Question about Hayward 116k BTU HeatPro Digital Heat Pump HP21003T
Panel reads lp error code
Heat pump wont work has lp on panel
    Scholar:
  • 78 Answers
Loss of refrigerant, bad motor for the fan clean the coils and unit as described in the manual. Here is a manual from the Hayward website or here http://www.haywardnet.com/products/manuals/pdfs/Manual122.pdf.
Posted on Jun 06, 2010
Hayward heat pump error code L P . what does this mean?
LP is an error message refering to the low pressure switch. For more information about it please refer to hayward-pool.com/pdf/manuals/Manual122
Aug 11, 2011 | Heating & Cooling
What does LP stand for , Ive seen when it says PS(power save) but Trying to heat the pool and ran for a day then said LP?
LP is an error message refering to the low pressure switch. For more information about it please refer to your owner's manual here. If you decide to persue attempting to repair it yourself and need further assistance, please reply to this post with a new comment or start a new post with your specific question(s).
John
Feb 01, 2011 | Hayward 116k HeatPro Heat Pump HP3100
Turned on my Heat Pump, kicked on for a few minutes, now it won't kick on and code said L5, now says LP. Left it alone all night, still says LP???
HOPEFULLY ITS STILL UNDER WARRANTY.
CALL HAYWARD OR GO TO HAYWARDPOOLS.COM.
THEY WILL SEND A LOCAL SERVICE REP TO COME ADJUST THE FREON LEVELS (LP).
Dec 27, 2010 | Hayward 116k HeatPro Heat Pump HP3100
Malfunction code tE
TE error code stands for thermistor error. You have to remove the front panel and ohm out the heating element. If you have continuity most likely it will be fine. There is a thermistor located next to the heating element that will probably need to be replaced. LG's are the only machine besides GE ref's that I have ever seen thermistors go bad on. There is probably an ohm reading you should get through the thermistor but unless you have an analog meter or a fluke most standard digitals wont read into mega-ohms. Removing the front panel is model specific. But i can tell you the spring around the front boot (drum gasket) needs to be removed and there will be some hidden screws at the bottom by the pump where the access panel is located.
Hope this helps _MJ_
Jan 31, 2010 | LG WM-2277HW Front Load Washer
LP flashes when it is turned on
THIS IS A LOW PRESSURE CODE PROBABLY LOW PRESSURE SWITCH THE ONLY OTHER TIME THIS COMES ON IF ITS TOO COLD OUT SIDE
May 22, 2009 | Pool & Spa
I have a rome Industries Pool heat pump model 105 showing error code LP???? what does that code mean and what do I do?
I happen to work for Rome Industries and can help you out. The "LP" code on your control board represents "Low Pressure". This is referring to the refrigerant pressure within the unit. The unit is equipped with a low pressure safety switch that when activated shuts the unit down. This could be caused by a refrigeration leak, a stuck thermal expansion valve, or even a faulty pressure switch. If you live within the state of Florida contact Rome Industries and you will receive a free of charge service call including parts and labor as long as your unit is under warranty. If your outside of the state please contact your dealer to handle the claim. Have a good day.
May 01, 2009 | Pool & Spa
Raypak gas pool heater with error code HL2
Do you have power to the heater?If you do then I would look for a hi limit switch to reset.It might be the pump you have to reset.
Mar 16, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
Hayward 116k BTU HeatPro Digital Heat Pump HP21003T Logo
1,564 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
