OBD2 codes .
  • The doors do not lock/unlock using the remote transmitter
  • Remote transmitter not programmed.
  • Remote transmitter.
  • DDM.
  • Go To Pinpoint Test F .
Did you program the new key fob ?
Remote Transmitter Programming NOTE: All remote transmitters are programmable and must be set at the same time.
  1. Turn the key from OFF to RUN four times within three seconds, ending in RUN. The locks will then lock and unlock, confirming program mode has been entered.
  1. Press any button on each remote transmitter to be programmed. The doors will lock and unlock to confirm that each remote transmitter has been programmed.
  1. If additonal remote transmitters are to be programmed, repeat Step 3 within 7.5 seconds or steps 2 and 3 if more than 7.5 seconds have elapsed.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
  1. NOTE: Failure to wait at least 20 seconds will cause programming failures. Wait at least 20 seconds after turning the key to OFF or after the last remote transmitter has been programmed to activate a remote transmitter for testing or verification
Feb 19, 2017 | Cars & Trucks
Need help with FOB not responding to commands to lock/unlock doors or open trunk and panic alarm won't work? Replaced battery (CR2032) already. The doors, trunk and starting the car will still function...
Your best bet would be to have the vehicle scanned for DTC'S - diagnostic trouble codes first . Do you know which of these your vehicle has ?
Keyless Entry System Inoperative (Active)
Keyless Entry System Inoperative (Passive)
Does the customer complain about other symptoms related to this, such as poor range when the key fob buttons are pressed or intermittent Tire Pressure Monitoring issues? (It's possible the RF External Antenna at the RCDLR may have a poor connection.)
YES - Go to Step 3
No - Go to Step 4
Inspect the external RF antenna connection at the RCDLR. First, gently pull on the coax connector at the module. If the coax comes out, then it wasn't seated properly. Remove and carefully inspect the coax connection for bent blades or a bent center pin. Fix coax connection if necessary and re-seat connector until a "click" is heard. Gently pull on the coax connection to make sure it is seated properly. Was the inspection made?
Press each button of the transmitter one at a time.
Does the system operate normally?
YES - Go to Testing for Intermittent Conditions and Poor Connections
NO - Go to Step 5
5
Lock and unlock the door locks using the controls inside the vehicle.
Do the locks operate properly?
YES - Go to Step 6
NO - Go to Symptoms - Doors
6
Operate the rear compartment release and the fuel door release from the controls inside the vehicle.
Do the rear compartment release and the fuel door release operate properly?
YES - Go to Step 7
NO - Go to Symptoms - Body Rear End
Important: Ensure that the keyless entry transmitter is the correct model for the vehicle remote system. A wrong model transmitter may pass this test, but will not activate the keyless entry system.
Turn on the J 43241 Keyless Entry Tester.
Place the transmitter on the J 43241 test pad.
Does a tone sound and the green light illuminate on the J 43241 after each button is pressed?
YES - Go to Step 12
NO - Go to Step 8
8
Do any of the buttons on the transmitter sound the tone and illuminate the green light when pressed?
11
Replace the keyless entry transmitter. Refer to Transmitter Programming.
Did you complete the replacement?
Go to Step 12
12
Perform the programming procedure. Refer to Transmitter Programming.
Did the drivers information center (DIC) beep and display a message ready for next fob?
Go to Step 14
Go to Step 13
13
Replace the remote control door lock receiver (RCDLR). Refer to Control Module References for replacement, setup, and programming.
Go to Step 14
14
Operate the system in order to verify the repair.
Did you correct the condition?
Feb 21, 2018 | 2005 Cadillac STS
2008 cadillac cts key fob not working
Testing would need to be done , scan tool hooked up checking DTC'S - diagnostic trouble codes . View data etc...
Keyless Entry System Description and Operation - Active
The keyless entry system is a vehicle entry device. The keyless entry system is used in conjunction with the door locks to unlock the vehicle. Keyless entry will lock/unlock a door or open the rear compartment lid when a corresponding button on the keyless entry transmitter is pressed. This is accomplished by the transmitter sending a radio frequency to the remote control door lock receiver (RCDLR). The RCDLR interprets the signal and activates the requested function via a serial data message. A low transmitter battery or radio frequency (RF) interference from aftermarket devices, such as 2-way radios, power inverters, computers, etc., may cause a system malfunction. High RF traffic areas, such as gas stations that use pay-at-the-pump RF transponders, may also cause interference that could lead to a malfunction. Keyless entry allows you to operate the following features:
• Door lock/unlock
• Rear compartment lid release
• Illuminated entry lamps
• Panic alarm/Vehicle locator
• Remote vehicle start
Your best bet , take it to a qualified repair shop . Dealer
Feb 18, 2018 | 2008 Cadillac Cts
2008 HHR Remote Starter not working
Is this an issue with all 2008 HHR remotes??? Highly doubtful , probably the vehicles keyless entry system . Taking the vehicle to a qualified repair shop an having the keyless entry system checked for DTC'S - diagnostic trouble code's . Do you know what a DTC is ?
The keyless entry system is a vehicle entry device. The keyless entry system is used in conjunction with the body control module (BCM) to remotely activate certain vehicle features. Keyless entry will lock/unlock the doors, or release the rear compartment lid when a corresponding button on the keyless entry transmitter is pressed. This is accomplished by the transmitter sending a radio frequency to the remote control door lock receiver (RCDLR). The RCDLR interprets the signal and activates the requested function via a serial data message to the BCM. A low transmitter or vehicle battery or radio frequency (RF) interference from aftermarket devices, such as 2-way radios, power inverters, computers, etc., may cause a system malfunction. High RF traffic areas may also cause interference that could lead to a malfunction. Keyless entry allows you to operate the following components:
• Door locks
• Liftgate lock
• Remote rear doors (Panel only)
• Vehicle locator/panic alarm
The keyless entry system has the following components:
• Keyless entry transmitters
• Keyless entry antenna
• 2 Way Advanced Remote Start RCDLR
• BCM
Guessing will not fix this .
Jan 12, 2018 | 2006 Chevrolet HHR
I have a 2000 ford mustang. Suddenly my keyless entry remote stopped working. I replaced the battery and turned the off and on 8 times and the locks cycled. after which i pushed the unlock but nothing...
The keyless entry system is controlled by the (GEM) - generic electronic module .
Keyless Entry The electronic door lock system has two main components:
  • generic electronic module (GEM)(14B204)
  • keyless entry remote transmitter (15K601)
  • NOTE: Battery power and ground must be remove before disconnecting the GEM connectors to avoid setting false codes.
    Power Locks Operation The power locks feature allows the customer to lock and unlock the doors via momentary switches located on the driver and passenger door. When the GEM detects a momentary press of the driver or passenger lock button, the GEM will supply power to the driver or passenger lock actuators for approximately 250 ms from relays internal to the GEM. When the GEM detects a momentary press of the driver or passenger unlock button, the GEM will supply power to the driver or passenger unlock actuators for approximately 250 ms from relays internal to the GEM.
    Remote Keyless Entry Door Locks Operation The remote entry feature allows the customer to unlock the driver door, unlock all doors, and lock all doors using a valid remote transmitter as long as the ignition switch is not in RUN or START. The driver door is unlocked whenever the GEM detects a valid remote transmitter unlock transmission. All the doors are unlocked when the GEM detects a second valid remote transmitter unlock transmission within three seconds of the first transmission. All the doors are locked when the GEM detects a valid remote transmitter lock transmission. If the GEM detects a second valid remote transmitter lock transmission within three seconds of the first transmission, the doors will lock again, the horn will sound for 20 ms and the parking lamps will flash for 200 ms to indicate the doors are locked. If the GEM detects the driver or passenger door is ajar during the second lock transmission, the doors are locked again and the horn is sounded twice. If the GEM detects a valid remote transmitter lock transmission within three seconds of detecting a valid remote transmitter unlock transmission, the GEM will lock all the doors
    • Ignition switch.
    • GEM.
    • Remote transmitter batteries.
    • GO to Pinpoint Test C .
    You followed the program instructions to the letter ? Programming -Keyless Entry Remote Transmitter NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
    NOTE: All previous transmitter identification codes (TIC's) will be erased when programming mode is entered.
    NOTE: To program (or reprogram) the keyless entry remote transmitters into the generic electronic module (GEM)(14B204), perform the following steps.
    1. Turn the ignition from OFF to RUN eight times within 10 seconds, ending in RUN. If the GEM has successfully entered program mode, it will lock and unlock all the doors.
    1. NOTE: The first TIC must be entered within 7.5 seconds of entering the program mode and additional TICs must be entered within 7.5 seconds of the first TIC. The programming mode is exited whenever the timing constraints are not met.
      Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
    1. If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
    1. Turn the ignition switch to the OFF position, or wait up to five minutes after step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will lock and unlock all the doors one last time.
    1. Take an have the vehicle checked for DTC'S
B1396 Power Door Lock Circuit Short to Battery GEM GO to Pinpoint Test B . B1397 Power Door Unlock Circuit Short to Battery GEM
Apr 12, 2017 | Ford Mustang Cars & Trucks
Keyless remotes not working
Try reprogramming the remotes. Here are the instructions for the procedure. Hope it helps. Cobra!
Programming NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
NOTE: To program (or reprogram) the keyless entry remote transmitters into the RAP module, perform the following steps:
  1. Make sure that the anti-theft system is not armed or triggered.
  1. Turn the ignition switch (11572) from OFF to RUN eight times within ten seconds, ending in RUN. If the RAP module has successfully entered program mode, it will lock and then unlock all doors.
  1. Within 20 seconds, press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed. Repeat this step for each transmitter.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Inspection and Verification.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the RAP module will lock and unlock all doors one last time to confirm.
Jun 06, 2010 | 1998 Ford F150 Regular Cab
My battery goes dead on my 1996 Lincoln Mark VIII overnight. I found that the lights come on by themself after I park the car. There is a clicking sound coming from the security module in the trunk when I...
security module in the trunk ???? There is no security module in the trunk . What light's come on by them self ? Park lamps , headlamps , brake lamps ,turn signals etc.... The module for anti-theft is under the right hand side of the dash . The remote keyless entry module is located in the trunk. Is this the part you hear clicking in ?
Door Lock Control Processor, Electronic NOTE: The electronic door lock control system will not function when the ignition switch is in the RUN or ACC position.
The electronic door lock control processor:
  • is located on the LH side of the luggage compartment.
  • contains a radio receiver that receives a signal from the keyless entry remote transmitter (15K601) through electronic door lock control processor antenna, and sends the appropriate command to the power door locks, the horn relay, the indicator flasher, or the anti-theft warning system.
  • is equipped with a battery backup which holds the programmed code in memory in the event the vehicle battery is disconnected.
    • Doors Do Not Lock or Unlock Using Keyless Entry Remote Transmitter
    • Circuit.
    • Electronic door lock control processor.
    • Keyless entry remote transmitter.
    • GO to Pinpoint Test B .
Aug 17, 2017 | Lincoln Mark VIII Cars & Trucks
Keyless entry 2005 grand am i put new ignition on car, 2005 grand am it came 2005 grand am that i own that was wrecked my car that i want to put it on did have remotes when i bought it they were lost, igot...
To program the transmitters, perform the following procedure while seated in the vehicle driver's seat:
Close all the vehicle doors.
Remove the ignition key from the ignition lock cylinder.
Press and hold unlock on the door lock switch.
Important: To successfully enter the keyless entry programming/diagnostic mode, steps 4 through 6 must be completed within 25 seconds of pressing the door unlock switch.
While holding the door lock switch in the unlock position, insert and remove the ignition key twice. Do not rotate the ignition lock cylinder.
Insert the ignition key a third time leaving the key in the ignition lock cylinder. The ignition must remain in the LOCK position for the rest of the procedure.
Release the door lock switch. The chime will sound three chimes to signal that transmitter programming/diagnostic mode is active.
Press and hold the lock and unlock buttons at the same time on the keyless entry transmitter for approximately 4 seconds. The chime will sound two times to signal that the transmitter has been programmed successfully.
To exit the transmitter programming/diagnostic mode perform either of the following:
• Turn the ignition switch to the RUN position.
• Remove the ignition key from the ignition switch
Oct 21, 2009 | 2005 Pontiac Grand Am
Keyless entry remote quit working. Just purchased new battery. Now Spare remote does not work either.
Transmitter Programming Notes Transmitter Programming
  1. Start with the ignition OFF, hold down the power unlock button on the door panel. Turn ignition key ON, OFF, ON, OFF. Release power unlock button on the door panel. The locks will cycle once.
  2. Hold down the keyless entry transmitter LOCK and UNLOCK buttons for 15 seconds . The locks will again cycle once.
  3. Repeat step #2 for each additional keyless entry transmitter.
  4. Turn the ignition on to exit the keyless entry transmitter programming mode. Programming is now complete
Jun 17, 2009 | 2000 GMC Sierra
My remote for the keyless entry does not work.
does trunk button work? panic button?
here's 2003 info:
  • Driver door module (DDM).
  • Go To Pinpoint Test G .
SECTION 501-14: Handles, Locks, Latches and Entry Systems 2003 Town Car Workshop Manual
GENERAL PROCEDURES Remote Transmitter Programming
  1. Cycle the ignition from OFF to RUN four times within three seconds. The locks will then lock and unlock, confirming that the program mode has been entered.
  1. NOTE: When the first keyless entry remote transmitter is programmed, all other keyless entry remote transmitters are erased.
    Press any button on the transmitter to be programmed.
  1. If additional keyless entry remote transmitters are to be programmed, repeat Step 2 within 7.5 seconds.
report back
Mar 22, 2009 | 2004 Lincoln LS
Vehicle Parts & Accessories Logo
236 people viewed this question
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
George Agios
George Agios
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
