Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
My Whirlpool Gold Dishwasher is not cleaning the dishes.
My Whirlpool Gold Dishwasher is only 2.5 years old, but it is not thoroughly cleaning my dishes...especially on the top rack. Why?
  • George Spencer
    George Spencer Feb 28, 2014
    Take out the bottom arm and and strainer to get to the chopper and screen the screen is probably clogged with fine matter, you will have to pull dishwasher underneath are two motors should be the one by the chopper drain,udo motor now clean screen. Will work now
  • 10,515 Answers
Below I listed 3 reasons why this may be happening and a product that will clean this off for you!
Glasses Are Cloudy/Spotted:
• Select Extra Rinse (select models).
• Check water temperature. Incoming water should be 120°-140° F (49-60° C).
• Always use a rinse aid.
• Confirm that the cloudiness is removable by soaking the item in white vinegar for approximately 5 minutes. If removed, the problem is due
to hard water. Adjust detergent amount being used to match water hardness (pg. 5). Be sure detergent is fresh, stored properly and is a
high quality brand.
• If cloudiness is not removable, it is etching. This is an erosion of the surface of the glassware and can be caused by water that is too hot,
from using too much detergent or by prewashing. Detergent needs food soil to act upon. If etching has occurred, the glassware is permanently
damaged. To prevent further etching, adjust the detergent amount to match the water hardness, stop prewashing, and be sure incoming
water temperature temperature is not greater than 140° F (60° C). Use water heating options only when incoming water temperature is below
120° F
Food Soil Remains on Dishes:
• Run hot water at the sink before starting the dishwasher.
• Select Tough Scrub™ or Tough Scrub™ Plus (select models).
• Check water hardness and adjust detergent amount accordingly
• Use fresh detergent stored in a cool dry place.
• Select proper cycle for the soil level.
• Load items so they do not block the wash arms or center tower
• Load the utensil basket with some handles up and some down to prevent nesting.
• Do not place glasses over tines.
• Prior to loading, scrape off burnt on foods and wipe the starchy film from utensils used with pasta, rice and oatmeal. These soils require
more energy than the rest of the load to clean.
Items Washed In The Dishwasher Or The Dishwasher Tub Itself Are Stained/Discolored:
• Aluminum utensils or pans can leave marks when they rub against other items. Leave a slight space between items.
• Iron deposits in the water can leave a yellow, brown or orange film on dishes or the dishwasher tub. A filter may be needed, check with a
water treatment company. RoVer Rust Remover (part no. 057961)** can be used to remove rust. Do not use RoVer along with dishwasher
detergent. Fill both cups with RoVer and complete a Normal Wash cycle. Follow with a short wash cycle using dishwasher detergent.
• Color from tomato sauces may adhere to the tub . If light staining has occurred, leave the door open to oxidize the stain away. For
removal of heavier stains, try a citric acid containing dishwasher cleaning product such as Glisten (part no. 18001017)**. Change dishwasher
detergent and be sure to use a dishwasher detergent that contains chlorine to better fight staining.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jun 04, 2010
I have a whirlpool Gold quiet partner III that is about 14 years old. It is no longer getting dishes consistently clean.Is it something fixable or is it time to get a new one?Could it be cleaned out?
There are many places and parts for dirt to remain after washing. Clean all parts as per manual. Spray inside with vinegar and lemon juice, place tablespoon of bi-carb soda in dispenser and put through cycle without dishes
Feb 25, 2015 | Whirlpool Dishwashers
Our Whirlpool dishwasher in only 2 years old and yet it is not cleaning the dishes. Each load comes out with white film on the dishes. What can be causing this?
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Nov 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
My whirlpool gold dishwasher is about 11 years old now and is'nt cleaning my dishes at all...they are still dirty both top and bottom. Any ideas??
Make sure the water sprayers are not clogged. It may just be a good idea to get new sprayers and they are easy to install.
Aug 16, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
My dishwasher is not cleaning the dishes properly it leaves food on some of them. Is it gettin enought water? what could the problem be if not. It is 1 1/2 years old. thanks MAB
If the dishes are spotty or cloudy the problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 19, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
My Whirlpool Gold Dishwasher isn't cleaning
You need a new water valve. Call us for parts and supplies for your Whirlpool dishwasher. We will be sure to get the correct part out to you right away! We look forward to hearing back from you soon.
Sep 09, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
How do you fix a noisy whirlpool dish washer DU1100XTP(Q) ?
A hard object has entered the wash module (on some models).
When the object is ground up, the sound should stop. If the
noise persists after a complete cycle, call for service.
Mar 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
874 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
