Apr 09, 2008
The "E18" or "Lens" error message indicates an error that involves the lens unit or lens cover.
This error may appear where the lens is prevented from properly
extending or retracting such as, for example, when pressure is applied
to the lens or the area surrounding the lens while handling the camera.
The error may also be displayed if the lens unit/camera has been
subjected to an external shock, or if a foreign substance (i.e. liquid,
sand, dirt) enters the camera.
Solution
Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area:
- Hold the camera so that your fingers do not touch the lens unit when you are shooting.
- Make
sure the camera is off before the camera is placed back in the case.
Exercise caution to ensure that the camera does not accidentally power
on while the camera is stored inside the case.
If you cannot clear the error code by turning the camera off and then
on again, or if the error code is displayed frequently, a camera
malfunction may have occurred.
